Question about Mitsubishi WS-65511 65" Rear Projection Television
Mitsubishi WS-65511 HDTV
I have a blinking green light and the set will not power on. Any sugestions on how to fix the problem? I have tried unpluging and system reset button, still blinking light. mine blinks for 40 seconds, about 80 times in that time, what does it mean?
  • fixya691 Jun 02, 2009
    mine stop blanking after 40 sec and shuts down. I use V21/V19 Mitsubishi DM repair Kit, and still don't work, what is my next step?
  • 126 Answers
Well, this is how that set is supposed to work. After it is plugged in the LED should blink for 70 to 90 seconds. That is normal and is the amount of time it takes for the Digital Module to boot up. During 'boot up' time the set is inoperable. Once the LED stops the set should operate normally. If the blinking never stops there is a problem with the Digital Module. If the blinking does stop but the set wont come on there are other things you can do to narrow down why the set is not working.
Posted on Jun 02, 2009
  • hatman1 Jun 02, 2009
    After LED stops blinking try to turn the set on with the remote. If it won't come on push and hold down the MENU and INPUT buttons on the front of the set until the LED blinks a two sequence code. This is a diagnostic code from the micro. If no blinking occurs after 10 seconds then you need to unplug the control panel and try the remote again. Leaking switches can cause all kinda strange problems with that unit. Unplugging the switches will eliminate them as a problem. The remote will still operate the set with the switch assembly disconnected.
I have a Mitsubishi Model WS-65511 the green light on the front was flahing (would not stop) I replaced the 7 Capacitors as was suggested. The light flashed for a while then stopped and turned green
I think I advised you before (on this page you will find a "make a comment button" which allows follow up questions and answers without posting another question.
Green power light now comes on and goes out in few seconds:
On front of set (not the remote) press and hold when that happens both the menu and input buttons for at least 5 seconds and release both.
Power light will blink a 2 digit code like 2 blinks, 2 blinks, pause and repeat that several times---this is an error code---let me know what code you find.
Note: if you have unplugged the set it clears the error codes and you have to plug back and try to turn set on--let it fail and repeat the self check.
SD TECH
Apr 22, 2012 | Mitsubishi WS-65511 65" Rear Projection...
Tip
Mitsubishi WS-65511 Manual Download
Download Mitsubishi WS-65511 HDTV Manual
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Have you misplaced your Mitsubishi WS-65511 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-65511 HDTV Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
__________________________________________
Reset Mitsubishi WS-65511 VChip Password
Bypass Mitsubishi WS-65511 Front Lock
on May 03, 2010 | Televison & Video
Tip
I hope that helps.
on May 03, 2010 | Mitsubishi WS-65511 65" Rear Projection...
Mitsubishi WS-65511. Won't stay on.
Bad filters in the main microprocessor. good luck.
Aug 30, 2009 | Mitsubishi WS-65511 65" Rear Projection...
I have a Mitsubishi Ws-65511 65" and the green light on front panel blinks continuesly and the tv will not turn on with the power button or the reset button on the front panel. If we unplug the power cord...
The Bulb in the unit needs to be replaced. To confirm, look in the manual for the set and it will explain the flashing lights by the numer and duration of flashes. Hope this helps.
Jun 07, 2009 | Mitsubishi WS-65511 65" Rear Projection...
My Mitsu WS-65511 will not power on. When power is pressed on tv or on remove solid green light comes on for a moment as if television is going to come on and then it just shuts back off. I have tried...
I have had my WS-65511 fail like this, first at 4 years, second 2 weeks later, then 3rd time yesterday (4/14/2009). In past, the tech replaced a thermal sensor p/n 299P313010A (but Mitsubishi says that part is not for WS-65511 and that it does not have a thermal sensor - go figure). It is a white rectangle with about 30 pins in 2 rows and is soldered onto a board in the TV. List price is about $25.
Apr 05, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Blinking green light, will not power up
my 55613 tv wont turn on just blinking green light
Sep 18, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi ws-65511 No power green light blinking
yes the capacitors on the DM need replacing. depending on the chassis some have 4 capacitors on the DM board where as other chassis have 7 capacitors on the DM power supply that are causeing the problem. If you dont know which chassis your has go to this link and leave them an email they can help you figure it out,
http://servicemanuals.vstore.ca/
May 31, 2008 | Mitsubishi WS-65511 65" Rear Projection...
How many times does it blink? Or is it a continuos blinking that doesnt stop? Let me know and I will be able to help you with it.
Apr 30, 2008 | Mitsubishi WS-65511 65" Rear Projection...
Green blinking light on Mitsubishi WS-55813 HDTV
generally this means a bad digital module.. as a techinican the first thing that we would check are what is know as standby voltages. if they were there we would replace digital module.! question. Does it blink for more than 70 seconds. This unit comes with a lockout feature. to unlock press and hold menu down for 10 seconds on front panel.
Jan 08, 2008 | Mitsubishi WS-55813 55" Rear Projection...
Open Questions:
See all Mitsubishi WS-65511 65" Rear Projection Television Questions
Mitsubishi WS-65511 65" Rear Projection Television Logo
351 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
