Question about Microwave Ovens
GE Profile over the range microwave
The microwave is several years old, used several times per week.  All of a sudden there is a "grating" sound.
  • 4 more comments
  • Anonymous Nov 06, 2007
    turntable makes a grinding sound when turing
  • Anonymous Nov 29, 2007
    I have the same problem - grinding sound associated with microwave motor running.
  • SuziPhoto Jan 03, 2008
    Same problem here.  I have a GE Profile Spacemaker XL 1800.  It makes a grinding noise.  i think it's the motor.  If we hit the "turntable" button to turn off the turntable, the noise stops.  This has to be done EVERY TIME the microwave is used.
    Any advice on how to fix this without having to call a service technician?
  • spacemaker Jan 04, 2008
    hi i have the EXACT same problem as the previous person..
    i have a GE space maker the model number is JVM1860SD 002
    Any idea on how to fix it?
    Thanks! : )
  • pegj Jul 24, 2008
    Or microwave has been doing the same thing for about 2 years (2001 model) I thought it was just ours until we went to a rented beach house with the same model and it was doing the same grinding noise as well.
  • Anonymous May 13, 2009
    My GE Profile microwave convection oven is making a loud grating/crunching noise when it microwaves. Is it safe to use? How can I fix this problem?
I have a GE space maker the model number is JVM1860.
Same grinding sound when truntable is turning. Stops when you turn turntable off.
Can this be fixed by a layman?
Posted on Jun 10, 2008
  • Microwave Ovens Master
  • 9,098 Answers
It might be better to post this in the GE section, but I'll be happy to answer it here, too.
I would suspect a bad magnetron or high-voltage transformer, but it may be the turntable motor or an arcing stirrer.
If you can post back with the model number and a bit more detail on when and how it happens, we may be able to help you better.
Posted on Nov 05, 2007
Why does my ge profile spacemaker not heat up
There maybe so many factors. How old is your microwave. From your description, I believe you may have to change your Magnetron. Maybe the magnet is cracked.
Jul 28, 2014 | GE Profile Spacemaker Over-the-Range...
GE micro died
The main fuse is the probable cause, magnetron, "heart of the microwave oven" the inverter board, "if 7 years old or less" and the keypad control board can be a factor.
Apr 21, 2012 | GE Profile Spacemaker Over-the-Range...
I have GE Profile microwave model PVM1870SM1SS and last week while running, suddently it shut off. There is no power, display buttons and stopped running. Please advise.
From the description a major part has failed, the magnetron is suspect because it suddenly shut down in cycle, if the unit is less than 7 years old it probably has a inverter board and tends to fail, also there is the possibility the keypad control board has stopped working. The microwave in my opinion is worth getting checked out and repaired, but it will be expensive.
Apr 03, 2012 | GE Profile Spacemaker 1.8 Cu. Ft....
My3yr old GE profile microwave doesn't warm up
from what you are discribing , I would be looking at the high voltage transformer
Feb 13, 2010 | GE Profile Over-the-Range Microwave
GE Profile Performance Convection/Microwave Problem Heating
Either magnetron, capacitor, diode pack or transformer has failed causing a fuse to blow.
Jul 13, 2017 | General Electric Microwave Oven
GE Profile Spacemaker XL JMV1460 Turns On by Itself
Sounds like there is a stray piece of wire or other metal floating around inside the case. Remove the cover and any breakables in the microwave (the power cord is unplugged for this), turn it upside down over a table and shake it, pound the bottom, and shake it some more--likely the offending piece will drop out onto the table. If so, put it back together and whack it to see if that fixed the problem (cord plugged back in). This process can be repeated.
Jul 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Cleaning ge profile convection microwave
HI HERE THE STEPS TO DISASSEMBLEA gas range cabinet comes apart very easily. Here's how:
Step 1: Take out the screws that hold the panels, and pull off the control knobs. On the control panel the knobs are friction-fit; pull them straight off. Some knobs may have setscrews in the base of the knobs; back out these screws using a screwdriver or Allen wrench and pull off the knobs.
Step 2: Remove the back service panel on the control panel by backing out a series of screws around the edge of the panel. To remove the front panel, take off the control knobs and remove a series of mounting screws that hold the decorative panel to the frame. These screws may be hidden by molding or trim; pry off the molding or trim with a screwdriver, or take out several screws.
Step 3: To gain access to the burner assemblies, remove the burner grates and then the top of the range. The entire range top should either lift up and off the range or open up and back on hinges. The oven door can usually be removed by pulling it straight up off the hinges on both sides of the door. Some hinges have a latch that must be unlocked before the door can be removed.
Step 4: If the surface light of the range burns out, remove retaining screws and panels as necessary to gain access to the bulb. Replace the burned-out bulb with a new one of the same type and wattage; check the ends of the old bulb for this information. Then replace any retaining panels.
Step 5: If the oven light burns out, unscrew it and remove it from the oven. Replace the burned-out bulb with a new one of the same wattage, made for oven use.
PLEASE RATE IT.........................
Nov 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Over the range Microwave trouble
It is a door switch problem of some sort.  I have two Sharp R-1611 units that do the same thing.  The light and fan come on, but not the heat, thank goodness.
I am going to replace it since the plastic for the case and door is cracked in numerous places.  I have spent several hours researching microwaves online have not a single clue what to replace the Sharp with.  Seems like every vendor has very good units and very bad units.  I guess you just pay your money and take your chances.
Oct 31, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
427 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
