Question about Whirlpool ED5VHGXM Side by Side Refrigerator
Water running from under fridge. all water lines off
Water running out from under.all water lines off
  • 142 Answers
Condensate pan is gunked up and no where for condensate to collect. Clean the pan on top of the compressor and make sure there is no gunk or dirt collected there.
Posted on Jun 02, 2009
My ice and water out of the fridge taste bad
I recently had a customer who had bad tasting ice. She'd had technicians from the place she purchased her fridge out, and they replaced the supply lines to the fridge, added water filters, but the problem persisted.
The problem actually started under the house. The fridge is on a wall opposite the kitchen sink and the dishwasher, so it was the only thing using water at the end of a long run of copper line, about 10 to 12 feet of it. Since the ice maker doesn't cycle allot, the water in that line was getting stagnant.
I ended up running a new line from a supply line in the adjacent room where the washer was. It was much shorter and didn't leave the fridge at the end of the line. And that was the end of her problem.
Check the supply line under your home if you can. If there's no other way around it, but that it be at the end of a long run, try running a smaller line to reduce the amount of water that sits in the line, and flush it often.
Hope this helps.
Oct 16, 2012 | Frigidaire FRS3R5EMB Side by Side...
Hi, I have a refurbished RFG297AARS from Samsung that we purcased as a refurb about 7 days ago. On day 1-3, a puddle of water formed under the back right underside of the fridge, without the water line...
Chances are its either the drip line or drip tray.. there is a drain to route the condensation pulled out of the fridge and freezer that leads to a drip pan underneat the unit.
Either the drip tray was not installed.. reinstalled incorrectly or the drain tube is leaking or no longer directed to it, or it's overflowing due to excess condensate.
Best of luck!
Apr 26, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
Water runs out the frezzer side when the door is closed onto the household floor.
Look underneath the fridge and check the drain pan it's probably full. Also check your hoses when you under there. You have a line running from the wall underneath the fridge and up to the water supply system. Check for any lines that might be leaking or have come loose and causing the problem.
Dec 22, 2010 | LG LSC26905TT Side by Side Refrigerator
Hooking up water line to LG LRSC26920TT - water runs great through line, but once connected to fridge, no water runs through line in fridge - no water comes out when trying to fill a glass. No water...
dissconnect water line coupling behind lower kick plate under door. push water dispenser; and sell if water flows out line. keep a towel handy. it there is water; then, the problem is in the door itself. of course, make sure the water solenioids are working.
Apr 17, 2010 | LG LRSC26925 Side by Side Refrigerator
I know this sounds really stupid, but I think that my water line is frozen for the ice maker in my kitchenaid superba fridge. Everyone is suggesting using a blowdryer to defrost the line. My stupid...
The water line would run up the back of the fridge.
I don't know that the line could freeze, but I'm no pro. I just wouldn't think that would be possible.
Has the fridge been moved lately? Maybe the water line got pinched? Try checking where the water line runs, maybe it got pinched somewhere else (under counters/sink, etc).
Jul 31, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice maker and the water dispensor is not working.the fridge is only 6 months old
does your plastic water line run from underneath your sink to fridge? if so maybe you put something under sink and crimped the little plastic water line. pull refride out some and then try water dispenser
Jul 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
There is water dripping filling up the bottom under the salad container. The model is a LRTN22311TT.
Remove contents of fridge and check the drain line running down the top back of the back of fridge and follow to lower section of fridge (usually a back ledge or under the crisper sections) and locate a small round drain hole. Also, check to see that the drain collector (funnel looking thing at top back of fridge section) is located under the freezer defrost drain opening, to allow water to flow through the fridge into the drain pan under the fridge.
If something has obstructed the drain funnel, path, tube, or lower drain hole, remove the blockage to allow water to drain into underneath of fridge into drain pan for proper evaporation of water produced from the usual daily defrost cycle of fridge/freezer.
If that is not the problem, it could be that you have a leaking water supply line for your ice maker and you'll need to see if the freezer is allowing excessive water to flow out of the ice maker into the fridge section.
Another simple check/solution is that the fridge is not properly leveled, meaning that the front of the fridge should be slightly higher than the rear to allow for proper drainage and self closing of the front doors. This will help keep the water flowing in the built in channels and drains.
A perfectly level fridge isn't the right way to install most moveable refridgerators, while built in fridges (Sub Zero, etc.) are designed for plumb and level installations for proper functioning and use.
Apr 09, 2009 | LG LRTBC1825T Top Freezer Refrigerator
Kitchenaid fridge (ksrw25crss02)icemaker slowly stopped working, decreasing in the amount of ice it made until finally no ice at all. also, water trickles from water dispencer.
hi kev215,
welcome to fixya.com.
Huuum at your service.
You said, the ice maker slowly stopped working, decreasing in the amount of ice it made until finally no ice at all. also, water trickles from water dispenser.
The first thing I would ask is when did you last change your water filter in the fridge?
Or if it's an older fridge with an inline filter behind the fridge!
check the shut off valve for the water line that leads to you ice maker. under the sink or in the basement or where ever the line comes from. I've seen where someone turned the valve a little clockwise unbeknown to the home owner and stopped or slowed the water flow.
The water line should be checked too, for any kinking that may be running behind the fridge or some unseen place!
How old is the fridge??
Let me know,
Thank you Huuum
Sep 23, 2008 | KitchenAid Refrigerators
Cant get water out of the fridge door
hello allamericananp,
Let me know,
Thank you Huuum
Sep 23, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Whirlpool ED5VHGXM Side by Side Refrigerator Logo
94 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
