Question about Hayward 250kbtu Ng Pool Heater - Inground
Pilot light is lit, but heater will not fire
Just started up the pool, got the pilot lit but the heater will not fire, it is an h250 about 10 years old. Help.
  • Anonymous Mar 12, 2014
    replace pilot generator pilot is lit but bureners do not fire
  • 864 Answers
Make sure thermostat is set higher than water temperature. Make sure pump is running and water is flowing through unit. If gas valve is not opening then flame sensor or gas valve is bad.
Posted on Jun 02, 2009
My laar hot shot natural gas pool heater pilot says lit but wont fire any more replaced pilot generator pilot that whole unit nice pilot but wont fire
problem isnt with the pilot generator. you have either an open safety withing circuit, lose wiring connection, or tstat issue
Aug 17, 2013 | Teledyne Laars Laars Lite 2 Pool Heater...
Every year I have a problem getting it to light. The pilot is lit but the heater will not turn on. It is 8 years old and I have been having trouble with it since day one. My pool guy comes out fires it up...
First, check the gas valve and make sure the valve in all the way to "on" not "pilot".After shutting to off for the winter, and not turning the valve all the way on start up could be it. If that is ok, check/replace the pilot generator next to the pilot lite. One question. Does the pilot go out soon after calling for heat? Next, if you have it on "spa" or "pool" on the temperature adjusting module, try the other setting. eg. If it is on "pool", switch the knob to "spa" and adjust the temperature.
Jun 05, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot light is lit but the heater won't fire
it's possible there is a blockage in one of the lines---those tubes are a very popular place for spiders to build a nest. check especially where you see curves in any of the tubes
May 11, 2010 | Hayward 2001 Series Millivolt Gas Pool...
Pilot lit clicking noise no burner
make sure knob on gas valve(inside heater)is turned to on position.3/4" should be fine as long as heater is not larger than than 175,000 btu
Jul 14, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Pool heater pilot works but no heater
make sure filter is clean, make sure filter is at 10-18 psi , also post if electronic or millivolt heater
Jun 16, 2009 | Pool & Spa
Have a Triton Millivolt pool heater pilot is lit and nothing!!
Low out put voltage from the pilot generator and/or an open circuit in the control circuit...the most common is a bad pressure switch (dirty filters can hamper pressure switch operation).
Jun 08, 2009 | Pentair PUREX MINIMAX HEATER; THERMOSTAT,...
Pilot did not stay lit,replace gas valve , pilot stays lit,but now it won't fire up. Jumped the TH terminals and it shut off the pilot light.thermostat is set highier than the water temp.Jump all ths...
Your problem is the pilot generator where the flame is by the burners. This needs to be repalced. That is what is causing the pilot to go out and not start. It is a flame sensor and also tells the gas valve when to release more or less gas.
May 28, 2009 | Hayward H Series Pool & Spa Heater 400k...
Rheem Pool Heater Clicks
see if gas is on if ok check to see if cobwebs if ok see if voltage to gas valve when cycling
May 24, 2009 | Solar Rheem Gas Fired Pool & Spa Heater...
Hayward 250kbtu Ng Pool Heater - Inground Logo
775 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
