Question about Samsung LE32R71B 32 in. HD-Ready LCD Television
Samsung LE32R71 OSD menus show screen corruption
Hi, I am unsure how it happened however I now have an annowying line of pixels flickering showing up in any tv input and resolution, but most annoyuing is the fact that everytime I bring up the OSD a square portion of the screen arounfd the OSD text corrupts and flickers, as if the portion of the OSD area was showing up corrupting the screen, making reading hte OSD menu quite difficult. The screen corruption also appears below the text in the service menu as well. I have exactly the same problem on the same model. Any idea? Thanks.
  • 934 Answers
SOURCE: samsung 42" plasma hdtv
Black bars to pink dots are all symptoms of the logic board failing. Samsung p/n# BN96-02042A and this isn't a repair for the novice. The board itself contains many small smd caps that are the likely culprits. But the fine wire traces on this board make replacing the caps nearly impossible without some very sophisticated smd removal equipment and a magnifier that could double as a hubble telescope. Most shops merely replace the board. They're about $180 plus shipping and core charges. If you want to price it goto vance baldwin's site and enter as a guest. Select parts and enter the part number above. It's about 1-2 hour install and re-assemble barring any complications. Find a reputable shop and take the unit in yourself. That will help keep the cost down, but expect that this one will cost in the neighborhood of $375 - $450 and could run higher if anything else is found wrong. If you need some help finding a good shop try NESDA, National Electronic Service Dealer's Assn., for a member shop near you. Good Luck Bill
Posted on Jun 08, 2007
SOURCE: Samsung plasma PS42D5S
how do you adjust the voltage settings regardss dave
Posted on Jan 27, 2008
  • 109 Answers
SOURCE: Samsung Model: HP-R4262 42" Plasma Problem, pink pixelation/ghosting
Wow, I've been an installer and salesman in the consumer electronics industry since before the first plasma TV came out (Phillips 42" and Fujitsu 42" in 1996) and this is the first time I've ever seen that kind of an answer. "Take this to a repairman and he can add more plasma" what is the repairman a doctor. If it were that easy no one would ever have to upgrade or replace their screens. You can't add more plasma to a screen, if you don't believe me call Samsung and ask them for yourself like I did. I was actually so dumbfounded by your answer that I called a tech friend of mine at Samsung and asked him, his answer; "does this guy work for you?" I told him no and he said, "I was going to tell you to fire him because that's the dumbest thing I've ever heard anyone tell a customer".
What you need to do is take you plasma TV to an AUTHORIZED Samsung dealer/repair shop and inquire about the hazing/ghosting problem with them. Follow this link to find an authorized repair center near you:
Posted on Jun 19, 2008
  • 44 Answers
SOURCE: Flickering Pixels on Plasma
The top y drive cable is loose or dirty. Delicate job to fix.
Posted on Jul 03, 2008
  • 58 Answers
SOURCE: I have 2 intermitant flickering white lines across
if the lines go all across the screen and they are like one or two pixel wide,
that is a symptom of a bad lcd panel
Posted on Apr 25, 2009
No osd menu on samsung sde-4001n dvr
yea no osd menu, it was the same for me, but after a couple test, i found thats because it does not detect de vga cord correctly, duno why only with this model, if you use kvm or a dvi to vga cord, happens , i connected a old vga lcd screen and wala! , maybe after a firmaware update may fix the problem :)
Apr 22, 2012 | Samsung Sde4002 8 Channel Dvr Security...
I have a 204b moniter that the lower half of the screen faded to black then shows two half screens that are filled with so many vert lines that you can't see whats on the screen.
the screen is toast. if its black and not showing whats suppose to be on the other half.if you tried restarting the computer and unplugging the monitor and it is still happening then there is nothing to do. monitors are not built to last long, the cheap ones. it is good to get one with a good warranty because the pixels go out.
Sep 29, 2009 | Samsung Computers & Internet
Laptop screen constantly flickers and whites out
Your Bulb is DUE, you need to change it, Don't do it your self contains mercury. Your LCD is good IF you do not have bad PIXELS. This white and pink lines shows as pixel problem but it migth also short on LCD, if you placed something heavy on Laptop. You may remove and sent the LCD for repair or all laptop to tech.
You may also need to check inverter. I give service around the Country but it is up to you. My company name is JMC TECHS INC. Registered in Miami Florida. (Check jmctechinc@gmail if you like to contact me.
Aug 15, 2009 | Toshiba Satellite Pro M300-S1002X Notebook
The problem of OSD Menus popping up automatically are usually caused due to a faulty switch in the Menu button which is getting switched on automatically.
This menu will not harm the computer but constant OSD menu will most probably lead to permanent damage to the pixels in the LCD screen plus it is a constant irritation to your eyes which are most precious.
This problem can be rectified by replacing the faulty menu switch. Hope this solves your problem Thanks.
Jul 23, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
On a Samsung HL-R5087W TV i have 10 rows with 8 lines per row going across the screen vertically. These lines are Black. Please HELP!!!
Single Pixel width Verical Lines in all video inputs including OSD
This is caused by a defective DMD Board
Jul 22, 2009 | Televison & Video
Samsung LNT4669F Pixcels Flicker
As long as you only see these artifacts while watching certain broadcasts, the TV is fine.  If these lines are present no matter what you are watching, then you have a problem. What you are seeing is signal related and there isn't much you can do to fix that. Think of it like a scratched DVD; you will see strange things on the screen at times and many think it's the TV when it's only the signal from the device to the TV that is corrupt.
I have thought of one possible solution and this will depend on your TV's ability to slightly stretch the picture in vertical/horizontal directions.  If your TV will let you, you may be able to raise the top of the picture a cm or so to hide the flickering.  Check the TV's onscreen menu for anything to do with picture alignment.  This is nothing to do with aspect ratio though so ignore that.
Mar 24, 2009 | Samsung LNT4669 TV
Horizontal lines
i suggest you change video board .
Apr 19, 2008 | Samsung SyncMaster 152N 15" LCD Monitor
LN-T4665F 46 in. LCD- Black Line across screen
The set is under a year old and is under warranty. The LVDS cable inside these sets have a history of coming loose. The problem could be the panel. Either way, the set is the problem and needs to be looked at. This set is worked on in the home and does not need to be taken to a shop, so, you can still use it. Contact Samsung at: 1-800-SAMSUNG Hope this helps.
Jun 03, 2007 | Samsung LN-T4665F 46 in. LCD Television
Samsung LE32R71B 32 in. HD-Ready LCD Television Logo
137 people viewed this question
Jerry Greenberg
Jerry Greenberg
