Question about Toshiba 56HMX195 52" HDTV DLP Projection TV
Cable Tv Interference
I recently switched to basic cable ( had all the perks prior) and all the TV's had a clear picture. Now that I have gone to basic cable all of the tv's in the home have a crisp, clear picture except for the master bedroom. I have a semi-clear picture w/light snow. I have tried replacing the ends w/no luck. I even tried to add a splitter to one of the other tv's thinking it was the cable line and still no luck, the tv I spit the signal with was still clear but my tv was the same. I know its not the tv as it was fine before and only approx. of month time span since the ''upgraded cable'' was removed. Also from channels 62-75 it is very distorted. Funny thing this morning, when I turned on the tv (the only one at this time) it was clear for all channels and no interference, bu that lasted only about 5 minutes and it went back to the interference.
Can someone help, there are so many things that can be wrong I dont know where to start. I know that due to finances, i would prefer to try to fix myself before calling in a tech....Thanks for any help!
  • 2 more comments
  • lannh0865 Jun 02, 2009
    This may sound stupid but I assume that a splitter and a coaxial cabel are 2 different things? Someone suggested to get a signal amplifier, is that a good move or just try the coaxial instead or first?
    Oh, I know what your are talking about currently there are so many connections from the main source ( in the garage on the ceiling) that I cant tell which is the line for that tv/room. Last question, someone said that the signal amplifiers from Radio Shack were (1) not that good and (2) if you put an amp on a weak signal it will only worsen the signal. Is that true? It seems at this point I may need to get someone over who may be able to tell where the line is coming from directly and go from there? Thanks a Bunch!
    What is the difference between a weak signal and a poor one. Also if all the TV's were fine before with the digital boxes that came with the service but now you just have basic cable (no boxes) what are the chances that its the signal? Meaning if the signal strenght was fine before and only say 30 days have passed since the switch to basic. Keeping in mind there was no cable service for that 30days and then went to basic.
    Thanks a bunch! I looks I need to find the line/cable and go from there. YOu've shed some light on a few things!
  • 864 Answers
Sounds like the cable signal getting to that TV is just not strong enough.  This could be due to the number of connection and splitters leading to it.  Set it up with a coaxial cable that connects as close to the incoming cable as possible and not split it along the way.
Posted on Jun 02, 2009
  • 1 more comment
  • John Morganti Jun 02, 2009
    Coaxial cable is the black cable that connects to the TV.  A signal amplifier may be necessary if the signal is not strong enough.  Trying a connection that runs directly through coax cable form the cable source to the TV with no splitters or connections along the way may provide a strong enough signal.  If not then you can add an amplifier.
    Turn on the TV and disconnect the cables in the garage one at a time.  When the TV signal goes blank you will know which is the cable that feeds it.  If there are no other TVs or devices fed by that cable then you probably need an amplifier.  I do not have info about Radio Shack amplifiers.  An amplifier will boost a weak signal.  It will not improve a poor signal.
    A poor signal can have snow, etc. and an amplifier will only make it worse.  Cable through a cable box might be digital and it might use enhanced compression techniques that keep the signal from being degraded.
Magnavox tv has intermittent pixelation and snow breaking through on picture on all channels. Have had cable service out twice to replace digital DVR box but still a problem. Brand new HDMI cable too.
If your TV is connected to the cable box with only an HDMI cable, the problem should either the cable company equipment or outside interference. A bad HDMI cable with cause intermittent or continuous complete loss of picture. Try plugging the HDMI cable from the cable box into a different TV (if you can borrow one) then you can prove if the problem is with the TV or the cable equipment. Maybe a neighbor has a ham radio that is causing interference? (They will have a tall antenna at there house, so easy to see.)
Dec 22, 2014 | Magnavox Televison & Video
When I turn on the TV, the picture is fuzzy. After five minutes, the picture is clear but any words are out of focus even the menu for adjustments is out of focus. The convergence for red is clear but...
Below are some troubleshooting tips for a TV that has a fuzzy or blurry picture;
If your Plasma or LCD TV picture is blurry or fuzzy there are several things that may be causing the problem. It's worth running through the following list before seeking service. You may find yourself saving the full cost of a TV repair.
Make sure you are using the appropriate cable box for your TV. If you have a high-definition TV you should also be using a high-def channel box from your cable provider. Watching standard definition channels on a high-def TV can make the picture look distorted and fuzzy.
Not all cable channels are broadcast in high-definition. When you stretch a standard definition picture to fill the full frame of your wide-screen TV it may look distorted. You can try changing your TV display settings to show standard-def channels at their native resolution. This will create black or gray bands on either side of your picture.
Ideally all of your video components will be connected to your TV with HDMI cables. Your next best option will be component video cables. If your cable box does not have HDMI capabilities, contact your cable company about upgrading your box to one that does include HDMI.
Make sure there is no glare on your TV from a window or other strong light source. This can significantly degrade the quality of the image you are watching.
If your TV has digital noise reduction, try turning that feature on.
You can adjust your TV's sharpness and picture modes to see if that improves picture quality.
Try plugging the power cord into a different electrical outlet and/or surge protector. You may be receiving electrical interference through your power cord.
Trying moving any nearby electrical devices away from the TV. They may be creating interference that can degrade the picture quality.
Let me know if the above helps or not, so that I can direct you further on what do next.....
Best regards.
Apr 14, 2011 | Zenith IQB50M90W 50" Rear Projection...
We recently switched to digital cable and now the TV has a solid line thorough the center of the screen. This started intermitently and after a time the picture would come on but now is constant. Is this...
If the set is a standard CRT type set and the line is a horizontal one, this is a common problem that has nothing to do with the switch. There is a problem with the vertical circuit that can be a simple as poor connections at the vertical IC (LA7837 or somthing similar) or a defective IC.
Dan
Mar 14, 2010 | Toshiba Televison & Video
Sound interference... The Box Super & NT*L
the cable is in the wrong connector you need to put it in the Cable in; not tv in that will sort it out .
Dec 16, 2008 | StarTech.com StarView SV211K 2-port KVM...
Just bought a samsung ps50a557s3f 50" plasma tv and the picture isnt very good.Have only got normal sky at the moment and i was wondering what the best settings are
Hi Smudger
Not sure if you still have this issue, but i have just bought this TV & also use sky (not + or HD)...
I got myself a Monster Cable Home Theatre surge protection unit from comet, basically it helps filter out all the background interference (picture & sound) & helps boost the signal sent to the TV..
I use a gold plated scart lead from the sky box to the TV & the picture is spot on.......i've not noticed any ghosting/pixeling etc & am well impressed...
The unit came with a top end HDMI cable & cost £135 (bit excessive you may think, but to buy the unit & cable seperate would cost £250!!) + the cable is a 'cable for life', so you can get a free updated cable as technology progresses :-)
My sky signal was always at half power (you can view this from the sky menu options) & now its almost full signal
Oct 06, 2008 | Samsung Televison & Video
Cable TV connection
Hi, A couple of possibilities: 1. Line loss, some of the cables might be too long, shorted, loose ground, not connected right; 2. Splitter - passive splitter, you might be better off using a distribution amplifies (with gain control pref); 3. RFI - TV interference from external sources. Hope this be of some help/idea. Post back how things are or should you need further information. Good luck and kind regards.
Sep 02, 2007 | Televison & Video
Toshiba 56HMX195 52" HDTV DLP Projection TV Logo
190 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
