Question about Canon imageRUNNER 1370F All-In-One Laser Printer
System Error E810 - how do I fix?
Canon Imagerunner 1370F shows system error E810. How do I fix?
    President:
  • 1,126 Answers
E810 and/or "CHECK TONER/DRUM CRG" message on control panel.
Something is amiss in the drum unit. Make sure that the drum unit and developer units are attatched together at the front and rear. Use cation when removing, as the drum is light and scratch sensitive.
If all is well there, either call a service tech or replace the drum unit(expensive) approx. $135 for GPR 10 Drum unit.
Posted on Jun 03, 2009
My copier was working just perfect.(canon ir 1270f)...and had a paper jam..removed and now its shows error code toner/drum crg..what could possibly the problem...please help me out with this
hello
remove the paper jam and close the front cover and unplug the power from the outlet and same at the back of the printer, wait for 5 minutes and plug it again. this will helps to clear the error code of the printer.
thank you
Mar 08, 2011 | Canon imageRUNNER 1370F All-In-One Laser...
'check toner/drum crg' error, Cannon imagerunner 1370f
check the contacts inside of copier cavity where they line up with drum unit and make sure they are in correct position.
Mar 01, 2010 | Canon ImageRUNNER 1670F Copier
System error canon ir 2000
that is a fuser related error,probably the fixing film is torn or the fuser thermistors are bad
Feb 08, 2010 | Canon imageRUNNER 2000 Copier
Canon iR 1330, Getting SYSTEM ERROR E810
The case that the toner bottle is detected, but not the cartridge. The DC Controller PCB is faulty so the cartridge is faulty.
You can try these things to see if it helps:
If the spring that supplies the high voltage is dirty, clean it.
If the connection between the high voltage spring and the DC controller is not a normal connection, correct the connection.
You might have to replace the Developing Unit DC Controller PCB.
Hope this helps.
Jan 06, 2010 | Canon Office Equipment & Supplies
Canon Irc2105 Colore Copyer Machin
E215 -The thermistor of the scanning lamp (fluorescent lamp) exceeds
a specific temperature, check your scan lamp
Apr 05, 2009 | Canon imageRUNNER C3200 Color Printer
Need help adding numbers to speed dials canon imagerunner 1370f
One of the easiest ways to explore this is with the RemoteUI, the web management interface accessable by entering your imageRUNNER's IP address into your web browser's address bar.
I don't have one handy so I cannot be certain, but you will want to look for the Address book. It should be clearly listed on the left hand navigation.
If you are prompted for a password enter your system manager password (used with Job Accounting, usually)
Unless you have a system manager password set, you can login via admin mode with a blank password.
Dec 18, 2008 | Canon imageRUNNER 1370F All-In-One Laser...
Canon imageRUNNER 1370F All-In-One Laser Printer Logo
958 people viewed this question
old marine
old marine
