Question about Polaroid FLM-3201 Television
No power, no sound , no picture. Is there a fuse?
I am able to fix most things but need some guidance on this.
Thanks.
  • 44 Answers
Check the  back about half way dpwn
you will see a little trap door, pry it open with a screw driver and you should see the fuse. if you can't find the fuse take off the back black plastic cover ot go online  to vance baldwin.com and you can download the service manual for this tv
Posted on Oct 24, 2007
  • lOU mARGOLIS Oct 24, 2007
    if the fuse is burnt and you replace it and tit blows imediately , replace the power supply board.
Loud Pop Vizio P50HDTV10A 50 in.
sounds like the power supply board..could be the system board, but sounds more like the power supply board..this unit still under warranty?
Oct 20, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
42'' samsung plasma. no picture, sound only. Power supply board?
I don't think those are fuses but if something is melted chances are it won't work
Jan 31, 2018 | Televison & Video
Philips Magnavox 9P5040 C104. Green power light- no sound/ no picture, fuse good.
Hey my tv is doing the same thing. The green power light with no sound and no picture and the fuse is good. I was wondering if you fixed the problem and if you could tell me how to fix mine.
Nov 02, 2009 | Philips Magnavox 9P6034C 60" Rear...
Picture appears only as a thin, horizontal line...
chk vertical amp /vertical drive i/p from oscillator/power to it/power to vertical amp/chk dry joints-hot area/look at vertcal amp capacitors-swelling etc
Jul 04, 2009 | Akai Televison & Video
Phillips 64p9161006 Powers on but no picture or sound
Was the screen shrinking or expading prior to failing? Or do you here a chirping sound. If so check www.TvRepairkits.com for a fix.
Mar 21, 2009 | Philips 9P6444C 64" Rear Projection...
Proview rx 326 model 3200 tv sound but no picture
I just fixed my proview 3200 that doesn't have picture but with sound.
First, thanks for the tips I got from this forum. I checked the 24v from the power supply board and that's perfectly working fine. I then check the fuses in the Inverter board. There are 4 white fuses (2amp I guess, i cant remember) and 1 black fuse (1amp/76v just behind the wire connector going to the power supply board). The black fuse is the one that blown out on my tv. This fuse supplies power to the LM358A IC. I know its not right but I just solder a thin piece of wire to short circuit this fuse. I'm lazy to drive to RadioShack to find this fuse. :)
....and that worked beautifully. Check the picture attached for what I did.
May 27, 2008 | Proview PA-32JK1A 32 in. LCD Television
Mitsubishi YS-5075
yes, this sounds like a fuse blown or open. What model is this a VS or YS?
Mar 10, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Philips 60PP9202/17F Fuses are gone
I can't believe he pulled them all, but here's a list of all the fuses and their ratings from the service manual:
S 1000 Fuse, T 5A IEC
S 1300 Fuse/Clip, 5 Amp, 250V
S 1801 Fuse, 2 A, 250V IEC
S 1804 Fuse, LT 1A, 250V, IEC
S 1805 Fuse, LT 1A, 250V, IEC
S 1700 Fuse, 2 A, 250V IEC
S 1701 Fuse, 2 A, 250V IEC
1003 Fuse, 500MA, 50V, UL
Jan 12, 2008 | Philips 60PP9202 60" Rear Projection...
Sony KV32s45 sudden failure
I really have to say there is no miracle cure for TV's I have 20years of experience in fixing TV's I don't suggest for you to try to fix this as TV's run on high voltage and you could kill yourself.
If you really cannot find a tech to check it for you the only thing you can try is to check for a broken fuse.
You Must Take Great Caution.
If you are a person that like to take things apart you may try to take the back off .
Start by disconnect the power cable and follow the main power cable inside , normally it goes where the main switch is located and there you should find a Time Fuse normally the value is around 2.5 amps T for time it should say on circuit board & on fuse.Check for a faulty fuse.If faulty replace with the same type fuse and before you plug it in put back all covers than you may try to put on TV.
If fuse is good than fit back cover and take to a professional.
Nov 29, 2007 | Sony KV-27V55 27" TV
Polaroid FLM-3201 Television Logo
143 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
