Question about Individual Professor Teaches Microsoft Office 2003 (office2k3) for PC
No picture I just installed Prof Teacs Office 2003 to 32bit sys w/Vista & downloaded necessary drivers for compatability. I also placed shortcuts on desktop. Everything works fine but the instruction screen remains dark. I get sound & dialog box but no picture. What's up? Mike
If every thing works fine, then you should go for the change of windows themes or appearances from Personalize folder in Control Panal,
Try and inform for further quiery
Posted on Jun 03, 2009
Is my old Lexmark x5470 compatible with MS Office Professional 2007?
MS Office is only bundled set of Office applications software eg. Winword, Excel, etc.......It had nothing to do with the compatibility isuses with any devices like printers, fax or scanmner, etc....
Compatibility isuses are with the Operating Systems (OS) eg.XP,Vista, Win 7 ... on your PCs. Different OS require different versions of Devices "Drivers & software" . If you can successfully install your device Drivers & software for the AIO "Lexmark x5470" on your PC Operating System, you should be able to print, scan or fax from MS Office applications.
Hope it helps.
Jun 13, 2011 | Microsoft Office Professional 2007 Full...
When i install vga compatible driver then computer ask me to provide ati2mtag.sys file
hi.
mean that you need to download the necessary drivers
(Download in accordance with the display card used by your computer)
TQ
Jan 01, 2011 | IBM ThinkPad T42 Notebook
Print Shop 21 will not work on Windows 7 operating system is there a fix?
When a ‘clean’ install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 64-bit version of Windows 7, with two incidents.
1. If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant” in Windows 7 will display this message
this program has know compatibility issues
To continue with the installation, select "Run Program". After .NET Framework 1.1 is installed, the necessary updates will be pulled from the Microsoft Windows Update Service.
2. After .NET Framework 1.1 is installed, the "Program Compatibility Assistant” in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 64-bit. To continue with the installation of .NET Framework 1.1, select "Run Program".
NOTE: Even though the Print Shop 22 Vista patch, which can be found here
Download Vista Patch For The Print Shop 22 and PrintMaster 17 Disk Versions
can be installed on a 64-bit version of Windows 7, the patch will not fix the problem with the Amyuni Document Converter, as it does on a 32-bit version of Windows 7 (see above). So, it will not be possible to use the 'Save As PDF' option with Print Shop 22 on a 64-bit version of Windows 7. Instead, it will be necessary to install an alternate PDF driver, then Print to PDF, as is described in this FAQ
Save as PDF vs File | Print to PDF
So far, the only other known incompatibility with Print Shop 22 on a 64-bit version of Windows 7 is that Print Shop 22 cannot be run from a shortcut on the Dell Dock that is provided with many Dell computers. A Print Shop 22 shortcut can be placed on the Dell Dock; but, attempts to start Print Shop 22 from that Dell Dock shortcut will cause several incompatibility messages to be displayed
Aug 04, 2010 | Broderbund The Print Shop 21 Deluxe Full...
Image Mixer Ver 1.5 for Sony DVD Handycam. How to run it in Wndows 7 Home Version
hello.
this may work with your windows 7 install.
have you seen this page?
http://support.sony-europe.com/dime/downloads/downloads.aspx?site=odw_en_GB&f=ppckg_uninstll
and under "overview features" it says:
"Picture Package" and "ImageMixer Ver.1.5" supplied with Cyber-shot or Handycam are not compatible with Windows Vista. For users who have accidentally installed these software into Windows Vista, we are offering "Picture Package Uninstaller" as the uninstallation tool."
again this MIGHT work with your windows 7 install.
also you might try the compatibility mode:
Right click the shortcut you use to start the program and select the compatibility tab for you options.there.
Feb 17, 2010 | Computers & Internet
Issues with Vista
If it is not compatible, you mean there are no drivers for it?
The only thing you could try is to install the XP drivers in Vista in the compatibility mode (assuming you have XP drivers).
Sep 03, 2009 | Computers & Internet
Error 1606: Can not locate network location; during Adobe Acrobat Reader 9.1 and Microsoft Office Standard Version 2007 install
On another computer with a cd/dvd drive hooked up to the internet Go to HP.com/support and, download the drivers for vista for your computer then install them on your malfunctioning computer
May 29, 2009 | HP Computers & Internet
Vista driver for Intel QX3 Microscope
Instruction for installing the QX3 or QX3+ Microscope with Vista
Note, DO NOT use the software from the CD that came with the microscope.
DO NOT plug in the QX3 microscope until Step 4.
Step 1. Install the QX3PLUS.EXE software downloaded from Intel:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&Inst=Yes&ProductID=160&DwnldID=4419&strOSs=All&OSFullName=All%20Operating%20Systems&lang=eng
Step 2. Download and install the QCODINSTL.EXE software from:
http://www.intel.com/support/intelplay/qx3/sb/cs-016002.htm
Step 3. Download and extract the QX3 Drivers from:
http://hyperslug.s3.amazonaws.com/IntelQX3driverXP.zip
Step 4. Now, plug in the microscope.
When the "Found New Hardware" wizard appears, select "Locate and install driver software (Recommended)", a message "Installing device driver software" will appear. If you click on "details", you will see "Searching Windows Update", after a while you will be able to select "I don't have a disc. Show me other options" and browse to the folder with the extracted QX3 drivers from Step 3. above. The hardware should install successfully.
Double-click on the QX3+ icon on the desktop and the program should run.
Jan 10, 2009 | Intel Play QX3 Monocular Microscope
I have QX3 computer microscope installed on my vista but it doesn't work
I could not find driver. I placed in Windows 98 compatibility mode on my Vista. I right click Intel Play shortcut...go to "Open File location". Find QX3 application....right click. Go to properties...Compatibility tab and choose windows 98 / Windows ME. Click ok. Worked for me hope it works for you!
Dec 16, 2008 | Intel Play QX3 Monocular Microscope
Driver for compaq cq50-106au with win xp prof
Your audio card is the conextant High Def Audio
The XP drivers for this card are here
ftp://ftp.hp.com/pub/softpaq/sp32501-33000/sp32823.exe
Hope that helps
Aug 22, 2008 | Compaq Presario Notebook
Belkin F5D7132: cannot open exe program
Windows Vista; belkin says it's compatible. install program downloads, but desktop shortcut does not appear. When I attempt to open the file, I get error message "IP802MR MFC application has stopped working." IP802MR is the name of that file.
Jun 17, 2008 | Belkin (F5D7132) 802.11b/g Wireless Access...
Individual Professor Teaches Microsoft Office 2003 (office2k3) for PC Logo
56 people viewed this question
Top Individual Computers & Internet Experts
john smith
gary433
ka4iup
ka4iup
Are you an Individual Computer and Internet Expert? Answer questions, earn points and help others
