Question about Garmin StreetPilot c550 GPS Receiver
Memory full not enough internal memory to update maps
5 Suggested Answers
SOURCE:
SOURCE: Downloading new maps
you need to buy a memory card the unit wont take that much info.
Posted on Sep 14, 2008
sharcnet
  • 2130 Answers
SOURCE: Tried to update nuvi660fm. Message came up "not
Did the SD card perhaps have your map on it? Please see this link on how to free up memory space on your Nuvi.
http://www.sharc.net/discus/messages/6/367.html?1278285409
- Jim
Posted on Jul 21, 2010
  • 902 Answers
SOURCE: cannot update maps. Message
have you tried adding a 2gb sd card to your garmin?
Posted on Mar 27, 2011
  • 1514 Answers
SOURCE: I am trying to update
The map takes approx 3 Gb of storage space so you need a 4 Gb memory card. When you download the map to your computer run it and install part of the map to your satnav. After this click the start button (bottom left of your computer screen) and find the menu folder "Garmin". In the Garmin folder you'll find "Mapinstall" With the memory card in your satnav, and the satnav connected to your computer run mapinstall being sure to select the memory card as the destination. (It will be by default your satnav not your memory card). When the installation is complete the satnav will automatically switch to the map on your memory card when needed. You'll find detailed instructions of how to prepare the memory card and install the map on it at http://www.fixya.com/support/r5628920-update_garmin_satnav_maps
Posted on May 02, 2011
Need to know how i update the maps card for it
The latest version of Garmin Express provides the ability to install a map update directly to an SD card.
The SD card installation option will only appear when updating a compatible device that does not have sufficient internal memory for the largest allowable map region. When using the SD card installation option, critical files are loaded to the SD card so it must remain in the device after the update to ensure full functionality. For the largest size SD card a device can use, refer to: What is the largest size Secure Digital (SD) card that an automotive device can accept?
The SD card support during the map update will only function with up-to-date software. It may be necessary to update the device's software with Garmin Express prior to updating the maps. These devices do not support the SD card option:
  • Nissan 700
  • nuvi 295
  • nuvi 300 series
  • nuvi 500 series
  • nuvi 600 series
  • nuvi 800 series
  • nuvi 805 series
  • nuvi 5000
  • StreetPilot series
  • zumo 450
  • zumo 550
  • zumo 665
For devices that do not support using the SD card with the map update application, any maps that do not fit in the internal memory can be installed to the SD card manually, using these instructions:
Try the link.it may help.Under support.
Garmin United States Home
Nov 09, 2015 | GPS
How to replace vvt actuator on mazda cx7
with ( MyDriveConnect ) the system make the update
and ask you to chosse with coponent you want to remouve !
after you update you select the part of the map you want ,
the new thing you don't have the complete map only 3/4 of the map ,
the say with all new town and road the gps dont have not enough memory to have the complete map of the canada /usa and mexico after the update you select the part of the map you want ,
and now the memory of the gps is half full ,
and now you have space to add : voice , image , and other things
Jul 22, 2014 | Mazda CX7 Cars & Trucks
Panasonic dvd recorder DMR-E55GN
with ( MyDriveConnect ) the system make the update and ask you to chosse with coponent you want to remouve ! after you update you select the part of the map you want , the new thing you don't have the complete map only 3/4 of the map , the say with all new town and road the gps dont have not enough memory to have the complete map of the canada /usa and mexico after the update you select the part of the map you want , and now the memory of the gps is half full , and now you have space to add : voice , image , and other things
Jul 22, 2014 | Panasonic DMR-E55 DVD Recorder
How do i update my tomtom when there is not enough memory
Jul 12, 2014 | Tomtom Go 2535 TM WTE GPS Receiver
I bought a lifetime update from Garmin a few years ago but now my nuvi 270 tells me that I don't have enough memory to install the latest maps and that I must choose only certain regions. I have an 8Gb...
The internal memory of the nuvi is full. Some maps will need to be delete before any new maps can be added. Typically, the map in the nuvi is named GMAPPROM.IMG and a map installed to an SD (or SDHC) memory card is named GMAPSUPP.IMG.
1) Remove the SD card from the memory slot
2) Connect the nuvi to the computer via USB cable.
3) Open the nuvi drive.
4) Locate and delete the GMAPPROM.IMG (or GSUPPROM.IMG) file(s). Optionally copy (instead of deleting) them to your hard drive in case there is a problem wit the new map file(s).
5) Empty the Recycle Bin.
6) Retry the map update of the nuvi.
This method will take some time to perform depending on how many map segments you are sending to the nuvi. Transferring the entire map can take over an hour. A quicker way is to send the maps to the SDHC card directly by inserting the card into a card reader. This eleminates the slow Garmin card reader from the equation and transfers are done in a fraction of the time. No maps will be on the nuvi - they will all be on the memory card instead. To update the SD or SDHC card, do this:
1) Repeat steps 1 thru 5 above. This removes the maps files from the nuvi.
2) Disconnect the nuvi from the computer.
3) Connect a card reader to the computer.
4) Insert the SD or SDHC card into the reader.
5) Locate and delete the GMAPPROM.IMG (or GSUPPROM.IMG) file(s). Optionally copy (instead of deleting) them to your hard drive in case there is a problem wit the new map file(s).
6) Update the map to the SD or SDHC card.
When either method is employed, only one map file set will result. GMAPPROM.IMG or GMAPSUPP.IMG is the name of this file set. You should ensure / change the name to GMAPPROM.IMG. Any subsequent file set added should be named GMAPSUPP.IMG.
I hope this helps & good luck! Please rate my reply - thanks.
Jun 27, 2011 | Garmin nuvi 200W GPS Receiver
TomTom Go 720 map activation
No Maps Found usually means the Application on your internal memory is not the latest one, or the map did not download correctly.
Make sure when you select internal memory when updating your device on home, that you update the application as well.
V8351 should be the latest application for your device.
Oct 04, 2009 | Tomtom GO 720 GPS Receiver
Need a manual or instructions how to operate it
experimental status
ZEN mozaic player 2 GB
firmware 1.03
ZEN attached to USB 2.0
Windows XP SP2
Message "do not disconnect"
ZEN is not being recognized
Check ZEN memory setting
Memory ZEN is set to 0 in MENU>Etras>removable disk
Memory ZEN should be changed to maximum 1.5 GB
ZEN is recognized now
ZEN is ready to do the format command
ZEN can be written to for a maximum of 0.5 GB [internal memory !]
ALERT ! This 0.5 GB is the internal memory
The files written to the internal memory will be erased after
disconnecting !
access status
NO ACCES TO MY ZEN ?
1) Get access to ZEN by setting disk memory to maximum
2) ZEN should be recognized now
format status
1) FORMAT the disk
After formatting !
SET BACK YOUR disk memory capacity to zero [ 0 ]
for fully recovering the disk capacity
files presence status
FILES NOT PRESENT AFTER DISCONNECTING ?
- When set to zero you can use the full memory for
writing files to the player !
- When keeping the memory set to maximum you're using
the internal memory and written files are not saved
after disconnecting
updating + files presence status
UPDATING FIRMWARE ZEN MOZAIC = MAKING STANDARD MAPS
1) download the firmware that is suited for your computer
Operating System and your type of player from "CREATIVE"
2) Connect player to USB 2.0
and update with the firmware-update
3) Wait until the update is fully completed
4) After the update disconnect the player
5) Connect to USB 2.0 again
6) Check for the presence of the STANDARD MAPS for Music,
Pictures and Video
7) Files can be written into the STANDARD MAPS
8) Written files should be present after disconnecting
9) Files ready for mobile playing on ZEN mozaic now
CREATIVE support site for fimware / software / userguide
SUPPORT FOR ZEN MOZAIC ON THE INTERNET
http://support.creative.com/Products/ProductDetails.aspx?catID=213&CatName=MP3+Players&subCatID=214&subCatName=ZEN&prodID=17897&prodName=ZEN+Mozaic
May 10, 2009 | Creative Labs Creative Technology Zen MP3...
Sep 13, 2008 | Garmin StreetPilot C330 GPS Receiver
Free map updates
Unfortunately, they don't offer free map updates. You can purchase map updates for around $70, but they won't update them for free.
Also, the base model of the C330 does not have enough memory to store the entire 2008 Map Update. Unless you have more memory than it came with stock, you may have to choose which maps to include. For instance, in North America you have to choose between US and Canada - there's insufficient memory to hold both.
-John
Feb 06, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot c550 GPS Receiver Logo
24 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
