Question about Lexmark MFP-X3470 All-In-One InkJet Printer
I have a lexmark 3430, i have replaced the ink cartridge #24 and
Now the menu keeps telling me that the ink cartridge is incorrect how can i fix this
SOURCE:
tbirdfan1
  • 3051 Answers
SOURCE: Does a Lexmark 3430 printer take a black ink
hi there
yes it does the number is 32 for the black and the color is 33 about 30 buck's a pop hope that helps ya best regards mike
Posted on Feb 18, 2009
sgarrand
  • 25 Answers
SOURCE: lexmark x3430 ink cartridge?
According to Lexmark's site, it takes #24 or #24A.
Posted on Mar 13, 2009
  • 62 Answers
SOURCE: Printer says cartridge incorrect, but is the right one...what do I need to do?
There are a small number of #23/#24 cartridges that are not properly recognized by the printer. Lexmark has a firmware upgrade to correct this issue.
The upgrade for the X3430 is available from Lexmark at: PC: http://www.downloaddelivery.com/downloads/misc/Firmware_F061909_3430Series.exe Mac: http://www.downloaddelivery.com/downloads/misc/Mac_MCC_J062309_01.Zip
To install the firmware upgrade, 1. Make sure the printer is ON and connected with a USB cable. 2. Download and run the appropriate firmware upgrade for your computer. 3. Be sure not to disconnect or power off the printer until the upgrade is complete
When the update finishes the printer will restart and will accept the cartridges. Please contact Lexmark support if this does not fix the problem.
Posted on Jun 25, 2009
  • 62 Answers
SOURCE: Lexmark X3550 ink cartridge #23 receiving error
There are a small number of #23/#24 cartridges that are not properly recognized by the printer. Lexmark has a firmware upgrade to correct this issue. The upgrade for the X3430 is available from Lexmark at:
A similar patch is available for the X3430 and Z1420 models. See http://bit.ly/LoXxv
  • 62 Answers
SOURCE: left ink cartridge incorrect
This works for the X3550 and X4550 models. A similar patch is available for the X3430 and Z1420 models. See http://bit.ly/LoXxv
Keeps saying insert colour cartridge when we have just bought a new cartridge of correct spec. Says incorrect colour cartridge installed.Impossible to get past!!!
Hi,The most common reason for missing or incorrect colors is a print cartridge with one of the following problems:
  • One or more of the ink colors is empty. The black ink and all three colors of ink in the tri-color cartridge must be available or colors will be incorrect or missing. Under normal usage, the print cartridge will run low on one color of ink shortly before all ink colors are emptied.
  • The protective tape is not removed from a new cartridge.
  • Contacts on the cartridge are not making proper contact with the print carriage.
  • The cartridge is remanufactured or refilled.
  • The cartridge is defective.
Feb 14, 2010 | HP PSC 950 All-In-One InkJet Printer
My printer keeps saying left cartridge incorrect. I know how to put the cartridges in, I've had this printer for 4 years.
The connector for that cartridge isn't working properly - if you're lucky all you will need is a new cartridge; if you're unlucky a new All-in-one.
Nov 14, 2009 | Dell 962 Photo All-In-One InkJet Printer
I replaced the black ink and it keeps saying replace ink cartridge. I actually went ahead and changed the color as well even though it did not ask and it keeps saying replace cartridge. HELP! I am a...
Did you replace the ink cartridge with a new one, or did you refill an old one.
Some printers have a memory and can tell which ink cartridge is in them. This prevents them from easily being fooled into printing with refilled cartridges.
Another option is that you changed the ink cartridge without following the specific guidelines for replacement e.g. To replace the ink cartridge, select replace ink cartridge from the main menu, then open the printer panel when the light flashes X number of times.
You might also try unplugging the printer for a couple of minutes the reset it.
Oct 15, 2009 | Office Equipment & Supplies
My Dell AIO printer keeps blinking right ink cartridge incorrect.Exclamation light keeps blinking too.
Try going to the Dell site and searching for that printer model. Then see if you need to have both ink cartridges populated and filled with ink, to make it work.
You might also clean the contacts on the ink cartridges, to make sure the printer knows you have both cartridges in the printer, even though they're not both filled with ink.
It just might require both to be filled, before it will print for you.
See what Dell says.
Good luck.
-a.
May 22, 2009 | Dell 962 Photo All-In-One InkJet Printer
Error message after replacing the black cartridge
You must replace both ink carts to get an alignment.
Dec 29, 2008 | HP PSC 2210 All-In-One InkJet Printer
Display shows: printer cartridge incorrect
It seems like you are using incorrect printer cartridges.....
Make sure that part number on ink cartridges should be :
MK990 Cartridge, Ink, Standard, Series-9, Black CTRG,INK,STD,SERIES-9,BLK 0 1 0 Yes 1 N MK991 Cartridge, Ink, Standard, Series-9, Color CTRG,INK,STD,SERIES-9,CLR 0 1 0 Yes 1 N MK992 Cartridge, Ink, High-Yield, Series-9, Black CTRG,INK,HIYLD,SERIES-9,BLK 0 1 0 Yes 1 N MK993 Cartridge, Ink, High-Yield, Series-9, Color CTRG,INK,HIYLD,SERIES-9,CLR 0 1 0 Yes 1 N MK995 Cartridge, Ink, Series-9, Photo
Nov 10, 2008 | Dell 962 Photo All-In-One InkJet Printer
Message : Black ink cartridge empty , order new one
Haven't found a fix as of yet ...Will keep looking .. $15.00 for expert help is half the price of the printer. I'll keep searching , thank you !!!! In the mean time I'll tell everyone about Lexmark and how they handle their ink cartridges
ummyguy
Aug 20, 2008 | Lexmark Z1300 InkJet Photo Printer
Right cartridge incorrect" and "Left cartridge incorrect
Many newer HP Printers internally keep track of your cartridges by a serial number embedded into the cartridge. When it's low, the printer remembers. This is entirely done within the printer itself, and not the printer software. Some printers EXPIRE the cartridges after 18 months according to the installation date even it is not empty.
Outrageous, but true.
A fix? Most HP printers will only keep 2 cartridges in memory, so if you have 2 extra cartridges, (even empty ones) you could cycle them through to reset the printers memory, and reset the ink level to full. Basically, even though you've refilled your cartridge, the printers has the cartridge's serial number stored in memory. This will reset it.
Jun 02, 2008 | Dell 962 Photo All-In-One InkJet Printer
Open Questions:
Lexmark MFP-X3470 All-In-One InkJet Printer Logo
111 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
