Question about Akai LCT2060 Television
Remote codes needed
Need remote codes for this tv remote
SOURCE:
  • 21 Answers
SOURCE: Programing Code for RCA Universal Remote Control
It does not have any code.
Posted on Oct 22, 2008
SOURCE: remote that came with tv wont work
I stumbled across this page while the owner's manual for my remote was lost. I've now found the manual (after not having any luck finding the solution on the web)!
The AKAI KC02-D2 remote operates my AKAI PDP42Z5TA 42" Plasma HD Television. It may work with others as well, but that's the TV I use it for. If the batteries are removed (or dead) for a while, it will lose its programming. Here's how to reprogram it.
AKAI = 231, 218, 221, 222, 225, 226, 227, 228
1. Turn on the Device you want to program. The remote can be programmed by pressing the 3 Digit Brand Code number listed in the code table of this programming guide. If multiple codes are listed, you may have to enter several codes to complete the steps below. (Note: For programming the VCR, a tape must be loaded/inserted first.) If your Brand is not listed, please use the Manual Search menthod or Auto Search method (Section C & D below).
2. Press and hold the SET button for about 3 seconds until the current Device LED lights (TV, VCR, DVD, STB.), then release the SET button.
3. Press the device button you want to program (TV, VCR, DVD, STB.) then the selected Device LED will light on.
4. Enter the 3 Digit Brand Code for the desired Device. For example, enter "2" "1" "8" for AKAI TV. When entering each digit, the Device LED will flash one time. After all 3 digit numbers are entered, the Device LED will turn off. If the code is not valid, the Device LED will flash three times then turn off. Check the code list and repeat from the above step 2.
(*The manual contains a huge list of 3-digit codes for various devices. If you're looking for a specific one, just ask.)
Posted on Dec 30, 2008
atienzajude
  • 58 Answers
SOURCE: akai remote codes are what
Akai codes: 0051 0301 0671 0741 0851 0871 0991 1001 1491 2371 2391 2551 2751 2791
You may setup the URC by the following code entering instructions.
1. Refer to the DEVICE CODE LIST, look up the 4-digit Device Code which
corresponds to the brands of your A/V equipment. If there are more than
one Device Code listed under your brand, try from the first code.
2. Press a desired Device Mode Key
3. Hold down “ CH+ ” and “ VOL– ” on the URC together simultaneously for 2
seconds until the indicator lights up.
4. Use the number keys to enter your 4-digit Device Code, the indicator
should go out immediately.
Turn on your device (e.g. TV), try the function keys on the URC. If your device
(e.g. TV) responds to your invoked function correctly, you have entered the
right Device Code. Otherwise, repeat the above setup instructions with the
rest available Device Codes until your device (e.g. TV) responds to your invoked
function, and most keys work correctly.
Posted on Sep 09, 2009
  • 23 Answers
SOURCE: AKAI LCT2070 20" TV UNIVERSAL REMOTE CODES & BRAND/ REPLACEMENT
I recently bought a used LCT2060 that had no remote. I figured my comcast cable remote would work without a problem but it didn't. So 3 universal remotes later I found my solution...a radio shack2_bing.gif universal gamer remote. It controls up to 5 components plus your xbox360, playstation and pc. The price on sale was a mere 12.97, not bad if you ask me. Hope this helped. The code that worked for the Akai2_bing.gif was 11676. Take care...
Posted on Feb 18, 2010
  • 23 Answers
SOURCE: need setup codes for Akai KC01-B2 to run with comcast remote
Im trying to program a Panasonic universal remote to clear tunes tv
Search Results
    Need codes for ct-300 clear tunes universal remote - Fixya
    www.fixya.com/.../t17341079-need_codes_ct_300_clear_tunes_universa...
    Mar 26, 2013 - need codes for ct-300 clear tunes universal remote Need codes - Symphonic ST419E TV ... Universal remote code for a panasonic ct-27g14a.
    I have a clear tunes tv and trying to program my RCA universal
    www.fixya.com/support/t25649135-clear_tunes_tv_trying_program_rca
    Apr 16, 2015 - ... a clear tunes tv and trying to program my RCA universal remote to it ... "I need to program an old Panasonic TV with a RCA universal remote ...
    I need the codes to a clear tunes remote for a rca - Fixya
    www.fixya.com/support/t3026751-need_codes_clear_tunes_remote_rca
    Sep 26, 2009 - I need the codes to a clear tunes remote for a rca tv. ... "I need toprogram an old Panasonic TV with a RCA universal remote model RCR311St ...
    Radio Shack panasonic remote control codes clear tunes tv ...
    www.fixya.com > ... > panasonic remote control codes clear tunes tv
    ...remote. the panasonic codefor my radioshack 3-in-one remote is 0250 I need a codefor a VCR Durabrand (DCV603) for the Sony universal remote control or a ...
    Clear tech tv 4 digit code - TV - Other Consumer Electronics
Jan 25, 2016 | Panasonic Televison & Video
Guys I need help for my Hyundai TV...i need help code I used chunghop rm-133E
Hyundai Universal Remote Tv Full remote control with ...
tv.manualsonline.com > ... > Hyundai Universal Remote
Hyundai Tv Full remote control with exclusive Dynamic Database Technology ... replaced, the remote control will stop ... is preprogrammed with codes for the.
Universal Remote Control Remote Control Code hyundai tv ...
www.fixya.com > ... > Universal Remote Control Remote Control
code for Hyundai Q320 TV What is the universal 3-digit remote code for ... Hyundai TV Code hi! my hyundai TV remote is no longer working so i bought a ...
hyundai tv remote code Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Jan 11, 2016 | Televison & Video
I have a broksonic TV. and I need the code to a lm-1079 TV remote
Universal Remote Control Universal Remote lm-1079 Need ...
tv.manualsonline.com/...remote-control/...remote/need-codes-for-univers...
May 9, 2014 - Need codes for universal remote model number lm-1079. Asked by paula young on ... 1 how to set code for tv from lm_1079. Was this answer ...Missing: broksonic
Universal Remote Control Product Support ' ManualsOnline ...
tv.manualsonline.com/support/universal-remote-control/
Need codes for universal remote model number lm-10. Universal Remote ... UniversalRemote Control Universal Remote ECCO LCD 24?€? Tv. 0 Solutions ...
Universal Remote Control Codes - iWave Super-Sized
Dec 30, 2015 | Televison & Video
I have a GE JC024 tv remote and need code for an Emerson tv
These are the setup codes for Emerson TV, with GE remote control.
0004 0009 0044 0135 0049 0051 0189 0053 0147 0039 0130 0227 0233 0250 0252 0254 0257 0265 0266 0310 0325 0456 0040 0041 0042 0021 0023 0024 0179 0045 0025 0027 0030 0032 0034 0035 0037
Sep 20, 2012 | GE Remote Original Jc024 Remote Control...
I need a code for my universal remote from Philips. My TV is JVC. That's the code that i need. Please help me......
I need a code for my universal remote from Philips. My TV is APEX. That's the code that i need. Please help me......
Nov 30, 2009 | Philips Universal PH301S Remote Control
Need remote code for Wansa brand TV
I NEED WANSA 29" TV MODEL TK2966
REMOTE MODEL NO (OR) MODEL IMEAGE
Jul 02, 2009 | Televison & Video
TV Remote Control Code
i need the codes for this remote.. the tv is a symphonic.. the remote is a oneforall
Nov 11, 2008 | One For All URC-3021 Remote Control
General electric Universal remote control codes
i lost my code book for my ge remote control
Apr 11, 2008 | Broksonic CTVG-5463GVC 19" TV
Need codes please for Jensen JER 422 for Magnabox TV
magnavox tv jer 422 codes are: 1000 1004 1006 1008 1019 1062 1068 1069 1075 1076 1133 1219
Jan 12, 2008 | Jensen JER-422 Universal Remote Control
Akai LCT2060 Television Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
