Question about GE JVM1631 Microwave Oven
GE JVM1631BB not heating
Everything with the microwave works minus the heating up. My fuse is good. The door interlocks ohm'd out fine. The capacitor is holding a charge--in fact I discharge it and the voltage returns to ~2.2V. This doesn't seem right, though. I also get resistance between the 2 leads, too. This shouldn't be happening, right? Any suggestions are appreciated.
  • 8 more comments
  • MOTRSPRT Jun 02, 2009
    MicrowaveSVC,
    It appears that one of your links explained a bit more in detail about the diode, and mentioned how it should continuity only one way. If continuity exists in both directions then the diode is bad, and my diode shows continuity both ways. So, I am going to replace the diode and see what happens. I'll post on here the results.
    Thanks!
  • MOTRSPRT Jun 05, 2009
    I hooked everything back up and closed the breaker. I put some butter in the mw (it melts fast) to test and started the mw. Butter did not melt and I heard a small pop inside behind the keypad area. Killed power, removed the diode and fuse. Fuse tests okay, but now the diode measures resistance in both directions again. Something keeps killing the diode. Any suggestions from here?
    Just finished testing the transformer as per the link provided. I didn't remove the transformer from the mw.
    The steps said to test the HV leads from the xformer terminal and they measured 68 ohms.
    Next step was to measure from one primary terminal to the other and it measured .6 ohms.
    Next step was to measure from primary terminal to chassis ground and it measured open.
    Next step was to measure the filament leads from one to the other and it measured .3 ohms.
    Last step was to measure each filament terminal to chassis ground and these measured open.
    Basically, it appears that my xformer is functioning properly. So, in theory the power from the AC plug feeds the xformer which feeds the capacitor/diode. This in turn feeds the stepped up voltage to the magnetron. Right? So, why does the diode keep going south?
  • MOTRSPRT Jun 07, 2009
    Okay, I checked the magnetron and it checked out good. The connectors are not burned in any way. Overall, it looks to be in good shape. But, if the continuity checks out the magnetron may still be faulty. Yes?
    After I replaced the diode and ran the mw, if the mag was still good I should've got heat "until" the diode blew, right? If the mag was good. But, since my butter wasn't even affected then the problem seems to pretty much point in the direction of the magnetron. I was just thinking that maybe, just maybe, the repair shop sold me a less than adequate diode. For the 10 seconds it ran prior to me hearing the little "pop" the butter should've melted to some degree. OR, if the diode is an inferior piece would it be functioning properly in conjunction with the capacitor?
    What do you think I should do from here? This mw's build date was July 2001. Just try to get the magnetron replaced under warranty?
  • MOTRSPRT Jun 19, 2009
    Update:
    I called the number you suggested, and within 5 minutes the new magnetron was in the mail! No fuss at all. Thanks for that number--I hope others will be able to take advantage of that phone number. The magnetron arrived 3 days later and I began to r & r the magnetron. A note for others: to replace the magnetron on this microwave, remove the outer shell of the mw and the bottom portion of the mw. Inside the right hand side of the mw is a metal divider that needs to be removed. Once these things are out of the way you can remove the xformer and replace the magnetron. As far as I could tell, the xformer MUST be removed. Otherwise, there is not enough room to pull out the old magnetron. I got everything buttoned up and reconnected, bought a new diode, and restored the power to the plug. However, I am still not out of the water. After about 2 seconds of the mw running, it started humming loudly. Way louder than what it used to do. I shut the mw off and could smell a little bit of burned electronics. My fuse is still good, and my diode is still good. Everything was reconnected as it was before. So, I thought I'd post an update to this same thread before I do a search for humming microwave's.
    Any help is appreciated :)
  • MOTRSPRT Jun 24, 2009
    Update and final post: The loud humming noise turned out to be an open break in the insulation for the HV wire leading to the capacitor. I fixed the wire, buttoned everything up, and melted butter like the mw used to do! For the cost of 2 diodes, I replaced 2 diodes and the magnetron = $24. For the most part, this mw should last at least another 8 years :)
    Thanks to MicrowaveSVC who gave me the correct information needed to get this task done because a new microwave is about $250 more than I have right now.
  • William Miller
    William Miller May 11, 2010
    magnetron. Right?
    Right.
    Again, I refer you to my info about the magnetron:
    -paste-
    BUT FIRST
    , I would recommend that you carefully inspect the
    plastic around the connectors on the magnetron for signs of melting or
    warping.
    It's not uncommon to have a bad magnetron and shorted diode diode.
    This oven's magnetron has a 9-year warranty.
    If it's within that time (by the tag on the inside of the unit) GE will
    send you the magnetron to do it yourself. Call them at
    888-239-6832.
    Be persistent. You may have to speak with a supervisor.
    Let us know how it goes.
  • William Miller
    Please refer back to my Clarification Request
    Posted by MicrowaveSvc on Jun 03, 2009 concerning the magnetron.
  • William Miller
    That would mean it's bad if it's shorted.
    It is part #
    WB27X1160 and you can find it here but it runs almost $50!
    I would instead recommend the generic part GLC3-A from Global Micro Parts here.
    It's just used as a snubber diode, so it will work for you just fine.
    BUT FIRST, I would recommend that you carefully inspect the plastic around the connectors on the magnetron for signs of melting or warping.
    888-239-6832.
  • William Miller
    There
    should be a "mini-manual" (tech sheet) hidden inside the unit
    behind the
    control panel or hidden on the left side behind the grille, which is
    very helpful when troubleshooting, testing, and locating components.
    Here are some links you
    or someone you know can use (in order given) for test help, but read
    the safety warnings first:
    http://www.gallawa.com/microtech/cap_tes...
    http://www.gallawa.com/microtech/diode.h...
    (if it is NOT shorted or burned looking,
    it's probably fine)
    http://www.gallawa.com/microtech/mag_tes...
    (continuity can be good even
    though mag is bad!)
    http://www.gallawa.com/microtech/xformer...
    You can find
    helpful exploded view diagrams and order parts by entering your full
    model number from the tag on the oven
    here.
    Let us know if you need more help.
  • GE Master
  • 9,098 Answers
If the measurements you got on the high voltage transformer match what is specified on the mini-manual, then the transformer is probably okay. If there is a serious difference, that may mean the high voltage is too high, which can destroy the high voltage rectifier diode. Otherwise, you have a bad magnetron, regardless of how well it ohms out. Even though the magnetron's continuity readings are good, the magnetron can still be bad. We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Posted on Jun 08, 2009
  • William Miller
    William Miller Jun 08, 2009
    For some reason I couldn't post another clarification request. I think they want the thread to end.
    But seriously, the solution I posted is all but certain.
    Good luck.
GE Spacemaker XL1800 not working?
  • Open internal fuse
  • Magnetron failure
  • Faulty door interlock
  • Faulty control board
Feb 05, 2018 | GE Microwave Ovens
GE Profile Microwave Fuse Keeps Blowing
First of all, be sure your AC line voltage is correct at the outlet, at between 105 and 125VAC. If not, call an electrician.
There should be a technical sheet hidden behind the controller or behind the grille or the oven. It's helpful when troubleshooting. If you don't find yours, e-mail me for a copy.
Next take a look at the fuse holder connections and wire terminal connections on the filter board where the fuse is.
Loose or charred connections can increase heat and resistance, leading to a melted fuse.
Also look at the terminals on the upper door switch, magnetron thermostat, and oven thermostat for the same reasons as above. (You'll probably have to remove the oven from the wall to get to the oven thermostat. Your installation instructions are here.)
It's not likely the trouble, but you can eliminate monitor interlock trouble by disconnecting one wire (probably the black one) from the middle door switch and trying your test again. (Ignore the bottom door switch altogether.)
For more free DIY and other help & advice, feel free to contact me.
William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 14, 2017 | GE Microwave Ovens
Everything works but it will not heat food
Check the door safety interlock micro switches. Others will po9int to the very expensive magnetron and it might be that but I don't think so. Still others will tell you that it is the capacitor ... and it might be that. If you regularly open the door while the oven is operating, the tiny contacts become damaged from the arcing. When the interlock switches can not longer tell the oven the door is in fact closed, the magnetron will not come on .. and there will be no heat.
It is probably worth removing the cover to check the $2.99 micro switches ...
Make sense?
Thanks for your question @ FixYa.com
May 04, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Re: "my GE Advantium SCA2001
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Dec 31, 2010 | GE Advantium 120 Convection/Microwave Oven
Microwave stopped heating
Please remove the cover and check the door safety interlock switches found near the latch.
When these switches fail, the oven has no way to know the door is closed and will not turn on the heat. They go bad because we open the door with the door running and there is a arc on the tiny contacts.
There are other reasons for this condition ... this is the most common. Check them. If they are GOOD, repost your question stating you have inspected and tested the switches with a volt/ohm meter and they were good.
Thanks for your interest in FixYa.com
Feb 24, 2010 | GE JVM1440 Microwave Oven
I have a 1993 GE spacemaker microwave/range hood combo. Everything works except that for most of the day it did not heat the food. The turntable still worked and the oven still appeared to be running. Then...
In short yes it can happen again.
Intermittent operation can be caused by a door interlock micro switch, a weak capacitor, an intermittent wiring connection from heat or poor connection, a marginally performing diode or a sticking Magnetron. Except for the Magnetron all other repairs would be worth the expense.
Repair costs and parts for most everything else will be between $65 and $100.00 depending on the part(s) replaced. Replacing the Magnetron would cost more than 50 % of the total unit replacement cost.
Jan 17, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Hi, My GE microwave oven model no. JVM1850CD 002 stopped heating a few days ago, and now has a dull sound to it. Prior to this it had been working great. Your help is much appreciated. Thank You, Regards,...
Please check the door safety interlock switches which you will find opposite the door hinge. Check them with a volt./ohm meter. You will hnave to remove the cover. Dont fool with the start capacitor.
What typically happens, Richard, is if you open the door while the oven is working, the switches arc and will eventually burn to the point that they cannot complete the circuit. When this happens, the oven thinks the door is open and it will not turn on the heat (magnatron).
Find replacement parts at FixYa.com advertiser, local source in your community or at www.repairclinic.com
Thanks for posting your question at FixYa.com and plese vote
Thank you
a
Nov 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave JE2160 does not heat
Does it make any noises that it didn't before it failed?? It could be a bad secondary interlock switch, cook relay on the PCB, HV circuit problem or bad magnetron. You need an ohm meter to troubleshoot. If you take the cover off, you MUST short across the High Voltage Capacitor terminals to discharge any possible residual charge to prevent shock hazard.
Sep 11, 2009 | GE JE2160 Microwave Oven
Everything works except heat
Sounds like you've had a failure in the microwave portion of the unit.
Microwave not heating problems when the timer/controller board appears to function properly, are related to the following components -
1) Diode
2) Capacitor
3) Transformer
4) Magnetron
Jan 24, 2009 | GE JE1540 Microwave Oven
GE JVM1631 Microwave Oven Logo
606 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
