Question about iRobot Roomba 560 Robotic Vacuum
No suction on Roomba 560
Roomba 560 suddenly has no suction. Was working perfectly, all brushes working properly, but not picking up larger debris. Any way to check the suction on fix?
  • Anonymous Mar 20, 2014
    The roomba is not picking up anything
    Sniper:
  • 61 Answers
Larger debris is usually the responsibility of the brushes. Remove the bin and run the Roomba-- are the brushes actually turning? If not, call customer support for a new cleaning head module. If so, remove the grill from the back of the bin. Make sure that the little fan inside is clean, then reinstall the bin on the Roomba and run it. If that little fan doesn't spin, your Roomba has lost vacuum suction and you need a new bin.
Posted on Jun 03, 2009
Fan is spinning but nothing makes it into the fine dust bin like when it was new. The big stuff gets into the large item bin because of the brushes. All the fine dust accumulates around the rubber strip. Does someone make a stronger Fan for these units?
Posted on Nov 13, 2012
No suction rhooma 780
No suction means no air can pass through it. Clean the filter compartment, rinse the filter off with water and let dry before reinstalling it. I suspect you need to disconnect the brushes and clean them too.
Apr 13, 2014 | iRobot Roomba 560 Robotic Vacuum
Error 5 what dose it mean
(Condensed from the iRobot site...) "Uh Oh Error 5" or "Uh Oh" and 5 beeps means Roomba's Side Wheel is stuck. Pick up Roomba and with Roomba right side up, push the side wheel up and down a few times to clear debris. Manually rotate the side wheels to clear debris. Blow air through the side wheel pockets (or vacuum them with an upholstery tool on a traditional vacuum) to clear debris. If this doesn't clear the obstruction, then contact iRobot customer support.
Jul 02, 2012 | iRobot Roomba 560 Robotic Vacuum
My roomba 560 works perfectly for a year. Now works ok, vacuum but the dust stays at the bruches and at the bin. i replace the filter but nothing. Thanks George
You need to decide if the vacuum and brushes are runing or not. For me its easy to determine after its run. If the brushed turn then I have debris in the open part of the collection bin when I pull it off the back, but none if the brushes don't turn. If the vacuum runs then there is dust at the filter, and none if it the vacuum doesn't run.
You can also remove the vacuum/bin and place the roomba on a hard floor and start it and look into the rear and see if the brushes are turning.
When the vacuum is running there is a noticeable amount of air pushed out the rear vent.
When you've figured out what isn't operating, you'll be halfway to solving your problem.
Nov 30, 2009 | iRobot Roomba 560 Robotic Vacuum
IRobot stopped picking up larger bits from the carpet. It picks up the dust, but anything larger, it leaves behind. Have changed the filter/brushes. Is there anything else I need to do
Its sounds like the brushes aren't turning. Pull the vacuum and bin off the back and start it and look to see if the brushes are turning.
Sep 29, 2009 | iRobot Roomba 560 Robotic Vacuum
New Roomba 560 beep twice, ask to clean brushes, but no dirt
your roomba is thinking that you need to clean the brushes. if too much load it put on your brush motor--the unit will think that something is wrapped around the brush and slowing down the motor. if you have cleaned your brush and are sure that is not the problem; you need to look for anything else that could be slowing down the brush/motor. If this is inconclusive you need to put your roomba into diagnostic mode by following the procedures in the link below http://swiftracer.com/index.php?myPage=RoombaDiagnosticMode.php
Jun 13, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
Roomba keeps saying clean brushes yet are clean!
Make sure you take off the little cap at the end (the one that spins -- just grab it and pull it straight off) and clean under it too. The rest of the brush may look perfectly clean but what happens is that hair gets stuck under spinning cap and, like a slowly growing washer, it pushes the whole brush toward the gear box. When it gets pushed over enough, the large yellow ring starts to rub against the side of the brush deck making it harder for the motor to turn the brush and you get that "remove and clean brushes" message.
Jan 30, 2009 | iRobot Roomba 530 Robotic Vacuum
Roomba won't pick up debris
I had this problem until I wiped the dirt sensor, which you will find under the rollers.
May 26, 2008 | Vacuums
No suction
Roomba does much of its cleaning by the brush and roller on the bottom, but an important part is the little fan at the back of the debris bin which provides 100% of the 'suction.'
First, take off the vent cover on the back of the debris compartment and start Roomba on a mission. You will see the little turbine spin (if it's working) and probably a little dust cloud will come out.
It may not be working at best efficiency, however, because dirt gets sucked into the housing and blocks much of the air flow. Now that you know what the fan/turbine looks like (it's quite small, only the size of two stacked silver dollars), peer down into the larger opening of the debris bin and view the turbine from the other side. Chances are there's some crud stuck down there which is impeding air flow. (There's a hollow part of the turbine where the air is sucked into before being expelled out the back, that's probably filled with pet hair/dust/etc.) Clean that out using a long knife, chopsticks, or anything else that can reach down in there. Bang the dust bin down (lightly) to dislodge any more hair that's up there and continue cleaning until it's all gone.
I've had 3 Roomba's and they all get hair stuck up there. I only have to do this once a year or so (multi-cat and dog household here!) but it makes all the difference in the world.
May 01, 2008 | Roomba Robotic Floor Bagless Vacuum
Open Questions:
See all iRobot Roomba 560 Robotic Vacuum Questions
iRobot Roomba 560 Robotic Vacuum Logo
3,734 people viewed this question
Top iRobot Vacuums Experts
Shehu Pro
Shehu Pro
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
