Question about Sony RDR-HX510S DVD Recorder/HDD Recorder
Sony DVD Recorder not recording correctly
DVD player 3 months old.   Doesn't happen all the time but has started to change channels during automatic recording.   You don't realise until you play back and only have part of the programme and the rest is from another or several others channels.
Posted on Nov 25, 2007
No reception!
Contact Sony directly so they can walk you through it.
Before you do, try it from scratch one more time.
Good Luck.
Nov 14, 2013 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Sony RDR-HDC100 will not remain operating and turns itself off
follow this step:
No power
  1. Check if the power cord has been properly connected to the power outlet.
  2. Check if the main power has been switched on.
    (DVD player's power supply transformer could be burned out)
Screen is "frozen" or completely black, or Power button does not work
  1. Try turning the power off and wait 3 seconds before turning it on again.
  2. Make sure the TV and VCR (if connected) are set to the correct channel or line.
    However the power supply can be faulty,some resistor,capacitor, diode or IC . see the block attached .If you do not have skill for electronic, go to the repair shop.
    God bless you
Feb 09, 2013 | Televison & Video
How to record
Be sure you have first set the clock correctly. After setting timer recorder time, channel, speed etc. hit enter to highlight the setting to be sure you have it. Press setup to put you back to tv screen. Then press t-Set button on remote. Unit will automatically shut off and there will be an amber symbol on the unit lcd along with the time. This indicated the unit is in the timer mode. It will automatically turn on and record the program at the set time.
Sep 26, 2012 | Sylvania DVR90VE DVD Recorder/VCR
How do I select the recording speed "SP" mode on my Panasonic DMR-E55 DVD recorder
1 Press [< OPEN/CLOSE] on the main
unit to open the tray and insert a disc.
≥Press the button again to close the tray.
2 Press [W X CH] to select the channel.
To select with the numbered buttons:
3 Press [REC MODE] to select the
recording mode (XP, SP, LP or EP).
4 Press [¥ REC] to start recording.
Recording will take place on open space on disc. Data will not
be overwritten.
≥You cannot change the channel or recording mode during
≥[RAM] You can change the audio being received by pressing
[AUDIO] during recording. (Does not affect the recording of
Feb 02, 2010 | Panasonic DMR-E55 DVD Recorder
DVD recorder won't start up properly
model number :RDH-HXD760. The problem is it won't start up correctly. The welcome message stay on and nothing further happens.
I have replaced all the caps( C105 400V 120uF and 2 of 10V 3900uF no needs) in power supply. It back to work !!!
John Chew
Apr 08, 2009 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Programming TV-channels on old Samsung VHS video recorder VB-520T
I tried another position of te range switches and scanned again and again and then I found the tv channels finally.
Mar 25, 2009 | Televison & Video
I need playback channel for tv to be ch.4 -
Solution 1
How to set the DVD Recorder+VCR’s RF output channel
Turn off the DVD Recorder+VCR, then press and hold
CH (v/V) on the front panel for about five
seconds to change the RF output channel (CH 03 or
CH 04). “RF 03” or “RF 04” appears on the front panel display.
Solution 2
Cable Service With Cable Box
If a cable box is required in your cable system, follow the
instructions shown below. This hookup permits both TV and
DVD Recorder+VCR operation.
To view or record a CATV channel:
1 Tune the TV to the correct video input channel.
2 Set the DVD Recorder+VCR to the output channel of the
cable box using the CH (v / V) or the 0-9 keys on your DVD
Recorder+VCR (e.g., CH3).
3 Select the channel you wish to view on the cable box.
Please rate this a fixya
Jan 30, 2009 | GoVideo Go Video DVD/VCR Combo
Setting the clock on a Wharfedale DVDRHD400F
Try scanning for channels. It may well download time and date automatically.
Dec 21, 2007 | Wharfedale DVD-M3 DVD Player
Timer recording on GoVideo VR2940
First, you need to have the cable directly input into the recorder.
If you only plug the cable box into the machine, you get what is happening now.
After splitting the cable, one side into te box and the other into the recorder, run the channel seek part of the program and it will scan all the channels available on the cable and place them in memory.
Then plug the output of the cable box into the other input on the recorder, and you get yor pay channels and upper tiers.
Your recorder is now a switching unit as well
Nov 19, 2007 | GoVideo VR2940 DVD Recorder/VCR
Sony RDR-HX510S DVD Recorder/HDD Recorder Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
