Question about Frigidaire Dishwashers
CONTROL LIGHTS BLINK BUT WONT OPERATE
My dishwasher lights blink and it wont operate.its a frigidaire model #GSB5712BS1
  • 6,784 Answers
Anytime the lights blink simultaneously on this model, it is because of a major control fault that has occurred.
unplug the unit or shut the breaker off for 3 minutes. if the lights continue to blink after the 3 minute reset, replace the control/timer module asap.
Posted on Jun 03, 2009
Frigidaire Dryer model # LEQ1442ES0. The lights come on and beep at us like normal when I change settings but when I press start, they just blink and beep but wont turn on.
Thank you for your post, friend!
From my understanding your Frigidaire dryer is not starting and the lights just blink. It sounds like a faulty door switch or control panel. I would check to make sure the latch or door strike is not cracked or broken if the door is not closing properly that could be the cause of your dryer not starting.
You could also perform a reset on your dryer and that could help clear any faulty error codes within your dryer. To reset your dryer you would unplug the power cord for ten minutes. I hope this has been beneficial. -Matt
Oct 17, 2014 | Frigidaire Dryers
Frigidaire model FDB750RCC0 dishwasher wont work?
Hello John - Please describe what the unit is, or is not doing? Does it have power at all? Is it blinking any lights or creating any audible beeps?
Sep 23, 2012 | Frigidaire Dishwashers
My dishwasher wont start. After pressing start the light(s) pressed blink but doesnt start. The delayed start is not selected
Hi
First make sure that nothing is blocking the drain pump assembly located inside the lower front panel of the dishwasher. If the issue returns after its cleaned then try to reset the dishwasher control by pressing the HEATED DRY button and hold it for 15 seconds, if its still not resolved then it means that the control board has gone bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 30, 2011 | Frigidaire Dishwashers
E25
hello,
All error codes start with the letter "E". An error code of E11 will have the five indicator lights flash once and the Start indicator light flash once.
Some models of Frigidaire washers come with a digital readout display that informs the operator of the unit's function and any errors.
Error codes indicate that a problem has occurred and should be addressed. Different models of Frigidaire washers may vary in their fault displays.
Some washer models use flashing lights at the unit's start, door lock, wash, rinse, final spin and control indicators to display error codes.
If the five indica
tor lights flash more than nine times, this signals a letter in the error code. The letter "A" stands for 10 flashes, "B" for 11, "C" for 12, "D" for 13, "E" for 14 and "F" for 15 flashes. An error code of EB2 will have the five indicator lights flash or blink 11 times, and the Start indicator light blink twice
hope this help?
thanks.
Oct 23, 2010 | Dishwashers
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
All buttons light up and nothing happens wont start.. Or sometime you hit pan wash cycle and all it does is blink
This is mainly due to control panel failure. This unit does not vent from the front like most do, so there needs to be some clearance above the top of the tub to avoid blocking the vent fan, otherwise moisture gets trapped in the machine and works it's way into the control panel eventually.
Thank you !!
Jul 01, 2010 | Frigidaire PLD2855RFC Dishwasher
Dishwasher is less than a year old. Once in a while it will stop about 10 minutes into the cycle, then the display lights will blink. Sometimes it will stop and the lights wont blink so we will come back...
I would most likely guess a faulty latch....it will cancel the cycle, thinking that the door has opened, and the lights will flash. After a certain amount of time, it might "time out" and reset and the lights would stop flashing. Unfortunately it's a bit of a guess, but the other option would be a bad control board.
Apr 07, 2010 | Frigidaire 24 in. PLD2850 Built-in...
When trying to start the dishwasher the normal load light,heat light, and other lights blink and nothing happens.
take the control panel off and re-seat the ribbon cable back on the board if that does not change anything replace your control panel.
Feb 20, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire Dishwasher Energy Star blinking lights.
Hmmm...don't know why this worked, but it did. When the lights were flashing when I tried to start my Frigidaire dishwasher model#FDB1500LF, nothing would happen...just blinking lights, so I went to the house electrical panel, found the switch for the dishwasher, turned off & on again, and now the dishwasher works.
Go figure.
Feb 16, 2009 | Frigidaire 24 in. PLD2560LCC Energy...
Cycle stops, lights blink
I have the same problem, same model. Driving me nuts. Help!
Dec 03, 2007 | Frigidaire 24 in. PLD2560LCC Energy...
Dishwashers Logo
956 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
