Question about Microsoft Windows XP Professional Upgrade Version OEM for PC
Intel 102ggc:The Firmware has detected that Cmos Checksum Error
I have Intel 102ggc with 2Gig Ram and I recently updated the bios, now when my Pc shuts down illegaly then it resets Date/Time and throws an error stating. "The Firmware has detected that Cmos Checksum Error has occurred. Press Enter to Continue..." I changed Three Batteries none fixed the issue. The Cmos jumper is on the same place as it was before the Bios Update. I tried switching jumper then it would say put the jumper back Cmos is reset. Still the problem exists. Please help me solve this issue if one can. Thanks in Advance. Dear IT Friends, Please tell me about the soluation on the following two things: (1)The firmware has detected that a CMOS Checksum Error occurred. Press the Enter key tocontinue. (2) The firmware has detected that the system date/time has not been set. Press the enter key to continue. Kindly do the needful to give reply. Thanks & Regards, Rishikesh
  • Dick
    Dick May 11, 2010
    There was an error while updating the BIOS, or the wrong BIOS was used.
  • Microsoft Master
  • 4,806 Answers
Hi there.
Basically you first bios update was bad, if you can get into the operating system re-flash the bios again, that will sort it out.
Good luck and thanks for choosing FixYa!!
Posted on Jun 02, 2009
Posted on Jan 11, 2010
What is "the firmware has detected that a CMOS checksum error occurred.Press the Enter key to continue. The firmware has detected that the system date/time has not been set." What is this error.
I assume that you entered the BIOS after replacing the battery and set the date and time? If you cannot get to the BIOS after receiving this message, it usually means that the BIOS has become corrupted, either by failure or by virus. You may be able to reflash it if you can download a bios update from the manufacturer.
Dec 24, 2014 | Computers & Internet
I'm getting four beeps with American mega trend what does that mean?
Table of diagnostic beep codes compiled by AMI BIOS during power-on self test[8][9] Number of beeps
Meaning
1 - power-on self test successful
2 - Parity error in the first 64KiB of RAM
3 - Memory failure in the first 64KiB of RAM
4 - Same as 3, but also including a non-functional timer 1
5 - CPU error
6 - Error in the A20 line on the 8042 keyboard controller chip
7 - Generation of a CPU virtual mode exception signifying an error
8 - Read/write error when accessing system video RAM
9 - Mismatch between the calculated checksum of the ROM firmware and the expected value hardcoded into the firmware.
10 - Read/write error for the CMOS NVRAM shutdown register
11 - A fault in the L2 cache
Jul 20, 2014 | Intel american megatrends AMIDiag Suite...
I have recently updated the system bios it's successfully upgraded but the problem is its giving CMOS Checksum bad error please I yesterday buy the system
Hi.
Exist some problems that can cause that:
1- The CMOS battery. Solution: Change it for a new one.
2- Some problem with the time specifications in the BIOS.
3- Some drive that isn't connected properly.
Mar 01, 2013 | Radio Communications
Getting a CMOS checksum bad error when starting my Acer M5640 Desktop with Windows 7 Thanks Daniel
Solutions to CMOS Checksum Bad Error
The CMOS Checksum Bad Error can be fixed easily by following the listed steps carefully.
CMOS Battery may not be functioning properly
If you suspect that your CMOS battery is not functioning properly, you can easily change it. Before changing your battery, reboot your computer to make sure that the error still exists. If it does, go into your CMOS and write down all of the settings. If all the settings are lost, you can usually retrieve them from your computer manufacturer. Now locate the battery and remove it, you might need to consult your computer's manual or technical support to remove your battery (the battery a flat, shiny silver colored and coin-shaped). Take down the CMOS battery's information such as volt, size, etc. Once you have your new battery, you can replace it and reenter your CMOS settings. If your battery was the cause of the CMOS Checksum Bad Error, you should have solved the problem.
Your BIOS may have been updated
If your BIOS have been updated recently, your CMOS settings may have reset. Make sure that the values entered in the BIOS are correct or simply reset them to the default settings. If you believe that a virus has updated your BIOS settings, run a virus scan and make sure that the BIOS settings are back to the default.
The Computer may not have been shut down properly
Sometimes when running MS Windows, if you shut down your computer without first properly shutting down your operating system, it will corrupt the CMOS settings causing the CMOS Checksum Bad Error. You can easily avoid this error by making sure that you completely shut down your computer properly before turning off the main power. Usually this entails going into the Start Menu, clicking on Turn Off Computer/ Shut Down. If improper shutdown was the cause of the error, you may have solved the issue.
akuma_ryu21 rate it pls!!
Jan 21, 2011 | Computers & Internet
Cmos checksum error & keyboard not function
CMOS checksum errors
Explanation: A checksum is computed as an error-detecting code, to protect the BIOS settings stored in the CMOS memory. Each time the system is booted this number is recomputed and checked against the stored value. If they do not match, an error message is generated to tell you that the CMOS memory contents may have been corrupted and therefore some settings may be wrong. BIOSes react in different ways to encountering this sort of error. Some will warn the user and then continue on with whatever settings were in the CMOS. Others will assume that the settings that were in the CMOS were corrupted and will load default values stored in the BIOS chip "for safety reasons". The error message will indicate which your system is doing.
Diagnosis: The most common cause of checksum errors in CMOS is a battery that is losing power. Viruses can also affect CMOS settings, and motherboard problems can also affect the stored values.
Recommendation: Follow the instructions in this section to address the CMOS corruption. You should make sure that all of the BIOS settings in the system are correct, by rebooting the system, going into BIOS setup and double-checking all the values (hopefully against a recent BIOS settings backup).
Sep 24, 2010 | Computers & Internet
Pc "bios"problem
this looks like you have kept the bios password and you forgot it. just do one thing open the cpu case to access the inside of the system and then just remove the battery in it. wait for 5 min and again plug in the battery. thats it your bios memory password will be reset.
2nd solution without removing battery. just reset the bios as shorting the jumper pins. consult your motherboard book to know where to find the bios reset. it will be written as CLEAR CMOS.
Dec 21, 2009 | Intel Computers & Internet
if you have vista you could do a memory check in the boot options by resarting computer and key f10 boot options, then find memory check witch will display any errors with soloutions.
Dec 12, 2008 | Intel D102GGC2 Motherboard
Cmos checksum bad...usb current status detected system shut down 15 sec
Situation Remedies If you have encountered this error and would like to fix your computer, here are some remedies for each situation:
CMOS Battery Not Functioning Properly: If you suspect your CMOS battery is not functioning properly you can easily change it. Before changing your battery, reboot your computer to make sure that the error still exists. If it does, go into your CMOS and write down all of the settings. If all settings are lost, you can usually get them from your computer manufacturer. Now locate the battery and remove it, you might need to consult your computers manual or tech support to remove your battery. Take down the CMOS batteries information such as volt, size, etc. Once you have your new battery, you can replace it and reenter your CMOS settings. If your battery was the cause of the CMOS Checksum Bad Error, you should have remedied the problem.
Your BIOS has Been Updated (either by you or possibly a virus): If your BIOS has been updated recently, your CMOS settings may have become reset. Make sure that the values entered in the BIOS are correct or simply reset them to the default settings. If you believe that a virus updated your BIOS settings, run a virus scan and make sure that the BIOS settings are back to the default.
The Computer Was Shut Down Improperly: Sometimes when running MS Windows, if you shut down your laptop or desktop without first properly shutting down your operating system it will corrupt the CMOS settings causing the CMOS Checksum Bad Error. You can easily avoid this error by making sure that you completely shut down your computer before turning off the power. Usually this entails going into the Start Menu/ Turn Off Computer/ Shut Down. If you received the error, shut down the computer properly, if this is the cause of the error, the error message will not return.
May 11, 2008 | ASUS M2N-MX Motherboard
Cmos checksum error
cmos checksum errors are caused by a bad battery.
If that dont work then the board is bad from the factory.
Dec 24, 2007 | ASUS A8V-VM Motherboard
Microsoft Windows XP Professional Upgrade Version OEM for PC   Logo
1,417 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
