We have emptied and cleaned the ice drawer, but it seems to be on the ice as it comes out of the maker
What is the model number? Thanks, John Tripp Appliance 911
SOURCE: Ice maker drawer for sub-zero 632
Look at both those tracks on each side. its likely one or both are cracked or broken. Each one has 2 screws holding it in. To put the metal hange back in the tracks, you must get new tracks (if broken/cracked) then hold the2 tracks onto the bucket carriage...then stick thewhole thing in as an assembly, hen put the 4 screws back in. there are 2 more small screws way in the back (one on each side), but they do not have to be removed, only there to guide the racks in properly. these tracks are only about 7 bucks apeice, and shouldn't take long to chamge. Good Luck!
SOURCE: Kitchenaid superba side by side ice maker stopped producing ice
This is a picture of an ice maker module. Which is behind the white plastic cover. The cover just pops off. Look at the two little tabs in the center of white wheel. If yours is twisted, pressed together, or one is broken then the module is bad. If not, take the icemaker out and let it set for a few hours to let it defrost. Put it back in and see what you get. The ice maker won't cycle and fill with water until it gets below freezing so you will have to wait awhile. It can be started manually by inserting a jumper wire into terminal T and H. Let it start to cycle for about 10 sec. then pull the wire out. At the end of the cycle it will fill with water then wait for it to freeze. Also, if door was left open check all vents in fridge for ice build up. This cause cooling problems of they are plugged. Let me know what you find.
SOURCE: Ice maker doesn't work
Help, help , help, Please.
I have one of the REFRIGERATOR MODEL: RS267LASH made by SAMSUNG about two years old.
For the past few months, I found that all of the accumulated ice in my ice maker had slightly melted and re-froze together, causing the spiral coil to lock into place. I had to pick at the ice in order to free the bucket from the freezer and completely remove all the ice.
It looks like the ice tray fills with water but doesn't turn over sometimes to empty the ice out. When more water is added to make more ice is dispensed into the tray and it overflows down into the bucket, out the chute and all down underneath the ice tray.
Email: [email protected]
Thank you
SOURCE: i have a Whirlpool refrigerator
The ice door located in the ice chute in the door is not closing. Allowing wam air in your ice bin which melts the ice at the bottom of your bin there for making a huge ice dam. Replace cirercut board at cost of 295.00
SOURCE: my model 650 subzero ice maker won't make ice
make sure your ice tray in in the righ position. really important. the tray have to press the ice maker switch. or bad ice maker or bad water valve. also make sure to press the ice maker key. in the display. ONLY IN NEW MODELS
