Question about Winbook Corporation PowerSpec MCE 410 PC Desktop
I have a WinBook XL Laptop that will not Power up,start up, switch on.
  • 21 Answers
This is for Winbook WinBest 233MMX
Replace the cmos battery. If it is more than 7 years old, it will most likely be weak or dead.
Remove the keyboard, ribbon cable from connector by pulling on the plastic tab, remove power connector then remove bottom screws and separate the case, pry the 3v battery off the welded ends, bend tabs so the new non-tabbed battery will be squeezing the new battery for contact, add a piece of electrical tape to secure it from sliding. Replace bottom and screws and then re-attach keyboard ribbon cable and 4 wire power connector. Re-boot and reset cmos ( CTRL-ALT-S ) on boot
Posted on Oct 01, 2009
  • haansgruber Apr 18, 2011
    If you still have this laptop and it is not working. I would be willing to buy it from you. Someone tripped over the cord and broke my wife's case at the hinge for the screen. The plastic probably cannot be repaired. Let me know since this is an old thread. I'd really like to fix this old computer. It does a job none of the new machines can do.
    email address is: gruber_haans (at) yahoo (dot) com (dot) sg
  • 37 Answers
Check your power adapter if it is still working. Try taking out the battery and plugin the power adapter and see if its gonna turn on.
Posted on Jun 02, 2009
Winbook tw802. How do I hard reset?
    1)Begin by holding down power key to turn the device back on.
    2)In the next step open main menu
    3)Then from the screen in front of you find and select settings
    4)Then tap change PC settings and choose update and recovery
    5)In this step select recovery
    6)Afterwards search and choose option remove everything and reinstall windows
    7)When the appropriate information pop-up comes up tap next to begin the process
    8)Success! After about 30 minutes your tablet is ready to use
http://www.hardreset.info/devices/winbook/winbook-tw800
Dec 19, 2015 | Computers & Internet
Winbook laptop wont power up, could it be a security thing
First you state Desktop then Laptop ?
Take the battery out, plug in the charger and see if the laptop works.
If it works, the battery may be the problem.
Check the AC Adapter
Check to make sure the adapter is plugged securely into the wall outlet, connected firmly to the adapter box and to the back of your laptop.
Most AC adapters have a little light in themon that rectangular box in the middle of the cord that lights up when it's getting electricity.
If that light isn't on, try a different outlet.
Check your fuse or circuit breaker box and plug a different device into that outlet to make sure there is power to it.
If it still does not light up, your adapter could need replacing.
Also check the adapter box for signs of warmth, as it will generate heat when it's plugged in. No heat means no power.
Remove the Battery Sometimes it's as simple as a seated battery.
Remove the battery entirely and clean out any dust, lint or hair that may be clogging the connectors and preventing a proper connection.
Reseat the battery securely and make sure the little locking pins that hold your battery in place are securely fastened and there is no movement.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards
Check all power and data leads from motherboard to hard drive and all of your cd/dvd drives make sure connections are secure dust free and not faulty
computers need all power and data to travel through every working device and to finish its cycle
so any faulty lead will end in computer error or shutdown / fail to boot or to reboot on a cycle
make sure your computers RAM modules are securely seated with no dust in the sockets also the Cmos battery has charge and seated with no dust in the sockets.
some Motherboards Cmos batteries are soldered in.
Mar 10, 2014 | Winbook Corporation PowerSpec MCE 410 PC...
It is a winbook xl when i power it on the battery light turns on not any other lights i dont see any thing on the screen or hear the harddrive or any thing not even a beep i need help the laptop is about...
Without seeing it, I'd guess the power unit might have failed, or it could be the motherboard. Modern computers have a system management controller you can try resetting, but on a 15 year old laptop I don't know what the equivalent would be, if it even exists. If it's the motherboard chances are it'll be cheaper to buy a new computer.
Jul 28, 2013 | Computers & Internet
A got a Winbook 330. 1 G ram memory
Check the proper audio and WLAN drivers from the vendor and install.
Dec 01, 2009 | Computers & Internet
Where is the WiFi hardware switch on my WinBook, model MS-16372 laptop?
normally the switch is along the number keys 1 to 9 is a wireless cymbal , you must press a key with this key most of tmies its the fn key , not to sure about the winbooks, hope this helps
Nov 29, 2009 | Winbook Corporation X 510 (618996143061)...
My winbook wont charge
turn off remove the battery
plug in charger and see if laptop turns on
fiddle with cord to see if laptop cuts off. If so you need a new charger or
the jack in the laptop has a short.
If if stays on the battery may be bad
Nov 08, 2009 | Micro Electronics WinBook Si Notebook
How do I upgrade Winbook A210 Laptop to one gig.?
the ram is under your keyboard. on the sides of you keyboard the are tabs, 6 of them you need a small screw driver or something flat push in tabs starting on one side as you push them pry up gently on the keyboard till you have got the key board up then take out the 4 screws to expose the ram and mini pci slot where you NIC is located. Gently push the two tabs holding the ram in place away from the ram and pop it up. when you replace the ram it will go in at an angle and than you will press it down till the tabs clip in place note the location of the tabs to the notches on the ram before you pull it out. so you can see if you got it in all the way.
Jun 23, 2009 | Computers & Internet
Laptop CMOS battery
This is for Winbook WinBest 233MMX may be good for other Winbooks
Had trouble booting then just quit booting altogether...
For a quick fix that won't require soldering....
Replace the cmos battery2.gif. If it is more than 7 years old, it will most likely be weak or dead.
Remove the keyboard by sliding the KB toward you and lift the top up and slide out, Remove KB ribbon cable2.gif from connector by pulling on the plastic tab, remove the 4pin KB power connector. Then remove bottom screws and separate the case.
Locate the 3V battery, Pry the top tab of the 3v battery off the welded ends with a small needlenose, Pry the battery off the mini board, bend battery tabs so the new non-tabbed battery will be squeezing the new battery for contact, + is up!, add a piece of electrical tape to secure it from sliding. Replace bottom case and screws and then re-attach keyboard2.gif ribbon cable and 4 wire power connector. Re-boot and reset cmos ( CTRL-ALT-S ) on boot. Set your time. You must set the boot sequence to C:. It will then auto boot to C: WALLA! WIN98!
Mar 18, 2009 | Micro Electronics WinBook J1 Notebook
Need drivers for a winbook laptop
Hi there
Get the XP drivers here:
http://pcsupport.about.com/gi/dynamic/offsite.htm?zi=1/XJ&sdn=pcsupport&cdn=compute&tm=16&f=00&su=p284.9.336.ip_p504.1.336.ip_&tt=11&bt=1&bts=1&zu=http%3A//www.winbookcorp.com/
Thanks for using Fixya!!!
Feb 01, 2009 | Winbook Corporation WinBook A710...
Winbook Corporation PowerSpec MCE 410 PC Desktop Logo
429 people viewed this question
Top Winbook Corporation Computers & Internet Experts
Masood Rasool
Level 1 Expert
Mike Rommel
Mike Rommel
Are you a Winbook Corporation Computer and Internet Expert? Answer questions, earn points and help others
