Question about Kenmore Oasis 27042 Top Load Washer
Kenmore Oasis Ld code
I am getting a Ld code during the rinse cycle I have the same problem...."LD code is long drain one of 2 things the drain pump is frozen and need to be replaced or there is somthing in the pump." I have done this. Pulled the pump off & tried to clean it out but it was free of any clogs. I then purchase a brand new pump put it on and I am still getting the same error. Any other ideas?
  • 15,935 Answers
“F21” (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question !!!!
Posted on Sep 11, 2010
Kenmore Oasis Washer won't drain. "Ld" code during
Hi
Error code LD means long drain. This error appears when the washer takes more than 5 minutes to pump out the water till point where pressure switch resets. To resolve the issue you'll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn't work then you'll need to check the connections of the drain pump, check the electrical connections with a multimeter. Hope this helps... Please post back for more information.
Daniel
Nov 26, 2010 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Machine stops during cycle
"LD" stands for long drain meaning that the pump could be bad or that it just needs to be cleaned out.
Jul 22, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Oasis is beeping with an error code of Ld
LD code is long drain,one of two things the drain pump is frozen and need to be replaced or there is somthing in the pump.Pull the washer away from the wall a bit and get a bunch of towels.Lean the washer back against the wall towards the middle in the back you will see the pump take it apart and find the clog.
Apr 10, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
We have a Kenmore Oasis HE.It stopped during the rinse cycle
May 16, 2009 | Kenmore Oasis HE 27082 Top Load Washer
LD code is long drain one of 2 things the drain pump is frozen and need to be replaced or there is somthing in the pump. Pull the washer a way from the wall a bit and get a bunch of towels. Lean the washer back against the wall towards the middle in the back you will see the pump take it apart and find the clog.
it can be assessed through the bottom.
May 06, 2009 | Kenmore Oasis 27042 Top Load Washer
Oasis washer has Ld CODE runs will not drain.
May 03, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Ld code on any cycle
Feb 21, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Washing Machine LD Fault
mpratt, check to make sure there is no restriction in your pressure switch tube.it could also be kinked.
Oct 22, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Ld signal
ld means long drain, could be a bad pump or something stuck in it.also if drain hose is too deep in the drain a syphone can cause this
Jun 22, 2008 | Kenmore Oasis 27042 Top Load Washer
Ld error code on kenmore oasis
ld stands for long drain. If you can remove the bottom panel you will see the pump in the middle front which has a clean out you can unscrew. There is usually obstructions in the clean out such as a sock causing the long drain. When u remove the clean out cover alot of water will come out so a wet vac comes in handy.
Apr 15, 2008 | Kenmore Oasis 27042 Top Load Washer
Kenmore Oasis 27042 Top Load Washer Logo
638 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
