Question about IBM ThinkPad T20 2647 Notebook
Hard drive not installed if os not found re-install hit any key to exit
I switch my laptop on and it says hard drive not installed if os not found re-install hard drive hit any key to exit
  • Moh Tolentino
    Moh Tolentino May 11, 2010
    For me to further solve your concern, please answer the following questions:
    • When did this problem start?
    • Where there any changes made before this began?
    • If so, what where those changes?
    This usually happens if the computer does not detect the hard drive of your computer, your laptop might have been shaken which made it disconnect the connection to your hard drive.
  • 4 Answers
This usually happens when your BIOS fails to recognise your hard disk or else it is not enabled in BIOS or else there is a loose connection which makes your computer unable to detect the hard disk, You could try and use your BIOS to check if your hard disk is detected. In case it is not, then check the connections of your hard disk or ask your technician to do that
Posted on Jun 02, 2009
Why my acer aspire say system not found
The system cannot detect the hard disk drive. Before you start up, re insert the hard disk. Remove the memory card and clean it with soft cloth or tissue paper. After doing these..Start up your computer and see the results. If nothing happens, restart your laptop, hit F12 key & set the hard disk drive to first boot device then press the Enter key. wait till the OS comes up.
Aug 19, 2014 | Acer Aspire 4720 Notebook
Operating system not found
No, you won't get the OS to automatically install on the new drive. The OS is not stored in the BIOS chip (or a similar permanent location inside the computer). You will need an OS install disc (not an upgrade disc). Windows Vista Home Premium or Basic was the original OS on most of the Acer Aspire 4530 series. Acer appears to have drivers for the system for XP through Windows 7 to get the hardware to work. You will need to have these most of these ready before you install your OS. Put them on a flash drive or optical disc using another computer.
This computer may work with Unix as well. However, driver issues may be a factor. You can try most versions of Unix from a CD (LiveCD) to test it out.
When you get a new hard drive, install it into the laptop. Then put the OS disk in the optical drive bay. Boot to the optical drive. Follow the directions for formatting the hard drive and installing the OS. (Of course you will need a drive that doesn't have a higher capacity than the BIOS supports.) The motherboard needs to recognize the drive.
If you find a member of a Windows User Group, they may have Windows install discs available. The license number on the label of your computer will probably work as your license key. (The key for a computer like this is locked to the CPU and motherboard; unless someone upgraded the OS to Windows 7 or downgraded to XP, this should be the key you need.) Use the information on the label to obtain the correct version of Vista (the Basic install disc may not work for installing Home Premium). You also need to match the 32-bit or 64-bit install disc (and the service pack you need).
I hope this helps.
(An Acer recovery disc wouldn't help you. Most of those are completely locked to the original hardware (including hard drive) and look for the recovery partition that was on that hard drive.)
Dec 05, 2012 | Computers & Internet
I have a Dell vostro 3700 purchased only a few months ago. The hard drive crashed. After replacing the internal hard drive with new seagate, 750GB 7200rpm, how do I reinstall the OS? I turned off the...
Hi.
Pop the install DVD into the drive and restart your laptop. When you see the Dell logo hit the F2 key to get you into the BIOS. Look for boot options in the list and set the DVD/CD drive as the first boot device. Save the changes and exit the BIOS.
The laptop should restart and boot form the DVD/CD drive so you can install the operating system.
Good luck and regards.
Sep 05, 2011 | Dell Vostro 3700 Laptop Computer PC...
Unamountable boot volume issue. The laptop just died and when i power up it gives unamountable boot volume speil
Not sure what OS you are using so sending you the instructions for XP.
The problem is with a corrupt bunch of files in the Master boot record such as Config.sys and autoexec.bat etc.
Try this first
1. Insert your XP installation disk into an optical drive and boot up your computer.
2. When you see a welcome screen, hit the R key on your keyboard. This will enter you into recovery mode with a DOS prompt.
3. Now type chkdsk /p and hit Enter. This will launch a utility which will check for errors on your hard drive.
4. After the process is done, type fixboot and hit Enter to repair any damaged boot files which may have become corrupted. When asked to say yes or no, type the Y key on your keyboard.
5. Type exit and press the Enter key to reboot your computer.
If that fails, then:
Boot from the Windows CD rom drive (change boot order in Bios)
let the install get to where it looks for Windows installation and type enter to FIX the installation
If that fails then:
Pull your hard drive out of the laptop, connect to another computer as aslave and pull off all your data that you want to keep.
Reinstall the drive in the laptop, boot to windows CD and wipe the hard drive and do a fresh install, reimport the files you rescued earlier
If you STILL have problems, it is a failing hard drive and will need replacing (suggest you back up data even if step one works)
Feb 10, 2011 | HP Pavilion dv1000 Notebook
How do i erase a hard drive with a os on it i need to install a hard drive on a pc but the os on messess up booting when i plug it it
press DEL key as soon as the PC is booting. it will enter BIOS, find "Boot priority" and change the "First Boot Device" to CDROM. then save and exit.
If you are installing Windows, watch out for the message "Press any key to boot from CD....." then follow on-screen instructions.
If you are installing Linux, it will boot to CD drive when it found the Linux boot CD.
Oct 15, 2009 | Computers & Internet
Toshiba Tecra Notebook
INstall the hard drive, if the hard drive came with a cd, put the cd in the drive and boot the laptop. When you see it say "boot from cd hit any key" do so and follow the prompts. This software will "initialize" the disc and install for the first time. Once the disc is "officially" installed take the hard drive disc out of the drive and replace it with Operating Disc. Reboot the machine and again look for the "Boot from CD Hit any Key" hit any key and let the system load windows. You only have to hit the key one time when it says "hit any key" even if during the windows install, the system may reboot but it still may need the disc in the drive, if you see the heading "boot from cd hit any key" dont hit any key any more....just let windows finish loading. When windows finally reboots, sometimes up to three times, then you can take the disc out of the drive or take it out if the operating system instructs you to. Good luck, ParrotHead PC Repair
Sep 04, 2009 | Toshiba Tecra 500CDT Notebook
Want to install operating system on wiped out hard drive
You need a bootable copy of the OS (Some are only repair copies) and a copy of the Motherboard Driver disk
Switch on the machine hit F2 or whatever key it tells you to hit to get into Bios
Go to Boot , change 1st Boot to CD, save and exit
Restart the machine with the OS disk in and follow the instructions including the bit about formatting the drive again
Whan it is all done load up the Motherboard disk and update that
Jul 10, 2009 | Microsoft Windows XP Home Edition with...
Recovery console key convination for a laptop?
Hi there.
Restart the PC and hit F2 while it boots up, this will take you into the bios, look for boot devices and set the CD to the first boot device, save the changes and exit the bios. The compuer will restart and boot from the CD drive.
Once the OS has installed go back into the bios and set the HDD (hard drive) to first boot device.
Good luck and thanks for using FixYa!!
May 11, 2009 | Toshiba Satellite A105 Notebook
Try booting from the Operating system disc, into the recovery console.
check when booted, where your hard drive is.
if not try safe mode, reboot tapping F8 while booting,
choose safe mode from list, check for hard drive when booted in places like,
My computer, device manager, anywhere on the desktop if you get there,
If your savvy, ESD kit, check connections to hard drive, swap out cables if poss.
it's on IDE so no SCSI driver issues..
But if powered up, and cannot be located on desktop after multiple checks,
That's a possible hard drive failure.
Regards.
Apr 11, 2009 | IBM ThinkPad T20 Notebook
OS installation.
is the old hard drive still working if it is you can clone the two
Jan 20, 2008 | Dell Latitude C640 Notebook
IBM ThinkPad T20 2647 Notebook Logo
330 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
