Question about ASUS VW192S Monitor
NO SIGNAL PROBLEM
I bought recently one screen for my pc. Model : ASUS VW 192S. Every time when i try to open my pc the display shows the words ''NO SIGNAL'' and doesn't open. I tried everything connection cables, AC cables and whatever has relation with cables...nothing happens...i know that the system works normally because the buttons ''CAPS LOCK AND NUMS LOCK'' flashing when i push the buttons...only the screen doesn't open and every time shows the same ''NO SIGNAL''...could you give me any solution??? Thanks...
Open your cabinate and search for the mobo battery , it looks like a circular watch battery. Remove it and put it back in after 5 mins. Every thing back to default!!
Posted on Aug 31, 2011
  • 4 Answers
Please check whether the monitor is set to the correct settings. If you feel its incorrect, most LCD/TFT monitors come with an auto set up button which will restore the display to one that usually works. In case it still doesnt work, you might need to connect your pc to a different monitor and check the display settings. You could also try to download the drivers for this monitor and then re-connect the monitor and see if it works.
Posted on Jun 02, 2009
How do i open a cd tray on a asus pc notebook?
Look at the cdrom door and see you will find a small hole; use a paper clip bent straight; insert it straight and you will feel contact with "something" push in gently and the cdrom door should pop open.
Jul 18, 2014 | ASUS Computers & Internet
Display not centered, no access to vertical scroll bar
That's because the LCD screen is going bad.
I would have said the screen Inverter, but the LCD screen uses LED's as a Backlight, and uses no screen Inverter.
http://www.screenaid.com/asus-eee-pc-701-laptop-lcd-screen-89-wsvga-glossy-led-p-36730.html
The above is just an example. Shop around for a better price, but advise make sure it is a reputable dealer. (I do NOT advertise for anybody)
1) http://pskillenrules.blogspot.com/2008/05/dismantling-eee-pc.html
(You can click on the photos to enlarge)
Found this recently. I feel number 2 adds to replacing the LCD screen, and number 3, also adds another idea for those who may be interested,
2) http://www.r3uk.com/index.php/tech-tips/34-disassembly-guides/78-asus-eeepc-model-4g-disassembly
Steps 1 through 10, THEN Steps 17 through 22. (You just want the LCD screen replace instructions)
3) http://www.youtube.com/watch?v=N8-BbOWVgXg
Regards,
joecoolvette
Jun 10, 2012 | ASUS Eee PC 701 Notebook
Asus A53S Blue screen problem
The most important Blue Screen of Death troubleshooting step you can take is to ask yourself what you just did.
  • Startup using Last Known Good Configuration to undo recent registry and driver changes.
  • Use System Restore to undo recent system changes.
  • Roll Back device driver to version prior to your driver update.
I would suggest to use a system utility tool like Reginout to fix this problem instantly.
Apr 30, 2012 | ASUS Computers & Internet
Asus led monitor model vh197 shows no signal on screen and no display ,screen became dark
Good Day Dasarathi!
Please check the VGA cable if its properly connected and make sure two screws are fixed to both end connecting the monitor and the video card.
No signal comes out when there is no signal from the video card to the monitor. That is why you need to check if the VGA cable is fix to both end.
If that did not fix it, you will need to open the casing of your computer. Disconnect the video card from the motherboard. Gently clean by wiping a clean clothe over the contact surface of the video card. Then, reseat the video card properly to the slot in the motherboard. Return the casing cover and connect the VGA cable again.
Just remember doing the above procedure is only when the computer is turn off.
Turn on your PC and see if that fix it.
You will need to replace the video card if by booting the PC you will hear a series of beep codes. If no beeps then you are lucky VGA cable is the faulty one.
Jun 09, 2011 | ASUS Computers & Internet
When in word and opening recent documents how many show up?
you can choose. click on the word cymbal in the top left corner and at the bottom of the drop down menu click word options. click on advanced on the left tab and scroll down to display. on the first line under display it says show number of recent documents and click the arrows until u get the number you want.
Sep 14, 2010 | Computers & Internet
ASUS eee701 - Display is flickering in black/white version
If the entire display is flickering, tha'ts typically a hardware issue. Try tilting the screen back and forth, or pressing gently on the area just above the keyboard to see if you can replicate the issue. If it flickers then, you've got a bad cable or a plug.
It's unlikely, but if it is a software issue you can try dowloading new drivers for the video card. Go to the ASUS website, enter in your model information, and see if you can find drivers for the video component.
http://support.asus.com/download/download.aspx?SLanguage=en-us
Hope that helps.
Mar 08, 2010 | ASUS Eee PC 701 Notebook
Blank monitor screen
It appears that this motherboard has an on-board video port, I would recommend unplugging the video card and try using the on-board video. Make sure that when you do this, the BIOS POST screen shows, if it stops making the beeps, but still doesn't show anything, you might want to reset the BIOS (using the on-board jumper, sometimes also displayed as CMOS reset or password reset). If it still beeps, it might be the RAM, and you might want to see (if you have more than one stick of RAM) if you can try unplugging one or the other, or even switch their locations. Good Luck.
Mar 25, 2009 | ASUS Computers & Internet
PCV-RS720G Sony Vaio : BFG 5500 installed and wont display
Hi there
Boot up in safe mode, F8 on start up, if it lets you into windows, go to the device manager and uninstall the graphics drivers, then reboot the pc, let the PC detect the new card and try install the drivers, have your driver CD in the CD drive just in case it needs it.
Good luck and thanks for using Fixya!!!
Feb 14, 2009 | Sony VAIO PCV-RS720G (027242658103) PC...
ASUS P5B-MX/WIFI MOTHERBOARD : NO DISPLAY
If you just bought it, I suggest you contact the store where you bought it to claim the warranty.
If you keep trying to find solution, you might do something that void your warranty.
Dec 12, 2008 | Computers & Internet
No Display for samsang sgh a 800
my Samsung A800 also lost its inner display recently. When I open the phone, the inner display lights up but fails to show any image. Outer display is mostly OK, once it had trouble to "lock" the image and after opening and closing the phone a few times the outer display showed the image with light and dark bits inverted.
Switching phone off and on restores the inner display most of the time, but the image only lasts until I close the phone.
Jun 20, 2007 | Samsung SGH-x427m
ASUS VW192S Monitor Logo
518 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
