Question about Canon PIXMA MX310 All-In-One Printer
Can't fax it dials and says it is sending and doesn't send. Then says error...
Ndustrial RS-485 Guide
www.bb-elec.comRS-485 Industrial Conversion Solutions Made Easy - Free Guide
Posted on Sep 27, 2012
SOURCE: faxing
That is the same problem that I have. I think the settings for the fax have to be reset. I am calling canon to get help.
Posted on Jul 05, 2008
SOURCE: sending fax
Try turning off ecm (Error Correction Mode) It appears this may be common on this series. Basically line issues
Posted on Feb 09, 2009
CompuGuy44
  • 432 Answers
SOURCE: Comm. Error
Try this website: http://www.instruccionesweb.com/u2/pdf/fax/Canon-L120-en.pdf
Posted on Jun 25, 2007
kram26
  • 544 Answers
SOURCE: connot send fax
thank you for using Fixya.com.
please try to log it off and check carefully the plug if it is connected properly. like the connection to line and unit.
try to switch on again..
thanks,
Posted on Feb 18, 2009
SOURCE: Tx Cancelled: Rx Fax Info Mismatch
Can you tell me how you resolved it? Please Email me at:
PalpatineX@comcast.net
Posted on Dec 16, 2009
How do you send a Fax?
1 Load the document face up into the Document Tray.
2 Dial the receiving party's fax number.
3 Press [Start/Copy].
The fax begins sending.
Note
If an error occurs during sending, the fax beeps intermittently for a few seconds and an error
message appears on the LCD. If this happens, correct the problem and then press [Stop], then
try sending the document again.
The fax automatically redials if the receiving party does not answer or if the line is busy.
Feb 21, 2011 | Canon FAX-JX200
Fax machine will not send. Dial # Push Send and
If the fax is not set for tone dailing and it is set for pulse dialing the fax will not register the # button.
Dec 03, 2009 | Brother IntelliFax-2820 Laser Fax
Can't send faxes. Dials Ok but no connection to send fax
If you are unable to send the faxes, please try decreasing the modem speed and disabling the "Error Correction Mode." To decrease the modem speed, please follow the steps given below:
1. Press the "Fax" button.
2. Press the "Options" button 15 times till it reads "Advanced Fax" on the display.
3. Press the "Select" button.
4. Then press the "Options" button 10 times till it reads "Max Send Speed."
5. Now press the "Right Arrow" button and choose "9600 bps."
6. Press the "Select" button.
To disable "Error Correction," please follow the steps given below:
1. Please press the "Fax" button.
4. Then press the "Options" button 11 times till it reads "Error Correction."
5. Now press the "Right Arrow" button and choose "NO."
May 19, 2009 | Lexmark X4270 All-in-One Multifunction...
Fax not going out/coming in
connect a phone with 4521 in the back side jack of phoneout,
for outgoing fax
place original in the adf or glass for fax
Press hookdial and dial your sending fax number in 4521 after number dialing pull the phone handset to ear when you leason fax tone from the dialing number press start button to send fax.
for incoming fax (in not automoated)
press hook dial and press start to receive
Mar 01, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Hi, Remote Fax Error being displayed
Set the DRPD in the settings to 9600 and then try send a fax ...
Jan 29, 2009 | Dell 924 All-in-One InkJet Printer
Please help me send a fax on my HP 5610
Send a fax
You can send a fax in a variety of ways. Using the control panel, you can send a blackand-
white or color fax from your HP All-in-One. You can also send a fax manually
from an attached phone. This allows you to speak with the recipient before sending
the fax.
If you frequently send faxes to the same numbers, you can set up speed dial entries.
For more information on setting up speed dial entries, see Set up speed dialing.
Send a basic fax
You can easily send a single- or multiple-page black-and-white fax by using the
control panel, as described here. If you want to send a color or photo fax, see the
onscreen HP Image Zone Help.
Note If you need printed confirmation that your faxes were successfully sent,
enable fax confirmation before sending any faxes. For more information, see
Print fax confirmation reports.
Tip You can also send a fax manually from a phone or by using monitor
dialing. These features allow you to control the pace of your dialing. They are
also useful when you want to use a calling card to charge the call and you
need to respond to tone prompts while dialing. For more information, see Send
a fax manually from a phone or Send a fax using monitor dialing.
1. Load your originals, with the print side up, into the document feeder tray. If you
are sending a single-page fax, such as a photograph, you can also load your
original on the glass.
Note If you are sending a multiple-page fax, you must load the originals
in the document feeder tray. You cannot fax a multiple-page document
from the glass.
2. Press Fax.
Oct 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Printer can't send or receive faxes
Same problem here - I got it work:
- Error Correction: off
- V34: off
(both Menu -> Fax-Setup - All Faxes)
- detect-dial-tone: off
(Menu -> Fax Setup - Fax Send setup - detect dial tone)
:-) Stefan
Aug 30, 2008 | HP LaserJet 3055 All-In-One Printer
Fax machine stoped receiveing fax
First, check your fax's phone line. Put a regular phone on it and check for dial tone and line noise. If the line is dead or noisy, this will cause a problem.
You can also try dialing your fax number from another phone and see if the fax unit picks up the line and starts initiating communication. (sounds like modem noises)
Jul 30, 2008 | Brother MFC-7820N All-In-One Laser Printer
Error 401 & 634
error 634 is an indication that the line was either busy, or there was no answer on the receiving end.
Jul 23, 2008 | Panasonic Panafax UF-550 Plain Paper Laser...
Problems sending faxes with B820
make sure it says doc ready before pressing start!
Feb 28, 2008 | Canon FAX-B820 Plain Paper Bubblejet
Canon PIXMA MX310 All-In-One Printer Logo
538 people viewed this question
old marine
old marine
