Question about Air Tools & Compressors
Need to repack pump on graco gm5000 gas paint sprayer
I have a graco paint sprayer i need detailed instructions with a blow up if possible to repack fluid section... i have the kit .. i just need to know what is the next steps in the process ...
thanks in advance
  • 98 Answers
Http://www.graco.com/
you can put your model in or if you have a part # you can enter it into one of the fields eventually you will fing a parts diagram for your unit.
Posted on Feb 21, 2010
My graco GM5000 wont prime or build up pressure replaced transducer but still no pressure
The check valve is a ball valve that gets dirty and rusty over time and sticks usually due to the usage of water based paints and storage with water in the machine and lines. I run mineral spirits through the machine if I am storing the machine for longer than a few weeks. This helps to reduce rust and makes it easier to prime when I use the machine again. If I have the ball valve sticking on my machine I will tap the valve to try and get the ball to loosen but usually I have to disassemble the valve and clean it throughly cause I don't like to tap the valve too much and cause damage to it.
Oct 08, 2016 | GRACO INC 390 Stand Airless Paint Sprayer
How to repack the sprayer
The packings are static and self adjusting. The repack kit includes the piston so it replaces everything. Just buy the kit and follow the instructions. Try Scott at American Airless on 770 4771337.
Aug 25, 2014 | Titan Paint Sprayer. Advantage 200 Airless...
Graco paint sprayer repair
Odd that you have air coming out of the suction, however it sounds like your inlet valve is not closing, the ball damaged or missing, or the O-ring under the valve seat is missing or damaged.
Aug 14, 2014 | GRACO INC Ultra Max II 795 Electric...
I have Graco Gmax 5900 Airless paint sprayer Gas Powered with gun & hose. It is spraying alright but started making a loud kinda of a grinding noise when spraying. Any ideas on what problem may be,...
As I have only just seen your question, maybe you have fixed the problem? If not, this GMax sprayer has an electric clutch to control when it is pumping or not, so there could be 2 sources of the problem: The first is that when the clutch is closed, some part is touching something inside the housing. The other possibility is that one of the bearings has gone dry or a gear has a damaged tooth.
If its not fixed, the drive assembly needs to be opened up and the parts cheked
Jun 01, 2014 | GRACO INC GMAX II 5900 Airless Paint...
Pump will not prime after cleaning with paint thiner
Could be that your were using water based paint, so if there was any in the sprayer when you cleaned it out with thinner, this could cause the latex to become a rubbery mass that then blocks up the passage ways. If so you'll need to strip the pump and clean it out.
Oct 04, 2013 | GRACO INC TrueCoat Plus II 16N659
Graco magnum paint sprayer won't prime
Airless won't prime- I always start trouble shooting an Airless that won't build/hold pressure look at sump hose inlet filter (the hose that goes into the paint if its got paint debris on it clean off filter and pour the paint thru a strainer bag into a clean 5 gal bucket-also remove the filter housing on the spayer and clean and flush and replace filter and housing- the shaft or the metal sleave has two ball bearings called "check balls" that maybe stuck turn on sprayer and put a piece of wood on shaft and give it a few good taps this will knock the check balls loose if after all this fails then you need to have new packings put in becuase the old ones are worn this is pretty easy to see because the rod the compresses the paint will have signs of paint on it indicating that the packings are worn.. Note keep rod and other moving parts oiled ith graco throat seal and finally Graco sprayers with the X on them are there (Graco) home owner line of sprayers that sell at home depot they are rated for only a certain amount of Gal per year keep it in good condition and cleaned store with coro-check inside of the pump when you are done using it.....
May 27, 2012 | GRACO INC 232745 Magnum XR-7 3/4-HP...
Graco ultimate max11 490 paint sprayer does anyone know how it works because i have no instructions
Here you can find manuals for your Graco sprayer: http://www.graco.com/Internet/SiteSearch.nsf/Search?OpenAgent&Mode=M&Query=Ultra%20and%20Max%20and%20II%20and%20490
Michael
www.sprayfinishingstore.com ' info@sprayfinishingstore.com
Apr 04, 2011 | Air Tools & Compressors
Air Tools & Compressors Logo
1,509 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
