TIMER PROBLEMS WHEN YOU SET THE TIMER TO CYCLE WANTED THEN PULL SWITCH (TIMER( TO TURN ON WASHER IT FILLS WITH WATER THEN STOPS. IF YOU MESS WITH SWITCH PUSH/PULL IT ON AND OFF YOU CAN GET IT TO RUN THROUGH THE FULL CYCLE. YOU MAY NEED TO DO THE ON/OFF 15 TO 20 TIMES BEFORE IT RUN. THEN SOMETIMES IT WILL PAST THE EDN OF CYCLE INTO THE NEXT ONE.THE WASH IS TEN YEARS OLD.
  • blueextc3221
    blueextc3221 May 11, 2010
    your timer is bad. with a model # we may be able to refer you to an online part to purchase.
  • 142 Answers
You need to replace the cycle timer. Try cleaning it with electric contact cleaner. This is available at any home depot. Sometimes just a good cleaning will solve the sticking problem.
Posted on Jun 02, 2009
    President:
  • 1,185 Answers
Inside the timer there are a set of contacts which supply the timer with the voltage to run it, plus all the other loads
Over a period of time the contacts get weak with the heat that is built up in them while the washer is running (Especially if you run high temperature washes and the heater is on a lot)
The contacts then burn on the two surfaces that meet and it become pitted.
Repeatedly switching on and off causes the two surfaces to meet occasionally and you will get a circuit
No way out other than a new timer.
Cold water won't stop before rinse cycle
if it fails to stop running only at the rinse part of the cycle it is probably in the timer as the solenoid valve has to cut the water off when the washer fills for the wash cycle too. fills for wash cycle and cuts off water, washes and drains, refills for rinse cycle and water just keeps running? does this every time you run it? that's in the timer. bad solenoid (water inlet valve) would keep running even on wash fill up. hope this helps.
Feb 25, 2014 | LG WM2688H Front Load Washer
Washer stops before rinse cycle
Check the water level sensor.
Nov 25, 2013 | Maytag Washing Machines
Washer stopped at the drain cycle Model LSR8233JQ1
Could be either a bad lid switch or a bad water valve.
Set the timer dial to SPIN and turn the machine on.
If it spins the lid switch is OK. If it does not spin the lid switch must be replaced.
Next,set the timer dial on a wash cycle and set the water temperature knob to COLD water. If it fills,the lid switch is bad. If it does not fill the water valve is bad or the cold screen filter is clogged.
If the COLD does not fill,turn off the cold water faucet. Remove the cold water hose from the machine water valve and check for a clooged screen.
If it does not fill with COLD water and the screen is clear,replace the water valve.
Oct 27, 2009 | Whirlpool LSR5132PQ Top Load Washer
My frigidaire top loader fills with water at the beginning of the wash...then nothing. it just sits there full of water.
Hi, could be your timer motor, timer or water level switch, first push timer knob in and manually advance to wash or spin cycle (program) then pull knob, see if machine operates, let me know, then i can tell you exactly what's problem.also advance timer, to spin cycle (program) machine should pump out water, or you can lower drain hose into bucket and empty machine, you should empty machine and try again, let me know what happened, we can solved this together. good luck.
Aug 12, 2009 | Frigidaire FWS933F Top Load Washer
Stops in the middle of wash cycle
Hi!
If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Washer will not progress to the rince cycle.
that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
I quote from : The cycle doesn't advance
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Nov 20, 2008 | Washing Machines
    When washer is in super wash cycle water will not stop causingthe tub to over fill running onto the floor.
    It sounds like you are trying to use the largest water level setting. If this is correct you may have a pressure switch problem.
    First turn the timer to spin and get all of the water out, that start a washer cycle with the water level set to the small or low setting and see if the washer fills to this level. if it stops at the low level great Now if it continues to fill and does stop you may need a pressure switch or the hose needs to be replaced that runs from the tub to the pressure switch.
    Now set at the medium level and try again. does it stop or over fill?
    If it over fills you probably need a pressure switch however before you purchase this, make sure the hose is in good condition one pin hole will cause your overfill condition.
    Jul 09, 2008 | Washing Machines
    Washer fills/agitates and stops prior to draining
    If pump works fine or still pumps out water, then it is a timer malfunction. Replace the timer and you should be fine. To locate a part number for your timer, refer to www3.sears.com with the model number off your washer.
    Mar 14, 2008 | Kenmore 24032\24036 Top Load Washer
    Does complete cycle
    When would the washer stop?
    Is there water in the washer when it stops?
    Feb 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
    LTE6234 Whirlpool Twin Thin Timer Broken?
    Check for voltage at the water inlet valve with the timer dial pushed in or in an off position. If no voltage replace the water valve. If you do have voltage you'll have to trace the circuits back from the water valve to the line. One point of demarcation is the water level switch. Pull the violet colored wire and see if it still fills while off. If it does it's likely the timer's bad.
    Jan 31, 2008 | Whirlpool LTE6234D Top Load Stacked...
    Washing Machines Logo
    65 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
