Question about Moen 103459 Drain Pop-UP Plug
Can no longer drain tub unless I use a piece of plastic under the plug and use this to pull the plug out after the bath
Tub plug no longer raises enough to drain tub when you turn fixture on face of tub which should cause the plug to raise up.
    President:
  • 1,185 Answers
At the base of the plug there is normally a stud with a thread on it to allow you to raise and lower the plug so that it seals or empties.
If that is not how your oulet is made then there is a lever behind the or to the side of the outlet underneath the sink, that also is adjustable on most sinks.
Sometimes it is via a spring clip which rusts and loses its grip
Posted on Jun 02, 2009
I just had a Maax Living tub installed but did not receive a manual. I searched the Maax website but could not find the answer I need: if I accidently push the drain, the water starts draining but I cannot...
The drain may have been installed incorrectly. It should not be that easy to "pop" open. In normal operation, you push it down until it latches in the closed position. Afterwards, you push it down to unlatch it and start draining.
Feb 08, 2015 | Maax Plumbing
How to remove bath tub pop-up stoppers
Put the lever in the open position so that you can grab the stopper. After you get a grip on it, put the lever in the closed position and the drain plug and rocker assembly will pull out in a horizontal direction.
Sep 25, 2014 | American Standard 1583.470.020 Universal...
Why does my geberit bath waste plug leak water?
It's adjustable. Remove the drain lever from the side of the tub. Now you can withdraw the whole drain assembly. Clean it well, then reinsert it to see if that fixed the problem. If not, try adjusting it longer.
Dec 24, 2013 | Geberit Bath Waste and Overflow Tub Drain...
I connected a hose extension to the continuous drain hose on the unit. I ran the hose into the tub, but water still goes in the tank. There is water in the hose too, but doesn't seem to drain in the...
Andre, the problem lies in the length of the hose (should be no longer than 5 feet) and trying to drain it into the bath tub. Your dehumidifier relies entirely on gravity to drain. It will not drain upward over the edge of the bath tub. Water gets trapped in the hose, because of this and creates a blockage. When that happens, water is diverted back to the tank.
For continuous darinage, it should be into a floor drain or a sump. So unless yo have one of the aforementioned, continuous drainage is not an option for you.
Hope this helped you understand how it works and what your options are.
Jul 20, 2011 | Danby DPAC7008 Air Conditioner
I am replacing a bathtub lift and turn tub drain w/ the Danze lift and turn tub drain conversion kit- how do i remove it from the part that stays in the tub? I just want to put the pull into the existing...
Unless you can get to the bottom of the tub either through the floor below or the wall in front of the tub.... you do not want to do that...
To change it you may need to change some of the piping to the tub drain....
It is possible that you can take a needle nose pliers and turn the tub piece out by sticking the pliers through the webing in the tub drain and turn the CCW also.....but if the bottom piece is not the same thread.. or the piece moves... you may not be able to get the new piece started and then your in BIG trouble...
heatman101
May 11, 2011 | Danze D490637 Lift & Turn Tub Drain &...
Knob on tub spicket to release or stop shower came off
I could not find an exploded parts diagram for the Benton suite from Moen. I did find the bayhill which is very similar. Please see link below of exploded view. That should help you piece it back together.
Jul 31, 2010 | Moen & Benton& Tub & Shower Faucet
Slow tub drain
I am not completly sure about the kohler,but i think that you have a toe tap drajn.You should be able to un-screw it counter clockwise.IF you can get it un-screwed look at the bottom of the toe tap.There will be a screw or a plastic nut.I beleave that you loosen it to raise the drain I hope my information is correct,I will certanly do some research on your drain.
Dec 11, 2009 | Kohler Archer Bath Drain, Vibrant Brushed...
Bath waste
! goes over the threaded piece that screws into the piece that goes under the tub...and the other goes between the tub and the waste assembly thereby creating a sandwich with one on top and one underneath the tub....then screw the piece down tight through the tub and into the waste assembly and your good to go.....
Good luck and thanks for rating my effort.....the Fang.
Mar 25, 2009 | Lefroy Brooks BATH WASTE KIT - LB1370-ST -...
Bath tub drain
You need to replace the overflow cover with the lever on it.You can replace the entire piece or just the faceplate.There is a spring on most of these that holds the lever in place when thrown and that is the piece that is broken causing your issue. Thanks for using Fix Ya.
Mar 02, 2009 | Delta T13420 Chrome Classic Single Handle...
Clogged drain
there is plastic plug that is used to stop the drain, when you pull the handle.
seems like the chain is broken off the the drain plug. the drain plug is one way plug.
the only suggestion I have is to open the backwall or the ceiling to get to the drain pipe. then you have to open the drain in order to fix this problem.
there is no easy fix, since you can't get to the plug that is in the drain, and the more you pull, the tighter it gets.
I don't suggest try to push the plug down, it may clogged the drain somewhere else.
Jan 01, 2009 | Eljer Arlington Non-Jetted Acrylic Bath...
Moen 103459 Drain Pop-UP Plug Logo
356 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
