Question about Sharp LL173C 17" Flat Panel LCD Monitor
Power button won't turn off monitor
The button acts normal and clicks but nothing happens. Been advised to clean control panel circuit or replace the tact switch? How do I clean the control panel circuit? and what is a tact switch? Also the Adjust lock will not come off.....
  • 1 more comment
  • Anonymous Nov 10, 2007
    I'm having the same issue, except i can't turn mine on. I noticed the monitor turning off every few seconds and coming back on, like it was possessed. I turned it off and now it won't come back on.
  • Anonymous Dec 01, 2007
    What's up with these flat panel monitors? I have 2 with the same problem... One is a BenQ and the other is an Acer. Both are just over a year old. Maybe the meantime between failure is kicking in already?.....
  • babemama Jan 08, 2009
    my monitor's power button won't work. every time i press it it shows a box saying "power button locked*
    help please.
We have the same problem our computor went on the blink for a while and we put more memory in the computor and now the monitor wont turn off with the button if anyone has a solution to this could they pleas tell me thanks
Posted on Aug 18, 2010
Well, I noticed this after I installed win xp sp3. My monitor won't turn offwhen I click the button. I have to set my power setting to a certain timeframe then require a relogin but the monitor just won't turn off otherwise.
Posted on Mar 22, 2008
  • waz-up Apr 10, 2008
    I uninstalled WinXP sp3 and my monitor button works now. So check and see if your auto update installed xp sp3. Hope this helps you also.
I bought a cordless mouse Fha 3410. When I let down the left click, it acts like double click, so do not let me select objects. I need to solve this problem, since I can not work normally in any...
Hi..
Go to - Devices and Printers in Control Panel
Go to - Mouse properties and check for the Doubel click speed.. See to that it is not set to the max.
May 30, 2011 | HP Wireless Optical Mouse
When i switched on the tv it looks like normal. but after a few minutes the tv shotdown .and when i tried to switched on again the tv, standby power is there but when i press the channel button, the...
It sounds like you may have faulty tact switches on the front control panel that are acting intermittently. If one of the switches is defective it can cause all kinds of erratic behaviour.
Nov 29, 2009 | Sanyo DS20930 20" TV
I have no control over the channel selection; the channel keeps changing and I'm powerless to stop it. The issue is not with the remote; the same thing happens if I attempt to tune to a channel manually on...
The problem is likely with your front panel control buttons - the CH up button (tact switch) is stuck on (shorted or changed value). In order to temporarily correct the problem remove the Ch up switch that is located on the front panel control board - it would have to be unsoldered- and then when one is available replace the "tact" switch.
Sep 27, 2009 | GE 31GT740 31" TV
Sound volume fluctuates
sounnd like your power supply
check you cap,s in power boulg cap.s
Aug 12, 2009 | Polaroid FLM-2632 Television
Just won't work!!
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
I would also advise to check the door switch as well. make sure the wires are connected to the switch and it is working. replace if found to be faulty.
Check the control as well. if the control is malfunctioning as you stated, this will be the logical solution here. replace the control board.
May 29, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
I just finished cleaning my swimming pool and tried to switch on the water pump but nothing happened.Then i noticed that the red trip light on the control panel was on. What do i have to do to fix this?
hi! there,
open the control panel,besure to close circuit breaker first,on control panel there is a over load protection relay,push the reset lever,then close the control panel,switch on the breaker and push the black push button to start the pump,observed if trip off again,check the cathridge filter,replace filter because the differential pressure
was exceeded the set up on pressure switch.have a nice day,don't forget to rate me,thank's
Apr 23, 2009 | Home
Problem is made by switches which are bad quality, you have to take your monitor to the nearest samsung service center or if you want you can change this switches by yourself. You can find them in conrad stores named phap3363 and art.nr: 700310 - 62.
Best regards
Dec 30, 2007 | Samsung SyncMaster 720N Monitor
How can i get my tv to stop automatically changing to menu screen?
slapshot,
What you have there could be one of three possibilities. Micro, eprom or tact switches... Tact switches are the small contact switches behind the buttons you depress to turn the volume up and down or change the channel. Sometimes these small switches can become contaminated or breakdown due to corrosion. What we call in the industry a windex syndrom, because the older crts on some models had the swiches exposed just below the lower ridge of the cry where when cleaning the screen windex could drip down onto the switch and cause the corrosion to begin.
Eprom is another likely suspect. This Ic is responsible for storing an array of information including customer settings and other logics convert what the eprom stores into electronic pulses for any number of fuctions. For example press the volume down on your Tv and the eprom has the information to show you the volume bar, the level the volume bar was last set at and the increments at which you are reducing it realtime.
The Micro is another possibility. It acts like a traffic cop engaging various circuits to do or not do something according to a preset list of conditions. Timers, looking at a particular input or yes even bringing up the menu is tasked through the micro controller Ic or micro for short.
The fact that you can eventually get the unit to operate suggests that something in the logic circuit is failing and will in all likelyhood continue to do so until eventually it doesn't work at all...
Nov 14, 2007 | Televison & Video
Power button won't turn monitor off?
ok,your monitor is in  a very simple problem.clean the control panel circuit of your monitor,or if it is not working replace the tact switch in your monitor.
Oct 18, 2007 | Sharp LL173C 17" Flat Panel LCD Monitor
Sharp LL173C 17" Flat Panel LCD Monitor Logo
879 people viewed this question
Top Sharp Computers & Internet Experts
Tony
Jason Harris
Jason Harris
Ricky Ostrom
Ricky Ostrom
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
