Question about Xerox WorkCentre M-24 Color Copier
Fault has occured error code 103-208
I have a problem with my printer i just moved it from one office to another and when i had it reconnected it starterd giving me a massege saying that a fault has occured turn machine off and on and if problem persists contact service provider and it show code 116-321, i did as advised but then the same massege appeared and the code has changed to 103-208 what can i do to resolve this problem
    President:
  • 2,072 Answers
First off. look around carefully and be certain everything is plugged in properly. Sometimes that code is caused my mis communication between the document feeder and machine, scanner and machine,finisher and machine, etc. I would follow all the connectors back and disconnect, then reconnect them.
If that doesn't resolve the problem, then remove the back cover and reseat all the connectors you can see on circuit boards.
With moving the machine, I am pretty sure you have a connector problem. But the 116 and 103 codes are related to software and mostly due to mis communications between the device peripherals.
Also on a hunch, just try to remove the RJ 45 network connector and turn the machine on. If there happens to be some odd job, something like an internet print job on that line, it will shut the machine off with that 116 code you reported.
Let me know and we will go from there.
Posted on Jun 02, 2009
Cannon printer c5030 code E000532-0002 what do it means? ?
Stapler assembly issue
https://printcopy.info/?l=en&mod=erc&brand=Canon&model=iR%20Advance%20C5030&page=34
  • Code: E532-0002
  • Description: STP Move Motor fails to move from HP
    At initial rotation, when the Motor rotates for specified period of time and cannot move from HP, it is detected as an error if the same symptom occurs again after the first retry.
  • Remedy: 1. Check if the Motor (M1) Connector is physically removed. 2. Check if the Motor failure occurs. 3. Check if the Stapler Move HP Sensor (S10) Connector is physically removed. 4. Check if the Stapler Move HP Sensor (S10) failure occurs.
https://www.justanswer.com/printers/4mgs2-canon-c5045-error-message-e000532-0001.html
http://www.copytechnet.com/forums/canon/43109-canon-ir-105-e000532-002-a.html
Apr 08, 2018 | Cannon Office Equipment & Supplies
Communication error occurred. Check the I/F cable connection and power of printer.
For some reason your computer isn't recognizing the printer. Try rebooting the printer and then the computer to see if they reconnect. If they don't then go thru the setup process for the printer again.
Mar 30, 2018 | The Office Equipment & Supplies
Canon pixma printer mp280 !!error code p08 tried suggested answers, take off electricity, when on again hold on button ect. need help ! thanks chris
The standard info on this code is:
5200/P08 - Orange and green light blinking 8 times Description: A service error has occurred. Resolution: 1. Turn off the printer. 2. Disconnect the power cable. 3. Open the printer cover. 4. Check for any orange protective tape or white polystyrene and remove if necessary. 5. Check that there are no foreign objects in the printer (such as a paper clip) and remove if necessary. 6. Close the cover. 7. Reconnect and turn on. If the above solution has not resolved your error, please contact your nearest Canon authorised service facility using the link at the top of the page.
That said, it is often a generic response meaning the machine has a problem but doesn't know what.
In the first instance check inside the machine at both ends of the carriage bar - look for a soggy black mass of crumpled up paper and remove if found. If there is nothing to find, it is possible that there is a printhead fault although typically this gives a P05 error. Try swapping out the cartridges with an old used one. Change one at a time to identify if one or both are faulty. If that fails, it is probably worth replacing the machine as it is relatively aged and new equivalent versions are really cheap.
Nov 02, 2017 | Canon Office Equipment & Supplies
Hi!Can you help me resolving error code 092-315 for xerox7225?
Can you verify the error code? 092-315 does not appear in the error code site. See link below
How To Search for a Fault Code WC7220 / WC7225 Fault Code Page
To search on a fault code, enter one code at a time. The codes will be displayed on the Touch Screen.
Fault code format: A 3-digit number, followed by a 3-digit number. For example, 010-352.
Viewing Fault and Alert Messages on the Control Panel
When a fault or alert condition occurs, a message will be displayed on the Control Panel to inform you of the problem. Alert messages inform you about printer conditions, such as low supplies or open doors, that require your attention. Fault messages warn you about printer conditions that prevent the printer from printing or degrade printing performance. If more than one condition occurs, only one displays on the Control Panel.
To view a complete list of active fault and alert messages:
  1. Press the [Machine Status] button on the Control Panel.
  2. Select the [Active Messages] tab.
  3. Use the Down arrow and select [Faults], [Alerts], or [Faults & Alerts].
  4. To view details, select a fault or alert.
Viewing the Fault History on the Control Panel
When faults occur, they are logged in to a fault history file by date, time, and fault code. Use this list to identify trends and resolve problems.
To view the fault history:
  3. Select [Fault History]. The screen displays the number, date, time, and image count for each fault code.
The following table represents the system area as represented by the first 3-digits of the fault code:
Chain Description 303 Communications Error 305 Duplex Automatic Document Feeder (DADF) 310 Fusing 312, 313 Finisher 371 - 375 Paper Tray Feed 377 Sensor / Interlock Fault 391 Drum Cartridge / Waste Toner
http://www.support.xerox.com/support/workcentre-7220-7225/support/enus.html
Mar 07, 2016 | Xerox Office Equipment & Supplies
Error 49.38.07 printer unable to initialize
49.XXXXX ERROR To continue turn off
then on
A critical firmware error has occurred.
Generally this fault occurs when a corrupt file is in the print queue
to clear fault follow these steps precisley
1. disconnect the net cable / usb cable or any other data cable that the machine is connected to
2. cycle the power with no data connections.
3. your machine should now come to ready.
4. take a copy from the platen glass ( straight forward photocopy)
if this prints out then the fault is down to corrupt data.
if at this point the error 49.xx.xx is still present then order a new formatter.
5. before reconnecting the networks -make sure ALL PRINT QUEUEs are cleared before connection otherwise you'll be back at square one
( print queues are on the computers sending print jobs)
before printing your documents its wise to send a test page through to make sure the printer is still able to understand print commands.
hope this helps...if you still need assistance please call Belmonte office equipment on 01614805556
Jan 21, 2014 | HP LaserJet Enterprise 500 MFP M525dn
C1AB0001 ERROR IN HP 8038 PRINTER
*** Fix your HP Photosmart D7360 (Reset Code/Master Reset) ***
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
8- voila, the nasty error message 0xc18a0001 "Ink System has Failed" is now gone.
Mar 11, 2013 | HP PhotoSmart Office Equipment & Supplies
Laser scanner unit error. Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service representative....
Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service representative. When contacting the service representative, inform them of the error code displayed and symptoms.
Error Code: E100 0000
Mar 26, 2012 | Canon LASER SHOT LBP-2900 Printer
When i put my canon IR 2318 on, the code E000010-0000 appears; what can I do to move it?
this is error code for main motor failure, you can try to reconnect main motor, look for breakege of gears, reconnect dc controller, or the main motor must be replaced or dc controller, or ...
As you can see that there is a lot of things that can be fault, so call service!!!
Aug 28, 2011 | Canon imageRUNNER 6000 Copier
I have xerox wc 7228, when i try to copy it is showing ''A fault has occurred press C botton to cancel '' error 009-936
hello
here is the link Xerox offical site about error codes and things that you can do . i hope it useless.
Feb 10, 2010 | Xerox WorkCentre C2424DN All-In-One Laser...
My printer will not work
Chek that your printer's internal parts are correctly placed and without error in connection. I think it will help.
Aug 10, 2009 | HP LaserJet M1522nf Multifunction Printer...
Xerox WorkCentre M-24 Color Copier Logo
723 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
