Question about Garden
What is the correct fuel mixture for this machine
What is the correct fuel mix for the Stihl FS 44 petrol powere strimmer
  • 1 more comment
  • Anonymous Mar 19, 2014
    every once and a while it acts like it is normal,and then goes back to its old running like at a quarter power
    it acts like it is running at quarter power,but once in a while it gets a burst of energy and acts almost normal,but then goes back to running poorly
    what is thwe fuel mix
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 8 Answers
Every Stihl I have ever touched requires 40:1 fuel mixture.
Posted on Jun 02, 2009
What is the petrol to oil ratio for this engine
http://www.csgnetwork.com/oilfuelcalc.html
In the Mix
All STIHL gasoline-powered equipment uses a 50:1 gasoline/oil mixture. The chart below can help you figure out the correct measurements to use. For high-performance fuel that requires no mixing, choose STIHL MotoMix® premixed fuel.
Jul 20, 2015 | Garden
What is the fuel oil ratio for this machine
In the Mix
What is the air n fuel mixture for a stihl FS 44 weed eater
50:1 ratio on all stihl products... If that helps
Aug 08, 2013 | Stihl Garden
Weedeater idles but bogs when i press the throttle.i rebuilt the carb,changed all fuel lines and gourments and removed muffler,cleaned screen.replaced plug. Still no change.I noticed a small amount of fuel...
as long as your fuel mixture is correct, thier is an air fuel mixing screw on the carb locate it adgust it wial it is running u can hear , see and smell the diferance how it is running .check proper plug gap and condition.good luck
Feb 25, 2013 | Garden
What is the petrol/oil mixture ratio for a STIHL FS 36 R Grass Strimmer?
Hi, 50 to 1 with stihl oil or 25 to 1 with any other brand 2 cycle oil. Hope this helps, regards Phil.
May 30, 2011 | Garden
Echo chainsaw 16in. model 280 E(P) or 290 EVL(P) \r\nLooking for the correct oil and gas mixture ?
The mixture for most echo products is 50:1 ratio. You can use the Stihl fuel mix in this unit .. The Stihl fuel mix is also a 50:1 ratio.
Mar 29, 2011 | Echo Garden
Mcculoch mt 300mcculoch petrol strimmer carb two adjustable screw bolts ones for petrol, ones petrol & air mixture hich one does which
Actually both screws are for petrol mix. The screw closest to the engine is the Lo side. Lo side jet provides petrol at idle and during the ramp up to speed. Hi side jet (closest to air filter) only effects the mix at high speed.
From McCulloch, these were set at 1 1/4 turns out.
Sep 16, 2010 | Yard Machines Garden
What is the oil to gas mix ratio ?:? stihl fs 45
If memory serves, Stihl recommends a 50 to 1 mix ratio on the gas mixture...( 2.6 oz oil to 1 gal fuel ) I usually run mine just a smidge richer and run a mix of 45 to 1... ( 2.8 oz oil to 1 gal of fuel ) I also add about 1/2 oz of "Stabil" fuel stabilizer to the mix (holds down gumming of the fuel and keeps things running sweet)...hope this helps... ;-D
Aug 08, 2010 | Garden
Oil to petrol ratio?Thanks Partner B300BX strimmer
If you are using stihl oil then the mix is 50:1
Jul 31, 2010 | Husqvarna Garden
Need to know petrol - oil ratio for mixing 2-stroke fuel for Electrolux-Partner B300B garden strimmer. The manual gives every kind of technical and other info the user is never likely to need; except this...
Hi There, I'd recomend using Stihl Two Stroke Oil. Mix it at 50:1. Its the best stuff you can get. Never let me down yet, used in all my chainsaws and strimmers.
Rich
Aug 15, 2009 | Garden
Garden Logo
982 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
