Question about Hitachi 43FDX15B 43" Rear Projection Television
How many hours would you expect to get out of a Hitachi CRT Tube for model number 43FDX15B. Tube part number UE20312. Does the TV keep track of the number of hours on a CRT Tube? How do I display the number of hours on a CRT Tube? Where is the chepest place to buy a replacement CRT. I fond one at Video Display Corp that is $165 each. They require you to send in old tube to rebuild. Are there any other companies that rebuild these CRT tubes? I am buying a used Hitachi 43FDX15D TV. What would you recommed I check out on the TV before I purchase it, beside the number of hours of the CRT Tubes.
  • mdoble Jun 02, 2009
    Need all the questions awnsered in my post.
  • 11,896 Answers
Yes these tv's keep track of how many hours on a tube. Tubes unfortunately these days last about 5-7 thousand hours. 8 if your really lucky. If you are good at repairing electronics, you can buy the caps for the tubes for about $4 each and solder them in. A repair manual may be needed.
  1. All rear projections have the option of reseting the lamp hours. This helps since you will know how many hours your last lamp ran for. Normal lamps should run between 5000 to 8000 hours.
    Try the following procedure:
    Please be cautious when entering service mode. Following the information below and you will have no problems.
  2. Step 2 Enter service mode by pressing Display, 5, vol +, Power On.
  3. Step 3 Proceed to the Option-E screen by pressing the 2 or 5 button
    Option-E 0 0
  4. Step 4 Change data to 1 using the 3 button on the remote
    Option-E 0 1
  5. Step 5 Press Mute Enter to write data.
  6. Step 6 How many hours would you - 2kba94e28fb1_thumb.jpg Image of Lamp Reset courtesy of www.agoraquest.com There is a jpeg image on this at www.agoraquest.com and more specifically at http://www.agoraquest.com/editor/upload/2kba94e28fb1.jpg
Posted on Jun 02, 2009
  • 10,594 Answers
There is no counter in TVs to show usage hours of CRTs in rear projection TVs.
Time counter facility is only available in DLP TVs (those use lamp) Plasma and LCD.
Tube UE20312 is available in Part Store for $248 and I do not trust on CRT rebuild and I do not recommend to buy defective TV that requires CRT.
Thanks.
NO RED COLOR ON A 43FDX15B HITACHI 52
3 reasons for this.
1st reason the fluid is contaminated and thats why u dont get red.
2nd reason no red drive possibly due to a bad colour driver on the base of the tube neck.
3rd reason the tube is out.
May 23, 2010 | Hitachi 43FDX15B 43" Rear Projection...
43fdx15b Hitachi 42in red vertical lines magic focus inop for red
This is a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors.Shops usually charge from $200-$300
Sep 26, 2009 | Hitachi Televison & Video
Hitachi 43FDX15B has a red tint...
This can be caused by a few things. The red crt/picture tube is going bad, which it would have to be replaced, tube can cost anywhere around $195 and up, if it is available. Another problem can be a bad transistor or IC on the red crt circuit board. Either way it should be taken to a repair shop. The average cost for repair could be over $300.
May 26, 2009 | Hitachi 43FDX15B 43" Rear Projection...
Hitachi 43FDX15B TV
Symptom: DARK PICTURE OR MISSING COLOR
Cause: CLEAN SPARK GAPS, CRT PINS AND SOCKET ON CRT PWB
May 22, 2009 | Hitachi 43FDX15B 43" Rear Projection...
Hitachi 43FDX15B 43 in
You can try replacing the convergence IC's ...should cost you about 350-400$..Its your choice at the end of the day,,It could also be that the lamp is blown and you will need it to be replaced. Best option..call a tech and get a quote and then decide..
Jul 19, 2008 | Hitachi 43FDX15B 43" Rear Projection...
Hitachi 43FDX15B Convergence Failed
You will need to order part no. CZ01341. This is the output ic. There are 2 of them, replaced them both. The numbers that are printed on the old part will not match the new part, do NOT take this to hart. It is a modification that you are putting in. You should be able to do this your self. I would charge 350.00. The set is not worth much, not working. Maybe 100.00
Jun 05, 2008 | Hitachi 51F510 51" Rear Projection...
Power light stay on
Sounds like you may have a sticking Relay S901 on the power board. Tapping the Relay may Make The Light Go On And Off. The relay part number is FJ00142 if you can find someone to work on the set for you as it would involve soldering in the new part. The number on the relay may be ALKS329 with the former part number being the Hitachi Part number.
Aug 20, 2007 | Hitachi 43FDX15B 43" Rear Projection...
Hitachi 43FDX15B 43" Rear Projection Television Logo
80 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
