Question about Samsung TXR3079 TV
Tv turns off after several minutes
TV is not attached to anything.  After running for 10 minutes or so.  The T.V. turns off.  I unplug it for 5 minutes or so, it comes back on.  I have checked the sleep timer (not set).  I have gone into service mode and reset .  I believe there is an over current condition going on.  Any suggestions how to isolate the component or board would be appreciated.
  • 4 more comments
  • Anonymous Dec 02, 2007
    Same problem - been waiting for an easy fix to pop up, but so far haven't seen one.
  • Anonymous Dec 04, 2007
    Mine goes off after 2 hours. Wait 5 minutes and then over time turns off about every 15-20 minutes.
  • jgiardina Dec 29, 2007
    Mine will work for a while and then start shutting off and on. Once it
    starts shutting off and on ti will get more frquent until it's about
    every minute or two. - DO NOT get Best Buy Extended warranty.
    I've been waiting for 2almost 2 months for them to repair it.
  • cadblur Dec 29, 2007
    this has only happened twice in the last year. I waited for about five minutes, and it came back on by itself
  • jeepchick79 Feb 21, 2008
    mine too. i turn it on and watch for 30-40 mins. wait 5 mins and it turns back on for another 20 mins and then shuts off again. wtf is going on? im pretty upset about it since i didnt register it and now samsung wont help me. what customer service. i wont be purchasing samsung products any longer.
  • aswild Aug 18, 2008
    i have the slim fit and i turn it on and @ 15 min. or so it turns off ,,and will not come back on ..i unplug it and then it will turn on for another few then turns
    off.. i can unplug it and plug it back in an the red light on the front stays on ,,but when i turn tv on and it shuts off the light goes out and does not come back n ,tv is less than 2 years old ,,,i need help
    Problem Solver:
  • 7 Answers
Rbuchalt:
I had the same problem with my Samsung TV Model: TXR3079WHX. I troubleshot my problem with a can of component cooler from Radio Shack and found my problem to be a defective voltage regulator, identified as "QR015" on the main circuit board (the same board that contains the high voltage section).
Caution:
Before I proceed any further I need to strongly warn you. Do not attempt to remove the back cover, troubleshoot, repair or perform the actions that I have done, if you are not a "qualified service technician". Removing the back cover exposes you (and anyone else) to harmful and deadly electric shock, even though the TV may be unplugged from the wall outlet and turned off. You (or anyone else) can be seriously injured or even killed. If you are not qualified, play it safe by allowing others who are qualified repair this for you.
The defective part (overheats and shuts your TV off) is voltage regulator manufactured by Fairchild. The part number is KA75450ZTA. This part is available from Mouser Electronics for less than 20 cents plus shipping. In order to replace this part a qualified technician will need to remove certain cables and unscrew the main board to allow access to desolder and solder the new component.
Hope this helps.
Posted on Jun 06, 2009
It seems to be a heat issue. I have had this problem for over a year now. If I turn on a fan and have it blow into the body of the set behind the screen [either side] it solves the problem.
Posted on Dec 24, 2008
I am having the same problem, please let me know if you find a solution. Here is my email address:
FBalski620@hotmail.com
Posted on Aug 30, 2008
SOURCE:
Sony Plasma KDE 42xs955 has delay in of 5 to 10 minutes for picture to appear. Sound turns on immediately
Contact the authorized service centre for Sony. This is not a fault that a normal user can do anything. Electro help
Oct 22, 2014 | Sony KDE-42XS955 42 in. Plasma HDTV
Jvc tv
FOLLOW this steps and fix it. God bless you
  • 1
    Power down the TV. Let it cool down for several minutes to avoid touching anything hot. There are many parts inside the TV that could be hot.
  • 2
    Unplug the TV and all media devices attached to it. Let the TV sit again for several more minutes just to be safe. The lamp receptacle and other components could still be hot.
  • 3
    Unscrew the back cover of your TV with a screwdriver. Have someone help if the cover is big. The lamp's housing unit on most TVs is located towards the bottom. Refer to your TV Owner's Manual for specific instructions.
  • 4
    Unscrew the lamp's housing unit with your screwdriver. Take your time to avoid damaging the housing unit. You'll see the lamp once you open the housing unit.
  • 5
    Use a soft cloth to unscrew the lamp out of the housing unit. There's a possibility the lamps- could still be hot. The cloth will help protect your hand.
  • 6
    Screw the replacement lamp into the housing unit with the same soft cloth. The oils from your fingers could ruin a rear projection TV bulb.
  • 7
    Reattach the lamp's housing unit and TV back cover. Make sure no wires are loose or get caught when screwing the back cover on.
  • 8
    Attach all media devices like cable or satellite boxes. You should now be able to watch your TV with a brand new picture.
Jul 25, 2013 | Televison & Video
Sharp lc-46le830u LCD tv does not turn on white arrow flashes 2 times slow than a pause and than flashes 5 times quick .it flashes this pattern over and over.what does this code mean?
It doesn't correlate to tthe trouble code in the users manual which are written. It sounds like a motherboard error. Try a cold reboot. Unplug the TV for 2 minutes then restart the TV and anything it is attached to. Unplug all first.
Feb 17, 2013 | Sharp Aquos Televison & Video
Samsungh LA40B530 No picture but sound
try connecting tv to cable direct also try unplugging both converter and tv for wile like 5 mins plug both back in see if tv and converter sync, but if otherwise then
The ysus board is the most common reason.
you can try websites on ebay.com to buy parts for replacement...
Aug 03, 2010 | Samsung LA40B530 40 in. HD-Ready TV
Samsung TV turns itself off every 10/15 minutes
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Jul 20, 2010 | Samsung TXM3297HF 32" TV
Tv will not turn on. Flashes 10 times. If we unplug/plug it basck in several times we can eventualy get it to work. Seems to be getting worse every day.
You need to replace the power supply, PN: ETX2MM704MGH. This 10 flash failure is common. I hope this was helpful, best wishes.
May 12, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
Tv won't turn on
These TVs have a self-check at turn-on, and will retry 3 x and then quit. Self-checks are like current overloads,voltages not present, IC communications not good, picture tubes not running. Can be anything without checking circuits.
May 02, 2010 | RCA HD52W58 52" TV
When i turn on the TV...it runs for 5-10 min...then shuts off... this turn it back on...it runs again for short time and turns off...repeats several times till it stays on...will stay on indefinitly till...
Hi Friend,
Please folliow the below steps one by one,try by resetting the TV
Step 1: Turn on the TV
Step 2: Hold the ON/OFF Button for 10 to 20 Secs
Step 3:Without taking the hand from the ON/OFF button unplug the power cable connected to the wall outlet from the TV
Step 4:Without taking the hand from the ON/OFF button put the power cable back to the outlet
Step 5:Now take the hand from the ON/OFF Button and try to turn it ON again and check
Even after that you are facing the same issue please check with the Display Card whether its has got any problem in the TV,
If you have any Clarification please feel free to contact us
Regards,
Ayyasam
Apr 02, 2010 | Panasonic PT-50LCX64 50" Rear Projection...
TV shuts off after 5 minutes.
ours did that we had to replace the lamp
Jul 21, 2009 | RCA D52W135D 52 in. TV/DVD Combo
My Panasonic TU-PT700U Digital media Receiver shuts the TV down after 10-30 minutes and the blue light flashes 5 times repeatedly. I have to unplug the unit and let it cool for several hours before it it...
Hi, I have a spare TU-PT700U that may be of use for you to solve your problem without having to replace your system.  My Panasonic onyx series monitor was stolen out of my house, but they left behind the TU-PT700U and cable.   If interested, respond to my craigslist post..
http://sfbay.craigslist.org/sby/ele/930283631.html
Nov 11, 2008 | Panasonic Televison & Video
Samsung TXR3079 TV Logo
210 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
