SOURCE: TI-83 Plus Problem
Batteries:
Make sure to replace the "battery backup" too the little lithium ion battery
Try Adjusting contrast:
Hold down "[2nd]" key press up or down arrow repeatedly to lighten or darken contrast.
First attempt reseting:
Step 1: Remove all the batteries
Step 2: Hold "Clear" key down
Step 3: Still holding "Clear" key reinstall batteries
Step 4: Still holding "Clear" key press "On" key until home screen is displayed.
Second shot reseting:
remove all batteries including lithium ion (backup battery), wait 3 hours and reinstall batteries.
Third Shot reseting:
Step 1: Remove a battery
Step 2: Hold down "DEL" key reinstall battery
Step 3: Possible msg pops up saying "Waiting ... Please install software" IGNORE msg and take out battery again
Step 4: Reinstall battery do not hold down "DEL" key
reseting will cause the handheld to loose all of its stored memory.
Hope that helps!
SOURCE: TI-83 Plus silver edition won't turn on.
the screen may be at the lowest dim setting, try turning it on, then pressing the 2nd key and then hold the up key and see if anything appears, if not let me know and I will try to figure out something else, I own a 83, 84, and 89 so it shouldn't be too hard to figure out
SOURCE: ti 83 plus small black screen?
try pressing 2nd then hold in down arrow to change the contrast
SOURCE: TI-83 Plus calculator--fractions
just type it in, e.g. 1/2 or 3/5. if you want to have answers display as fractions, press [MATH] ENTER.
SOURCE: my TI-83 plus calculator doesn't work
As battery gets drained, the screen contrast dims. But when you change batteries, some times the contrast is reset to some low value and the screen appears dead: it is so light that you do not see anything, and you think the calculator is malfunctioning. This is the most frequent reason users think the calculator refuses to turn ON. And I hope that is the case now.
To correct that, you must increase screen contrast: draken the screen a bit. To do so
If that solve your problem that is good, rate the post accordingly.. If that does not, do not get irate and berate the post. Post a comment here describing what you did and what message (if any) calculator returned, and I will give you further diagnostic steps.
Please be prepared to re-install the calculator's OS if you run through this process.
If you have a straight Ti 83 without the Plus or, Silver Edition label goto (Procedure 2) below. If your Ti calculator is a Ti 83 Plus or better goto (Procedure 1).
(Procedure 1). Try a new set of AAA batteries. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and, then press [CLEAR] one more time to remove the message. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system. Try a new set of AAA batteries. Remove one of the AAA batteries. Press and hold the [ON] key for 20 seconds. Reinsert the AAA battery and then turn the calculator on.
(Procedure 2).
~Connect the TI Connectivity cable between the PC and the calculator.
~Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
~Follow the on-screen directions to reinstall the calculator's OS. If you could not install the new OS on your calculator goto step 4.
For a straight Ti 83 without the Plus or, Silver Edition label try the procedure below.
