Question about Compaq Presario 5000US (D70008-261) PC Desktop
I have a old compaq modle 5000 us the Monitor is a FS 740 everytime I start the computor it goes on stand by nd the erro message says Video input not detected I tried unpluging and restarting but it keeps doing it whats wrong
Make sure ur drive is fat 32
Posted on Aug 21, 2011
    Problem Solver:
  • 19 Answers
It could be alot of things. Bad RAM, Processor, Motherboard, Videocard.
It could just need to have the BIOS reset.
Posted on Jun 02, 2009
When i shutdown my computer after that when lcd goes black then at that time a message shown on the black screen that "no input signal" and also glows little bit light with this message continuously.
Your monitor may have an option to set it as "manual" or "auto". If set in manual, you will have to turn off the monitor power switch each time. If it has the "auto" setting , it should shut off or "go to sleep" when it detects no input signal.
Oct 18, 2014 | Samsung SyncMaster 713BM 17" LCD Monitor
Bought HP Compaq monitor with desktop pc and hooked the monitor with old computer and message dispalys input not support on the screen
This means that the Operation System is not equipped with the appropriate drivers for displaying any images on the monitor. You will need to find either a different monitor, or upgrade the video card for the computer.
Please let me know if you need further assistance.
carsandcomps
Aug 12, 2011 | Compaq Computers & Internet
My monitor has kicked into sleep mode and won't "wake up".
Unplug all the Cables from Compaq Presario 5103 CL and leave the Keyboard, mouse and monitor cable pluged in.
Now make sure the power cable of the monitor should be pluged in and the power cable of the tower should be pluged in.
Now to check if the montor is fine just unplug the video cable only which will show no input signal on the screen. If it shows this signal the monitor is fine. Plug back in the video cable.
If the monitor is going to sleep mode it might be possible that the old computer ( Compaq Presario 5103 CL ) is in stand by mode. hit any key on the keyboard and it should come back .
If it is not in the stand by mode then do one thing. Check the same monitor with the new computer. If it is working. Perfect ..!
Do one thing now ..!
Unplug all the cables from your old system and then press the power button for 30 sec and let it go. Now plug the keyboard, mouse and the monitor try again.
If it works Perfect. If not ..!
Then you need to open the tower and check on the processor FAN is it running..? If its not running you will not get the display as the fan is responsible for the display on the screen. Otherwise...!
Check the Tower possibly the Tower is not getting the power.
Try these steps and let me know If it works
May 04, 2010 | Compaq Presario 5000 PC Desktop
My presario using windows xp screen goes greena nd says warning dumping memory onto disk,,and starts counting down,,,cut power to stop amnd the computer will reboot and work r=for a few minutes and then...
Get a new computer, i believe its a virus of somesort. destroying your internal memory cache. as for the green screen thats usually a video problem. or the virus and the green screen go hand in hand, sorry bud,
Dec 30, 2009 | Compaq Presario 5000 PC Desktop
"out of frequency range" message nothing works
Try booting to the ENABLE VGA mode off the F8 menu if you can get to the desktop and then you can go to display properties and see if you can reset the resolution to normal. If no go, try updating the video driver
Oct 02, 2009 | HP Compaq FS 7550 17 in.CRT Conventional...
HP pavilion win 2000 pro. x86family 6 model.intel 670 mhz. stand alone storage and word only (not this computer) will not start up. monitor message "please check video cable connection" monitor o.k.on...
first step to do check the video card 2nd check the memory inside the computer. remove the memory card inside the pc. and clean it to the tissue.if done put to the same position. and pls try to your pc.............
Sep 26, 2009 | Computers & Internet
Did you fix your Compaq 1220?
Any time you have a orange light . The monitor or video card can be at fault. First check the monitor. Turn it on and see if it goes from green to amber. Check all monitor cable connections. to make sure the all 15 pins are there . If monitor displays a message that check video signal most likely video card is the problem. Make sure you have the cable connection plugged in the back of the computer into the video card. Usually a picture of a monitor. Then afterwards turn the monitor on first then the computer. If you do the other way around then the video card most likely will not engage.
May 07, 2008 | Compaq Presario 5000 PC Desktop
Input Signal Out of Range
I have been having the same problem with my hpvs17 monitor when i start to use my web browser on linux distros. Now, for the next few days i am going to try my system on a regular crt monitor. if the monitor does not crash, than i will have to say that the hpvs17 monitor has a defect.It seems that when i go online, while i am in the middle of searching something, the monitor just shuts off and i get "input signal out of range".
Jan 31, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Vison 19
1st you want to do check the video card
Jan 08, 2008 | Gateway FPD2275W LCD Monitor
Compaq Presario 5000US (D70008-261) PC Desktop Logo
226 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
