The on/off switch on my acoustic research wireless speaker does not work
  • 470 Answers
It may be the direct connection of the switch,, if you can disassemble your fon try to check the switch line to the board circuit
Posted on Jun 02, 2009
My Acoustic Research HTB-80 Speaker Bar stopped working after a storm. No lights/power. Is there any fuses in the unit that I should check?
if your unit come with external Adaptor power up type. then mostly is the adaptor already blown, replace the adaptor will do.
Jun 24, 2011 | Acoustic Research HTB-80 Speaker
Help----i have aw825 wireless speaker and a yamaha rx-v730--how do i connect the two?
You need to connect a stereo out from the amplifier to the transmitter for the speaker. I believe the speaker unit comes with the required adapters which will probably be rca/phono's to stereo mini-jack.
Jul 19, 2010 | Acoustic Research 900MHz Wireless Stereo...
TRANSMITTER FOR A AW811 NO LONGER WORKS.. DID WORK TOO LONG AFTER I GOT IT...HELP
did you change the distance between the two ? assuming they are plugged in, does a power light come, maybe a fuse.
Feb 05, 2010 | Acoustic Research 900MHz Wireless Stereo...
I want wireless speakers for a 25'X 30' room to connect to a stereo. would the Acoustic Research be powerfull enough. Are the two speakers truly wireless or do the need to be connected to each other
they are wireless but need to be plugged in for power. or batteries. can be used as mono or left and right. i sell these spkrs and have had no complaints. hope this helps.
Jul 10, 2009 | Acoustic Research 900MHz Wireless Stereo...
I have a set of Wireless Acoustic Research speakers. I recently came home from college and the transmitter (connected to the television) does not work. I've tried everything from trying a different outlet...
Try using a different source than your television. If it works, then there's an issue with the output of the TV. However, if you use the same cables as you were using with the TV, they may be bad. Try using another device with a different set of cables to plug into the transmitter, which should help identify where your problem really is. Please rate my answer, thanks.
May 11, 2009 | Acoustic Research 900MHz Wireless Stereo...
Can Acoustic Research wirless speakers be used for surround?
yeah, I looked it up on thier website. Here is what they say.
Warning: This product is designed to work with line level outputs or headphone outputs only.
DO NOT connect it directly to speaker outputs as it will permanently damage the transmitter.
You can use these as surround speakers if you like. You just need a line level surround output on the receiver. Most high end receivers have this feature but, you may only have speaker level outputs.
If that is your case the only option you have is to use a "speaker to line level adapter".... http://www.crutchfield.com/p_543ADP12/Russound-ADP-1-2-Speaker-level-to-Line-level-Adapter.html?tp=9070
Now crutchfield.com is always a little high on prices but if you look around I have seen them around $10 online.
Good luck with your project.
Jan 28, 2009 | Acoustic Research 900MHz Wireless Stereo...
Wireless speakers AW872 transmitter won't power on anymore
Idhager,
I have the same set of speaker and had a similar problem. what I did was disconnent and reconnect the transceiver (sort of a reboot) and then powered everthing back up and that solved my problem.
Hope this helps
Dec 23, 2008 | Acoustic Research 900MHz Wireless Stereo...
Wireless speaker won't come on after plugging in now....
Try the adaptor that you know works in the speaker that doesn't. That will eliminate if its the adaptor or the speaker. You will need a multimeter to check if its the on /off switch or not. A quick alternative is to "bridge" out the on / off switch wiring. (Use a piece of wire to join the wires going through the switch together.)
Sep 04, 2017 | Acoustic Research 900MHz Wireless Stereo...
Acoustic Research Model AW871 wireless sterio speakers
Your connection between the AR transmitter and the ONKYO receiver sounds solid. I'd guess it's the wireless speakers that are the wrong point, or at least that's what I'd look at first. Doing a bit of research, I noticed a couple minor points. First, these seem prone to RF interference from other RF devices. Have to tried switching channels on them? Second, someone reported theirs would not work properly unless the speakers were turned on just before the transmitter, and turned off shortly after the transmitter. Apparently you have to hold the button on the front in for 5 seconds to turn the speakers on or off. I know that's rather basic, but it's been a few days and no one else has responded, so I figured we should start somewhere.
Aug 27, 2007 | Audio Players & Recorders
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
