Question about Microwave Ovens
We have the same problem of this JVM1650WH02 GE Spacesaver Microwave shutting down after a few seconds, mostly in the popcorn sensor cooking mode, with the display changing to jiberish then asking for a clock / control panel reset. I have seen and have been told of a solution of replacing the humidity sensor (F4 Code on display). I have also seen on the internet from various sources: solutions ranging from replacing the magnetron unit to placing something internally between the circuit board and the computer panel so as to eliminate microwaves which leak internally and effect the control panel, thereby shutting it down into a problem or short default (jiberish display). The "something" placed between the circuit board and the computer control panel (which is behind the keypad) is simply a piece of aluminum foil sealed inside a large ziploc bag which is taped in place to cover the circuit board, between it and the computer control panel in front of the circuit board. Makes sense - the foil stops the errant microwaves, the plastic bag avoids contact of the foil with the electronics. This is a frustrating problem as this GE unit is only 3 years old and we have been told it could cost $200 to $300 to service the problem. It has been suggested to us (by a service facility which also sells units like this) to change / replace the entire microwave. This is NOT a throwaway or disposable item. It should be good for 10 years or more, for what we paid for it. In this economy we all look for inexpensive but good fixes. There have been several suggested fixes in this forum and other forums - which one has worked?? GE's solution is a new humidity sensor due to an occazsional F4 Code. Anyone do that yet? Anyone do any of the other suggestions yet? WJM
  • 15,935 Answers
Instead of using foil "trick" - get an anti-static bag (hard drives memory and other sensitive computer software is bagged in to ship) and tape it on the back side of the controller.
This bag will absorb any extra RF that is disrupting the controller.
The foil method works 75% of the time - as it mus be placed in the exact location - is an electricity CONDUCTOR - and also doesnt allow the RF to discharge.... it simply deflects it.
Another test is to remove the front panel, and controller, but don't disconnect it. Try the microwave. At this time - also look for sparking near the upper left of the unit by the magnetron. Any sparking indicates failure - or arcing to something that isnt supposed to be there (chip off the magnetron).
Do the anti-static bag first - as it's the cheapest :D
Thanks for using FixYa!!
Posted on Jun 02, 2009
MY GE SPACESAVER MICROWAVE MODEL JVM-1653-SHO-1 SHUTS DOWN AND TELL YOU TO REPROGRAM THE CLOCK BUT YOU RESET USING ALL INSTRUCTIONS I INSTALL COOK TIME PRESS START IT WILL COME ON FOR 3 SECONDS AND SHUTS...
This is magnetron-related.
See
this FixYa solution (solution #2) even though your model number is different.
Jun 19, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave doesn't work
Sounds like you have a faulty control panel. I would use a meter and test the power from the control board to the magnetron and circuit board. Chances are the control panel is faulty
Jul 25, 2010 | GE Microwave Ovens
Ge spacemaker jvm1650sh01 starts to microwave then loses power
See this FixYa solution.
May 27, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Model JVM1650WH02 will shut off about 2 seconds or less into cook time. everything else works such as light and clock and sometimes the wave will cook.
magnetron is leaking internally, do not use until magnetron is replaced. the mag creates interference with the control board and resets it
Feb 05, 2010 | GE JVM1650 1000 Watts Microwave Oven
My spacesaver dated September of 2004 shuts off
I solved the problem by buying a new microwave and it was not a GE. I feel that GE should have had a recall on this problem, since it seemed to be a major problem in their system. I will never buy another GE product.
Oct 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Will not cook or will not warm
Your temperature sensor inside on the microwave need to rreplace. It maybe dirty or faulty. Bring your microwave to electronics technician to check it.
Jul 24, 2009 | Panasonic NN-H504WF Microwave Oven
GE Spacesaver XL 1650 microwave shuts off after a few seconds
this would be the digital control board that would need to be replaced
Nov 27, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Magic Chef MCO153UW
The cooling fan is a must!
Otherwise, the magnetron will be ruined, and that drives up the repair cost.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can order parts here: https://www.mcappliance.com/partorder.aspx
To contact Magic Chef about getting an *authorized* servicer, see: http://www.mcappliance.com/contactus/contactus.asp
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 06, 2008 | Magic Chef CMV1000B Microwave Oven
Magic chef microwave shuts down
We had the same problem with our brand new Magic Chef. Before going through the trouble of taking it back I called Home Depot. After talking to a Home Depot Rep I am told that the overheat sensor is under the glass plate directly beneath the popcorn bag. Popcorn gets very hot and the heat of the popcorn causes the sensor to shut the machine down. I would imagine this would be the same for a baked potato.
Very poor design.
I was told to put a microwave safe plate down and put the popcorn bag on it. This should help to reduce the heat and not trip the sensor.
A safety sensor is great, but not if it keeps tripping the machine and shutting down!
Sep 02, 2007 | Microwave Ovens
Microwave Ovens Logo
32 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
