Question about Philips Televison & Video
Tv won't come one and blinks red 7 times then stops.
It's a 42'' flat screen last week every once in a while half the screen would blank out, the bottom only, then yesterday we lost the picture completely but the light was still green. After a few minutes the light turned to red and now flashes 7 times then stops and a few seconds later will do it again, unless I unplug it.
  • ferretloverx Jun 02, 2009
    It is a plasma. any idea how much that will cost?
  • 126 Answers
When the bottom half of the picture goes out this usually indicates a failure of the lower Y driver module. When this module fails it will often take out the Y sustain module and when that happens the set goes into over current shut down. Both boards will have to be replaced. All of this is assuming you have a Plasma set and not a LCD flat panel.
Posted on Jun 02, 2009
  • hatman1 Jun 02, 2009
    Depends on what part of the country you are in....Those boards aren't cheap. I'd say average repair would run between $300 and $500.
Flat screen tv problem
42PF7320A: 7 blinks is missing 8.6VDC from supply -- connector CN-1M46, pin 3 (out of 11 pins), goes from power supply to main/input board.
Apr 21, 2010 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 42 wont turn on
I am having this same problem. I have "fixed" this problem twice by replacing 2 failed capacitors inside. The fix is pretty easy and the cost of the replacement parts is about $2.50. Unfortunately, the fix doesn't last. The first time, the TV worked again for about 6 months, but the 2nd time, when I replaced with higher grade capacitors, I only got another 2 weeks out of the TV. I think it's time to cut my losses and get a new set. Repair costs were estimated at $600. ...just not worth it.
Jan 25, 2010 | Philips Televison & Video
7 red flashing lights, won't power up..
Check the power board for capacitors with the tops bulged up. They are 3300uf 10v. There are either 2 or 4 of them depending on your set.
Jun 01, 2009 | Philips 42PF9631D 42 in. Plasma Television
LG 42 LCD no sound or picture
Did anyone find out the solution for this??????? I have the exact same problem with my LG 32 LCD. I only had it for a year and a half, and the green light blinks a few times and it shows no picture. Not even a red light when the tv is off. The same thing happened a couple weeks ago and by some miracle it started working again.
Jan 28, 2009 | Televison & Video
Philips 42" Flat Screen Plasma - blinking red light 7 times - HELP please!
Here is a photo of the board where I have removed the two from my TV. You can see the two open holes.
Aug 07, 2008 | Philips 42PF9631D 42 in. Plasma Television
Blank Screen
Many have replaced caps on the SMPS board, with success:
2662 is a 1000μF 25v 85°C with 2663 and 2664 both 25v 100μF 25v
Another model: http://www.hotelkaveka.com/9944CU.jpg
Some other pics of different caps: http://i121.photobucket.com/albums/o229/garafrax/TV%20Repair/HPIM1458.jpg
Once you get it on, there are adjustments to the VS voltage to cure the speckle.
Jul 12, 2008 | Philips 42PF9630A 42 in. Plasma Television
Philips 42 in. Plasma shut down
did u cheak the input cables does it do it on dvd input as well as others ?
Feb 01, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Televison & Video Logo
249 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
