Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Beeps with F-7
F-7 and beeping???
    Novelist:
  • 148 Answers
Please visit: http://www.applianceblog.com/mainforums/showthread.php?t=2655
I do beleive Powerman there has the solution
good luck,
Bastian
Posted on Jun 02, 2009
Constant beep beep beeb from Maytag
forum.appliancepartspros.com/oven...ranges-cooktops/5209-maytag-ove...
https://www.maytag.com/product-help
Jun 30, 2014 | Maytag 30" Built-In Single Electric Wall...
Error Code F1 displays once in a while. What does it mean?
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
1. Disconnect power to stove
2. Gain access to the back of the clock (electronic range control or ERC).
3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
4. Make sure everything is clear and will not short out when power is turned back on.
5. Turn power back on to stove.
6. Watch for the F1 and listen for the beep.
7. If you get the F1 and beep, replace the ERC.
8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
* ERC - Electronic Range Control
NOTE: Some models incorporate the touch pad and the clock as one part.
Hope helps.
Apr 20, 2011 | Ovens
Beeping
Hello,I'm afraid F7 on that make of range usually indicates a problem in the control keypad in which case on your model the whole console panel usually needs to be replaced to correct the condition.
Thanks
Jun 02, 2010 | Kenmore 33169 Gas Single Oven
My GE Profile oven is beeping every minute. I've
if its an f-7 error code its due to a stuck error code
Feb 06, 2010 | GE Profile JT955 Electric Double Oven
Oven W279U Serial No. 790191BD keeps beeping.
I turned off the power to the oven at the breaker box and left it off for several days. I restored the power this afternoon and there have been no more beeps. Spells and incantations may have played a part as well.
Aug 20, 2009 | Jenn-Air Ovens
Oven keeps making a BEEPING sound - only way to
This will occur when there is a control fault detected. have the oven control board replaced asap.
Aug 20, 2009 | Ovens
Beeping
Here is what the fault code means:
F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button
I hope that this helps for you
Apr 20, 2009 | Jenn-Air Ovens
F7 error code
f-7 means either the touch pad is stuck or a relay on the control board is stuck. if the code came up while the oven was not being used then the touch pad is shorted. if it came up while in use then the controlboard is bad
Nov 22, 2007 | GE JGRP17 Gas Single Oven
Oven beeping
See my solution to OVENMAN/April 12, 2007 which I posted on April 14, 2007. My solution to the F7 error message has been supplied to over 650 individuals with a high degree of successful application.
Apr 03, 2007 | GE JKS05 Electric Single Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
115 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
