Question about Apple PowerBook G3 Mac Notebook
Need instructions for setting up internet connection in OS 8
I have an older Powerbook G3 that I can't seem to get the ethernet adapter working. I connect the cable from the router, but I don't see a link light. Does it have one? If it does, the card must be bad because it's not coming on. I go into the Network settings and choose PPP but I don't see an option to allow the router to assign the IP and use DHCP. I can find instructions on the internet for setting up a connection in newer operating systems but haven't found any for OS8.
Thanks in advance.
  • Patrick Bridge
    Patrick Bridge May 11, 2010
    I have a Mac PowerBook G3 M5343. It turns on and makes the Apple startup sound and loads to a white screen, 1min later a Mac face icon folder shows up in the middle of the screen flashing the Mac face and a ?. Is it safe to scandisk the Hard Drive with a Microsoft boot disk? A: scandisk/all I was going to take out the Hard Drive and hook up to my desktop "Windows XP" and scandisk my Apple Hard Drive and maybe defragment.
    Scholar:
    New Friend:
  • 29 Answers
If you have any Issues regarding Roadrunner email 18447623344, just connect at our technical support number for USA. Nowadays E-mail is the efficient tool of communication and it also invites unauthorized access to hacking and other suspicious activities. If you are facing any issue in your email account just connect to Roadrunner Email Tech Support Number 18447623344 .our technical team is always ready to help you with instant support.
Posted on Jun 13, 2017
    New Friend:
You can contact on roadrunner technical support phone number for getting help. they solve your issues and provide instruction for setting up internet connection in OS 8 Roadrunner Technical Support Number
Posted on May 19, 2017
fire sine
  • 382 Answers
SOURCE: Connecting Powerbook G4 to Sharp Aquos LC-20D10-W
A few tries, go to the apple in the top left and choose SYSTEM PREFERENCES....it should bring you to:
In the HARDWARE row you should see DISPLAYS. Select that and you will be at:
You have the DETECT DISPLAYS button, and also CLICK the "Show displays in menu bar" box, so you dont have to keep going through menus to configure.
If you look at the F7 key, to the right of the NUM LOCK key (F6), that key allows you to switch from expanded to mirroring or vice versa.
You can also check Apple's Knowledge base....
http://docs.info.apple.com/article.html?artnum=58620
Keep me posted.
Posted on Dec 16, 2007
scottyfixit
  • 186 Answers
SOURCE: Open case of Apple Powerbook G3
Several screws on bottom and the whole top case snaps off. It will take a little time on this model to gently pry. Also, I think the keyboard comes off first before removing the top cover by two finger pegs. It's been a long time since I worked on this model you you'll just have to get in and look around. Very common on this design that the power plug just needs re-soldered to the motherboard.
Posted on Jun 20, 2008
Joed911
  • 4338 Answers
SOURCE: Apple Ibook G3 connect internet through Ethernet??
For Linzie:
To connect to Internet with cable:
1. Turn on your computer.
2. From the Apple Menu, select System Preferences, and select the Network icon. Click on the Built-in Ethernet connection, and then click Configure.
3. The Show drop-down menu should be set to Built-in Ethernet.
4. Click on the TCP/IP tab.
  • The Configure: pop-up menu should be set to Using DHCP
  • The DHCP Client ID should be left blank
  • Search Domains should be left blank
  • DNS Servers should be left blank
  • All other fields will be filled in automatically by the DHCP Server. Click Apply Now when you are done.
  • You should note the Ethernet Address for future reference. To do so, click on the Ethernet tab, and then write down the Ethernet ID. You may need this if it is not filled in automatically when you register your computer.
  • Close the Network preference pane.
  • You should be able to get online with Safari.
For Guest: Does your iBook 3G have an Airport card?
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 17, 2008
  • 53 Answers
SOURCE: what else do i need.......bought airport card. not sure what router I need and if I need an adapter?
Hi I'm mhel, you have to buy a wireless router and a hub to connect both your desktop and laptop
mhel
mhel_services@yahoo.com
Posted on May 31, 2009
  • 1099 Answers
SOURCE: i have a macintosh powerbook G3 and i forgot password
If you are running OS X put the appropriate system disk in the disk drive. Boot up using the c key. Once booted go up to the file menu and go to the reset password menu and reset your password. viola
Posted on Oct 08, 2009
What cords are needed to hook up hp7300 series printer to powerbook G3 laptop
Probably just need a usb a-b printer cable. One side is square-ish with a rounded side and the other end is a regular usb
Jun 22, 2014 | Apple G3 Computers & Internet
How do I connect to the internet via WIFI with a MAC Powerbook G3 laptop?
The easiest way if your Powerbook doesn't come equipped with an Airport card or isn't capable of supporting an Airport card is to purchase this http://www.sonnettech.com/product/aria_extreme.html it slides into the PCMIA slot on your Powerbook G3 (the credit card sized slot on the side of your Powerbook G3). There's support issues and model variations on older Powerbook G3's regarding Airport Card support and they're not as readily available as a standard PCMIA wireless card. This is my best suggestion for your situation.
Jun 01, 2010 | Apple PowerBook G3 Mac Notebook
Ibook wont log onto my network
I ran into this with my home network and my old g3 ibook needed the older speed wifi to connect. I found my old wifi router, hooked an ethernet cable to the newer router (in a regular ethernet port) and connected the other end to the internet port on the old one... they linked and worked fine to provide wifi for the old G3's ..
Dec 19, 2009 | Apple iBook G3 Mac Notebook
I have a apple clamshell i cannot get it to connect to my wireless at home,keeps asking for password,i put in password (for netgear)and it won't work ,it works at my job ,at the apple store,just not at my...
I had this problem with a G3 ibook. All our other laptops and desktops were fine but the old G3 was left w/o a connection. I did install an older wifi router that was pre G3 type and put it in line with the other modem via an ethernet cable from the normal router e-net port to the internet e-net port on the older style router... now eveyone can access w/o issue. This may be the reason for your prob, too.
Dec 17, 2009 | Apple iBook G3 Clamshell (M2453B) Mac...
Running os10.3 need to connect a printer.does not have usb ports
You could use a network printer. You counl share a printer on a nother computer and be connected to the inter via Ethernet or Wireless. Or you could go on ebay and buy an usb external card.
May 25, 2009 | Apple PowerBook G3 266Mhz w/ 14.1" Screen...
Brother mfc210c printer driver
I believe your brother printer uses one driver for fax/scan and another driver for printing. It might seem like you haven't installed the printer driver, only the fax/scan driver. You should find the driver file and the instruction on this brother.com page:
PS: the driver linked to above is for os 10.4. You might want to search for a different version if you have a newer/older OS.
If the link doesn't work, search for the driver from brother.com's site and download and install the driver by following their 12 points instruction. Good luck!
Dec 11, 2008 | Apple PowerBook G4 Mac Notebook
For Linzie:
Thanks, Joe
Oct 18, 2008 | Apple iBook G3 Clamshell (M2453B) Mac...
Connection of Paradyne 6211 to iMac (OS 10.5) via Ethernet
If you connect by using LAN port (RJ 45) you don't have to install driver. However USB connection will require driver. Do you have Ethernet adapter installed to you iMAC? If you have it will be resolved easily without using USB port. Check the following link for connection instructions
http://www.fixya.com/support/p200812-paradyne_6211_a2_200_router/manual-18800/page-18
If physical connection is successful you can go to internet browser type 192.168.1.1 and check your modem's settings. Please post if you need further assistance
Good Luck
Jan 27, 2008 | Belkin (F5D7233) Wireless Router
No Internet With New Router, Computer, or Adapter
This document is relevant if you had an Internet connection, but lost it when: * Adding a router to your network, or * Using a different Ethernet adapter card or computer than the one your ISP used during installation. Use ISP Configuration to see whether you need to "spoof a MAC address" to connect to your ISP. If so, follow the instructions in this document. If the Ethernet card that was used during ISP installation is not available, you may need to register the new Ethernet card's MAC address with your ISP for the following to work. MAC address stands for Media Access Control address (not "Macintosh computer"!), a unique number built into modems, routers and other network hardware. It ensures that one piece of equipment is not mistaken for another one. Some ISPs validate your connection by checking the MAC address of the Ethernet adapter in computer that was registered during ISP installation. If you add a router or change computer or Ethernet adapter, these ISPs will drop your Internet connection, because they find the MAC address of the newly added router or adapter, instead of the one they expect. To fix this, change the router to report the Ethernet adapter's MAC, instead of its own. This is called "spoofing the MAC address". To find a PC's or Macintosh's MAC address, see How to Find an Adapter's MAC address : http://www.fixya.com/ThreadView.aspx?prdid=252225&thid=102075. To Spoof a MAC Address 1. Connect the computer that your ISP's installers used to establish Internet connection to the router. If you are unsure which computer was used, call your ISP, and ask what MAC address was registered. Then, using the instructions in the box below find the computer whose MAC address matches their records. 2. Disconnect other computers from the router. (If you do not want to disconnect other computers, you need to know the adapter's MAC address, as described in the box below. Then, in step 6, type Use This MAC Address, entering the adapter's address.) 3. In an Internet browser type the address 192.168.0.1. 4. Type admin for the username, password for the password, and click OK. 5. Go to the Basic Settings > Router Mac Address. 6. Select Use Computer MAC Address. 7. Click Apply. This automatically gives the router the computer's MAC address. 8. Click Test to make sure you are connected. If you are not connected, contact your ISP.
Feb 19, 2006 | NetGear CG814M Wireless Cable Modem...
Apple PowerBook G3 Mac Notebook Logo
107 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
