When I go to start the dryer, I push the start button and it makes a clicking sound like it wants to start and tumble but it won't. My dryer suddently just stopped. The timer works and the heat element works. It will not start when I hit the start button? The belt is on, etc. Like there is no juice to the motor?
Jim
Check the wire leads the motor and make sure they are not burned. I had a dryer do the same thing and the motor lead had burned off the connection lug.
? 4:47
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
Oct 14, 2011 - Uploaded by PartSelect
Plugged up dryer saw sparks...noticed the burn area near the grounding ... I could hear a click til around the 8th turn then tried it and it worked. ... My dryer doesn't initially turn on when I push thestart button, only when I put ...
When the dryer won't start then troubleshoot common parts and problems like ... On alldryers, the door switch allows the dryer to start tumbling only when the door ... Gas and electric dryers have a motor that turns the blower and the dryer drum. ... and Stratton Parts · Echo Parts · Frigidaire Parts · GE Parts · Husqvarna Parts ...Missing: saw
try holding the door switch with your finger and turning the drum with your hand after you push the start button , if this does not start it then you will have to replace the motor
When your dryer won't start, it could be a number of problems from a broken door latch or start switch to an exhaust duct blocked by lint. It could even be a tripped circuit breaker or blown fuse.
The first step in troubleshooting any electrical appliance is to ensure that it is plugged in and receiving power. While dryer plugs do not come loose easily, it can happen.
For more troubleshooting tips, read Dryer won't start for possible causes, signs to look for and things you can do. I hope this helps!
there is a relay that latches on when you push the start button .. that relay is released by the "door open" switch .. i would suspect that the "door open" switch is bad .. thats usually a button that is pushed in when the door is closed ..
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
You-Tube video "XNxE9eXx2Rk" placeholder (do not delete)
For a full list of appliance Video Repair help see our video section White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool, Here is the elementin this video For all you tumble dryer spare parts click here
