Question about Maytag Neptune MDG5500AW Gas Dryer
Want to change from gas to power on maytag dryer
I have a MDG5500AWW maytag dryer and I want to know if it can be converted to power
  • blueextc3221
    blueextc3221 May 11, 2010
    no it cannot. it uses different heating element - controller etc.
    Champion:
  • 219 Answers
No they cant
Posted on Jun 03, 2009
Maytag dryer (model MDG5500AWW) will not heat.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Mar 09, 2011 | Maytag Neptune MDG5500AW Gas Dryer
NO HEAT MDG5500AWW 56780829AX DRYER TURNS BUT NO
heatman101
Dec 06, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Mdg5500aww lp gas dryer heating problem it fires once but dosent burn long clothes dont dry help
When a gas dryer starts and the burner does not stay lit more than one minute the flame sensor is not detecting the flame to as a by design safety feature the burner is automatically shut off. It is not sensing flame so it is shut off.
This is the most likely suspect. http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg5500aww-%3d%3di2681&PartID=2681
BEFORE you change this part make sure that the outside vent flapper and the ducting form the back of the dryer is free of lint. Disconnect the dryer vent and try it with nothing connected to the dryer. Also check around the lint filter area for lint especially in the bottom. If there is not a lint or ducting problem then by all means change the flame sensor.
Thanks for using FixYa!
Kelly
Mar 05, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDG5500AWW gas dryer ignites, then flame goes out
The 'radiant sensor/ needs to be replaced. This sensor tells the system that the flame is lit and everything is good. Go to repairclinic.com
Oct 02, 2009 | Maytag Neptune MDG5500AW Gas Dryer
I need to find a repair manual for Maytag MDG5500AWW gas dryer
Most service manuals have to be purchased, but you may find what you need for free by following the link below. You can purchase service manuals at, www.repairclinic.com
http://laundry.manualsonline.com/manuals/mfg/maytag/maytag_washerdryer_product_list.html
Sep 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag mdg5500aww gas dryer sensor
First of all shut off the power by pulling out the plug.
If you are sure of the sensor issue then you need to remove four screws on the inside of the door. Two screws are located on the left and two on the right, look at the hinge and you will find two. The door will lift out when you remove the screws. When the screws are out of the front, the front panel can be remove by pulling on the outside surface.
Aug 11, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Gas will not stay lit.
sounds like a bad coil
they are on top of the gas valve
Jul 03, 2009 | Maytag Neptune MDG5500AW Gas Dryer
I need access to gas valve in my Maytag mdg5500aww dryer
When I posted the question, I had not removed the front of the dryer. I thought the gas burner etc. had to be accessed from the back. As soon as I removed the front of the dryer I realized it was all up front and accessable. Conversion was straight forward from that point.
Jan 16, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag dryer model # mdg5500aww sensor not working is just starts a 37 minutes
How do I lift the top panel of my Maytag Neptune dryer model MDG5500AWW?
Jan 13, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
93 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
