Question about Tomtom GO 910
Battery indictes low and turns off
My GO910, battery indicates low and turns off, this is even when the green light on the front of the unit remains on.  These happens on both docking stations.  So unit is plugged into car socket, green light is on, unit will start up remain on for about 5-10 secs then battery indicator flashers and unit turns off. Green light on unit remains on???  What do you think?? Unit is 6 months old.
Re: Battery indictes low and turns off
I replaced the battery on my TomTom 910 and still no improvement so eventually sprayed the contacts with switch cleaner. Now, no problem. Probably didn't need to replace the battery.
If you unit is outside guarantee then this is worth trying. Might be as well to detach the battery and all other power supplies until the switch cleaner has dried.
Another possible problem is the rubber gromit which forces the contacts to make contact. You could replace this with a bit of rubber from a pencil.
Hope this helps you.
Posted on Jan 19, 2008
  • 55 Answers
Sounds like the rechargeable battery needs replacement, see:
Posted on Oct 23, 2007
0 characters
3 Points
Stange battery performance???? - iPAQ h2200
surely the problem is with the battery ask for a replacement, try to find one which has the same mah with the battery you got along with the phone.
Apr 15, 2009 | HP iPAQ H2210 Pocket PC
Green light flashing on blackberry pearl
This just means that the phone has coverage. under options and then screen/keyboard, you cna turn it off by where it says LED coverage indicator.
Apr 10, 2009 | RIM BlackBerry Pearl 8100
Why does the light blink green?
follow these steps
1) click on settings
2)click options
3)scroll screen/keyboard
4)select off for LED coverage ind
This simply is an indication you are in the coverage area.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 13, 2009 | RIM BlackBerry Pearl 8100
Charging indicator stays red the USB cable plugged in to a powered PC? Could be cable or battery issue. Red light means that the battery is very low on juice. Return it to where you got it from if you can't solve it on your own.
you want a repair service
Oct 16, 2008 | HP iPAQ hw6965 Smartphone
Battery charge indicator seems faulty.
Solved own problem. Bad conection between pcb and battery contact pins. Reheat each battery pin on the pcb carefully until solder reflow occurs then remove heat. PDA now repaired
Aug 03, 2008 | Fujitsu Pocket Loox 410 Pocket PC
My mobile is dead
I just had this happen to me yesterday. I fought with my phone for about 3 hours removing the battery and trying to restart it. It would take about 5 minutes for it to finally boot and once it did the touch screen would not work. So I did a hard boot and within 5 minutes my phone was back to normal. I lost all my contacts but I just did a restore with the backup software. To do a hard boot hold down the red and green buttons on the front of the phone and push the reset button on the bottom of the phone with the stylus. The reset button is on the right side of the power/usb plug. As I said my phone was back to normal in just a few minutes.
Jul 16, 2008 | HTC Touch P3450 Smartphone
Axim x3 power switch light flashes green constantly
as far as I remember its the wireless working, if you press the button on the far right u can disable the wireless..this will turn off the flashing green light.
May 30, 2008 | Dell Axim X3 Pocket PC
TomTom go 510
Feb 20, 2008 | Tomtom GO 910
Will not power up
Had same problem with my GO910 unit, after it was about 6 months old. Contacted TomTom and sent unit back. They said that they are aware of the problem. They sent me back a new GO 720 with 2008 maps as they said they could not fix the problem in the 910. and they were not importing anymore 910 into Australia.
Dec 26, 2007 | Tomtom GO 910
Tomtom GO 910 Logo
1,229 people viewed this question
Top Tomtom PDAs Experts
Are you a Tomtom PDA Expert? Answer questions, earn points and help others
