Question about Toshiba TLP T50MU Multimedia Projector
Yellow/green hue on projection
Projector projects a greenish yellow . . . was in the shop 6 months ago and they could not reproduce the problem. I have cleaned the air filter and the lamp only has 400 hours on it Adjusting color settings does nothing. Any ideas?
  • 2,237 Answers
The light filter on the blue lcd panel is fried due to excessive dust and heat. unfortunately, you'll have to replace the entire optical engine.
Posted on Nov 11, 2009
Screen has greenish yellow hue
Suspect it has like the 60V500, and others before it a bad optical light engine.
Dec 21, 2012 | Hitachi 60V710 60" Rear Projection HDTV
Panasonic projector Pt-LB60u has a greenish hue around part of the edge of the projection. What would be causing this?
upon the bulb life running out on pani projectors and proj. tv's the lamp set will start to produce a green hue get a new lamp bro. try this web site i highly recomend them www.electrified.com
Feb 08, 2010 | Panasonic PT-LB60U Multimedia Projector
Toshiba Rear Projection TV picture color is now a greenish hue
Hi, I used to work in Best Buy and one of the key things about rear projection TVs and the reason they push those service plans on you is that the tubes/colors need to be calibrated each year. You can do this yourself by checking out the following website:
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=3229
If you are not able to adjust the convergence using the remote you will need to replace the convergence chips.
Typical Symptoms
1) Convergence menu does not work for one or more colors.
Such as: Red moves up,down, but left or right fails.
2) Screen is bowed looking.
If you have one or more of the problems above you need to replace the convergence chips. You can get a kit and instructions from www.TvRepairKits.com
Hope this helps :)
Sep 12, 2009 | Toshiba 50H82 50" Rear Projection...
It went this greenish yellow hue
Try resetting the monitor to defaults if possible. If you still have the greenish yellow hue then at that point, try another known working monitor on the computer, if the hue goes away then you know the original monitor is bad, if you still have the greenish yellow hue then you know the video card is bad.
Aug 19, 2009 | Kogi L7CH Monitor
Tv, has yellow hue,lacks brite day and night
Replaced light engine. Be sure to note if model has an A at the end of it when ordering. They use different parts.
Aug 11, 2009 | Hitachi 51F59 51" HDTV Projection...
Toshiba 65H80 has yellow hue.
Check you HD inputs or source. Sounds like the red stream is missing; maybe a loose cable.
Nov 17, 2008 | Toshiba 65H80 65" Rear Projection...
Nec projector vt 660
could be bad bulb is it setting in right is coler wheel freeley moving
Oct 06, 2008 | NEC VT47 Multimedia Projector
JVC Model AV-48P575 Green/Yellow Screen
i would check the red color first it sounds like your loosing red
Feb 22, 2008 | JVC AV-48P575 48" Rear Projection...
My Sony VPL-X600 projector has a green tint over the whole picture
the problem you are having is the RED lcd has failed and needs to be replaced only sony can do this you must contact sony for the nearest service center for repair. unfortunatly that is the only solution.
Feb 10, 2008 | Televison & Video
Green spot on picture
Greenish yellow spot only means one thing. You have a defective lite engine. The only fix is to replace the engine. This part is very
expensive. Average cost $835.00 Part number A-1606-008-A
Best regards
circuitcity
Dec 08, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Toshiba TLP T50MU Multimedia Projector Logo
206 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
