Question about Hitachi Ultrastar 15K147 500 GB ATA-100 Hard Drive
Hard drive install new hitachi deskstar 80gb hard drive as master no other drive ran install cd rebooted and finds hard drive next system configuration goes as far as pri: master disk: LBA mode 4 the four is underscore and fashing tried with old hard drive and system works fine no windows o/s on new HD
  • berend Oct 24, 2007
    almost there just have to find missing driver so that o/s will install thank you for your assistant
  • 55 Answers
Some hard drives will only work as a single device when jumper-ed as "stand-alone", try finding this option or alternatively, remove the jump altogether and try again.
Posted on Oct 23, 2007
I have a Deskstar 80GB hard drive and I am adding another drive to the computer. How do I set the Deskstar to the Master. I'm not sure what the pin settings should be?
If you have the EIDE cables on your PC, it is easy. Your drives need to have their jumpers in the CBL SEL (cable select) positions (identified on the case on the sticker) and then you simply connect your Deskstar to the Master connector, and your other drive to the Slave connector.
Feb 12, 2011 | Hitachi 80GB IDE Hitechi DeskStar 7K160...
I want put my Hitachi Deskstar 7K250 80GB Hard Drive from a t2885 emachines on a HP/Compaq K8N8X-LA mother board without losing my data.
You won't loose your data Why wold you think you would? once data is written to a hard drive it remains there until it is removed be a user, it works on the same principlea a floppy, the magnetic coating on the surface of the anodized disks inside of the HD are written to and retain memory of the data, the only things in a computer that won't keep their data are the RAM chips which need electricity running through them to work.
Dec 07, 2009 | Hitachi Deskstar 7K250 80GB...
HItachi deskstar Hard disk 80gb 7200 rpm
check the power cord of your hard disk. It should be tight not loose, if not solve then change the power cord.
Nov 25, 2009 | Hitachi Deskstar 7K80 Hard Disk 80GB,...
Cloned hard drive "C" (WD 40GB) to A Deskstar 8oGB using external enclosure. When I remove the old drive and install new drive and boot up I get Msg drive 0 not found retry or enter setup. If I enter setup...
there are few thing you ahve to keep in mind
there are two type of hard disk
1. IDE
As per your hdd capacity it should of IDE type.
Now there are two IDE slots on motherboard. One is Primary and other is Secondary
You can fix two hdd with one IDE Slot that mean you can fix up upto faour IDE hdd at a time
Now again there are Primary master and Primary Slave
Secondary Master and Secondary Slave
Now You have to examine what was the location of previous hdd
1 Primary Master
2 Primary Slave
3 Secondary Master
4 Secondary Slave.
Now you have to make a HDD master or Slave.
just in between data cable connector and power cable connector there is a jumper. that specify the master or slave. do reply me if it works well thanks
Oct 01, 2009 | Hitachi Deskstar 7K250 80GB...
What settings do I need to turn an 80gb into an external drive
If using as an external USB drive it needs to be set as a master.
Sep 24, 2009 | Hitachi 80GB IDE Hitechi DeskStar 7K160...
Trying to get data off an IDE drive from a dead system
this MS link will help you configure it so you can read it
Oct 27, 2008 | Hitachi Deskstar 7K80 Hard Disk 80GB,...
Hitachi 80GB hardrive - error 6
Install your previous hardrive as a slave, secondary drive to your new one, or easier still, buy an external enclosure for it and connect to it via usb
May 16, 2008 | Hitachi Deskstar 7K80 Hard Disk 80GB,...
Hard drive
hi dear
use a cd booting
in command prompt c:\
type c:\fdisk /mbr
to fix your master boot record\
and make your partiiton active.
after that installing your windows XP
Mar 15, 2008 | Maxtor Hard Drive
plz connect the another Hard disk to the primary drive and restart the PC.
Sep 14, 2007 | Hitachi Deskstar 7K80 Hard Disk 80GB,...
Hitachi Ultrastar  15K147 500 GB ATA-100 Hard Drive Logo
131 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
