Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Kitchenaid Superba Model #ksrb25fkss01 Serial # sm0426177
The setting is on the coldest setting yet it absolutely won't keep anything cold. We have defrosted the fridge several times but that didn't HELLLLLLLLP please. Thank you.
  • 23 Answers
Re: Kitchenaid Superba Model #ksrb25fkss01 Serial #...
What about the freezer?. Check door seals with a dollar bill, close the door with the bill in different spots, if bill comes out to easy then seals might be bad or a door adjustment is in order. Make sure the coils underneath or behind do not have a layer of dirt on them. Try these simple steps and let us know thanks
Posted on Dec 08, 2007
0 characters
3 Points
Hi, I have a KitchenAid KSRB25FKSS02 and our refrigerator is not cooling and it is already set to the coldest setting, but our freezer is working just fine.
This is a fairly common problem and is likely caused by the failure of a concealed fan that is responsible for distributing cooled air from the freezer section to the refrigerator side.
SearsDirect parts department has full information on your KitchenAid fridge at the link below:
The fan I suspect is shown here:
Distribution parts
Looking at the various pages should give you an idea if you consider this a DIY task or call a pro.
Jul 04, 2011 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid superba refrigerator side at lowest temp setting is not cold enough. Freezer temp is fine.
Check the setting of your vents between sides and open them, sometimes you have to pull out the produce drawer to find the lower one
Jun 23, 2011 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba fridge section not cooling, freezer is cold.
You have done a good job of attempting to diagnose by process of elimination, but this is a more complex system. I have provided some links below to assist you in diagnosing your problem. Links courtesy of
1. Ascertain that the evaporator fan is operational. This may be controlled by the Door Switch, (No.4) and could cause the fan to be inoperable.
2. Ascertain that the Fresh Food compartment light goes off when door is closed.
3. The air diffuser may be faulty by not controlling the air flow from the freezer properly
Tip: Always maintain dual temperature control settings at equal or +/- 1 setting position.
How refrigerators work:
You will need to verify operation of the following components listed below:
1. Evaporator fan motor
2. Air diffuser assembly
3. Light switch for refrigerator/freezer light
4. Door switch
Click on the links to identify the parts listed
Parts breakdown diagram:
Aug 13, 2009 | Refrigerators
Kitchenaid superba refrigerator problem
I'm almost 99% sure that you have a bad compressor relay. Have you been hearing a clicking noise coming from behind the unit? This is the first indication of a failed compressor relay. Pull the unit out and unplug it. Remove the back cover and go to the compressor. You will find a device on the side of the compressor that has the wires hooked to it. This is the compressor relay and overload. It may be under a black cap. Remove the cap to access it. It may have 2 pieces to it or it may just have the 2 pieces encased in a white and tan box. Remove this box and shake it. If it rattles like gravel in it then it is bad. If it is in 2 pieces then it will have a brown relay. This is the piece that will rattle if bad. The white and black piece with one wire is the overload. They most never go bad. Use this replacement part kit...8201786 and follow the detailed instructions included in the kit. Thanks for the question. Hope this helps.
Nov 01, 2008 | KitchenAid Superba KSBS23IN Side by Side...
KitchenAid Superba that doesn't refrigerate
cathe if compressor is not running nothinh will get cold specially if frezeer is not working then the other side wont etheir if compressor is not running then it might just be the overload if nothing is running just the lights the is etheir the timer or thermostat
Oct 14, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid Freezer not freezing completley
sounds like you might have a sealed system issue(ie.compressor, sealed system. check your user guide for warr inf you might stil be covered by manufacture for this issue
Jan 06, 2008 | KitchenAid Superba Architect KSCS25INSS...
Fridge does not get cold
If your getting frost build up in the freezer..u said u tried defrosting... is frost building up it freezer?
IF so you have a defrost problem...bad  heaters, defrost themostat or defrost timmer, if ya need more help post more info
Things to check
Check freezer...
for Frost build up and if Fan is blowing,
Check condenser...
To make sure clean, and the fan is blowing by compressor & IF it is running
Check Recirclating Vents in refrigerator... to make sure theres no blockage,
CONTROLS ...should be in the middle setting,
Allowing.. MORE AIR.. to refrigertor side
Oct 23, 2007 | KitchenAid Superba KSCS23IN Side by Side...
Superba kitchenaid fridge not very cold, freezer is fine
do you have any frost build up it the freezer back wall... fan blowing in freezer and in back ...condeser coils clean... if all the above is ok ...must have temp. sensor or themostate cold control problem
Sep 02, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
430 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
rugby prop
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
