Sanyo isn't that great of a manufacturer.. I had a microwave from them a few years back that did the same thing.. The wiring inside the microwave is shot.. if you were to open it up, you'd probably see some burnt wires from a short. If you use the microwave over a range, it may be because of grease build-up...
anyhow, its better that you invest in a new microwave, rather than fix it. It will be much more cost efficient
there is a "L" showing on the display window and the microwave will not start.When you try...
(More)
there is a "L" showing on the display window and the microwave will not start.When you try to turn the microwave on it just beeps and an "E" comes up on the display window.
I have a jet3ulta that ran fine and then it would charge allthe lights up to green andthen it...
(More)
I have a jet3ulta that ran fine and then it would charge allthe lights up to green andthen it started losing its charge inabout3 hours.one day I turned it on andthelightsonthecontrolarmflashbutthechairwill notmove
It sounds like the microwave is 'sparking' (buzz, buzz, buzz) inside. When I turn it off and open...
(More)
It sounds like the microwave is 'sparking' (buzz, buzz, buzz) inside. When I turn it off and open door, small amount of smoke is inside. It is a Sharp model R-4W36 or R4W38 that I bought in 1996. Is the the 'meg tube' shorting out?
lights on no heat generated. When trying to heat an object, the light comes on, the table turns BUT...
(More)
lights on no heat generated. When trying to heat an object, the light comes on, the table turns BUT no heat is generated
I have a fuller commercial upright vacuun. It will not turn on. I know the switch is good but thats...
(More)
I have a fuller commercial upright vacuun. It will not turn on. I know the switch is good but thats it. Any other suggestions would be great. Thank you.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
