Question about Microsoft Windows Server 2003 Enterprise Edition x64 for PC
Window key Problem,While Server is working fine.
I have Window 2003 Server on my system when updating with Window 2003 Server SP1. It give Error Message Window Key Problem
What do you know produck key windows xp pack 2
Posted on Jun 03, 2009
Corrupt data behind Powerpoint 2003 graphs
1. If you run PowerPoint 2003, choose Help, About Microsoft PowerPoint from the main menu bar. If the About screen doesn't indicate that you have SP1 (Service Pack 1) or higher, you should update your copy of PowerPoint. Choose Help, Check For Updates. When the Office Downloads page opens in your browser, click "Check for Updates" and apply the recommended hotfixes and/or service packs.
2. If you run Windows XP and have installed SP1, see Files open as Read-Only after installing Windows XP SP1, Other file/path related problems
3. Open a blank presentation (You can apply the template used for the damaged file, if applicable. That might help cut down on reformatting.)
4. From the main menu, choose Insert, Slides from File (or if you use PowerPoint 2007, Home tab, New Slides (bottom of button), Reuse Slides.
5. Try to insert slides individually if you're not able to insert the whole thing
6. Use software for restoring corrupt .ppt and .pptx documents https://www.repairtoolbox.com/powerpointrepair.html PowerPoint Repair Toolbox
May 06, 2015 | Microsoft PowerPoint Computers & Internet
Upgrade win 2003 32 bit to 64bit
You Must do a complete Install there is no other way around this. You must do a complete clean install of the x64 bit server. There is no install-in-place option and the program file system format is different for the 32 and 64 bit versions.
Microsoft suggests this and I have had at least one of my friend's question me on this issue.
Mar 17, 2009 | Microsoft Windows Server 2003 Enterprise...
Unable to check for updates with Windows Vista Home Premiun, SP1, 32 bits, error code 80244019 for Windiws Update and 0x80244019 for Windows Defender, last update instaled Jan/01/09
I've been having the same error when I try to run Windows update on a Vista Ultimate machine setup for use with our SBS 2003 server running ISA 2004.
The Solution that I found is this.
When you setup Vista for use with a domain it creates the following regkey with a subkey etc ( policy ) that sets Vista to look for a WSUS server.
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate]
"WUServer"="http://serversbs"
"WUStatusServer"="http://serversbs"
[HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\AU]
"NoAutoUpdate"=dword:00000000
"AUOptions"=dword:00000004
"ScheduledInstallDay"=dword:00000000
"ScheduledInstallTime"=dword:00000003
"NoAutoRebootWithLoggedOnUsers"=dword:00000001
"RescheduleWaitTime"=dword:00000001
"UseWUServer"=dword:00000001
When I deleted this key and rebooted my PC windows update was working.
Hope this was somehow usefull
source: http://www.vistax64.com/vista-general/3421-windows-update-error-code-80244019-a.html
Good luck
Feb 23, 2009 | Microsoft Windows Vista Home Premium with...
There is no problem i want free antivirus for win 2003 server edi
try avir antivirus personal edition, which is the free version. it works fine, is pretty light and will only give you a popup window to upgrade when you update the program or virus file.
Jan 29, 2009 | Microsoft Windows Server Standard 2003 for...
Server 2003 sp1 not installing
Sometimes if you call up Microsoft and explain the situation they can issue you a new code to put in your machine. This at least works with consumer operating systems. I'm not sure if they will for a server operating system. It sounds like you were sold pirated or illegally copied software. I would take it up with the person who sold you that copy.
Oct 18, 2008 | Computers & Internet
Windows Server 2003 web Edition Driver Problem...
You can download it here:
http://www.microsoft.com/downloads/details.aspx?FamilyID=22cfc239-337c-4d81-8354-72593b1c1f43&displaylang=en
You should always run Windows Update until your system is fully patched.
But, you might want to check with your sound card vendor to be sure there are drivers for W2003. They may be different than the XP versions.
Jul 18, 2008 | Microsoft Windows Server Standard 2003 for...
RealTek HD Problem win2K3 SP1
This might be error due to the DirectX  problem some sound card drivers works with addon softwares by installing DirectX 9.C will solves ur problem. After installing DirectX install sound drivers.
hope this will be helpfull
Bye...
Jun 04, 2008 | Microsoft Windows XP Professional With...
Plz be posted , in case of server installation - it is veryu delicate the above situation may occur only for the following points .
1.intallation files were skipped by user manually (due to bad CD)
2.Improper Installation (in case root directory contained XP os and installation was overridden windows folder )
3.using a crack patch to OS for CD-KEY.
check and let us know.
Regards,
Sushil
May 27, 2008 | Microsoft Windows Server Standard 2003 for...
Microsoft Windows Server 2003 Enterprise Edition x64 for PC Logo
81 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
