Question about Kenmore 64902 Electric Dryer
I have a Kenmore 400
My timer does not work on the auto dry cycle but it does work on the minute cycle. My husband checked the timer to see if it was getting power and it does on the minute cycle but not the auto dry cycle. Could it be the timer going bad or something else???
  • 864 Answers
The sensor that determines how wet the clothes are is not working.
Posted on Jun 02, 2009
Kenmore elite dryer will not work on manual cycles which consist of three options; timed dry, express dry, and touch up. Dryer will work on auto cycles only
most likely the board is bad,the board is big money,just keep using it on auto,that's what you should be using anyway the dryer automatically stops when the clothes are dry,say you set your clothes for 60 minutes and they dry in 40,you're drying the clothes 20 more minutes that you didn't need,if you set it on auto the dryer sensor knows the clothes are dry and shuts it down when they are dry,this doesn't have a timer this has a computer board or it could be the touch pad not working correctly if it doesn't take commands but either part is expensive the board is like 200 and the touch pad is close to 300 bucks,i would use it on auto,one more thing to check is sometimes the ribbon or plug that connects the touch pad to the board could be loose or have some lint or something in it,i've just unplugged them and plugged them back in and then it works,also clean out all the lint out of the dryer and vent line,this is the number one cause of most problems in dryers and you won't have to worry about a dryer fire,if it's gas you should do this once a year yours is electric so you can wait like every 18 months with gas you have a flame in there so you don't want lint in or around the flame,clean out the duct that the lint filter slides down into and i use a leaf blower to blow out the vent line just take it off the dryer stick the leaf blower int the line and blow it to the outside when you have the dryer running go back outside and make sure the air is blowing out good
Feb 05, 2018 | Kenmore Dryers
Kenmore elete model 110.67032600 timer changes to higher # and takes a long time to dry on auto dry.
I had this and it was lint trapped in door below lint filter screen.( several handfulls) Took door apart/ reassembled and he worked fine.
Oct 07, 2015 | Kenmore Dryers
Kenmore 400 series gas dryer doesnt dry clothes
Replace timer, if you are sure that it is not working.
Do an internet search for kenmore driver parts and get dozens of hits.
Aug 03, 2014 | Kenmore Dryers
The timer does not work correctly. The timer does not move and the dryer runs forever.
If the timer doesnt even advance in the time dry cycle then you have a bad timer. However you will need to make sure that your getting heat throughout the auto dry cycle because no heat will cause the dryer to run forever. Hope this helps _MJ_
Aug 17, 2010 | Kenmore Dryers
Problem with Dryer Timer or heating element
The heat cycle must be working for the timer to advance in the Auto Dry setting.
Your heating element and or high limit thermostat is bad.
We need a complete model number to be more specific.
May 31, 2010 | Kenmore 600 6965 Electric Dryer
Dryer Gets Too Hot!
Could be the heat switch on the motor or a grounded heat element
May 20, 2009 | Kenmore 400 6942 Dryer
Kenmore dryer timer will not turn.
Bad timer motor if you are using timed dry.
If using auto dry probably a bad sensor.
Verify by using any time dry or air fluff cycle and see if the timer moves.
Mar 03, 2009 | Kenmore 64902 Electric Dryer
My Amana Model NDG5800AWW dryer has ceased to dry clothes dependably. The Only setting that still sort of works is HIGH timed drying, and this heats up to what used to be the "delicate" setting....
if you are using the auto dry setting and the dryer is still running after 5 hours you either have a timer issue or a thermostat problem.
The timer is driven by a motor, if the timer motor is bad the timer wont time out.
in the auto dry cycle the thermostat has to cycle off and on which then sends power to the timer again advancing the timer.
set the timer in a timed dry cycle for say ten minutes, if the timer advances and turns off then you know the timer works. if it doesnt advance you have a timer motor issue,
if the problem is the auto cycle, you could replace the thermostat, about $20 american. however a clock timer would be cheaper.
Based on how old is your machine and do you want to stick a timer in it after already paying the service man is up to you.
A basic bath towel load should be dry in about 50 minutes, this varies on how good your seals are and how long a vent you are running, if the dryer vent was plugged you already have shortened the life of your heating element.
Sep 22, 2008 | Amana Dryers
Dryer runs but wont auto shut off
On auto dry cycles, the cycle is controlled by moisture sensing bars located on either the rear or front bulkhead, ( visible inside dryer ) if the moisture sensor bars are shorted together (normally by wet clothing) the dryer will continue to run. If the dryer continues to run when the clothes are plenty dry, check and see if there is anything stuck between the sensor bars, (sometimes a metal sequin will cause this) or see if they are damaged. If not, you may have a problem with a timer contact, if the timer advances and stops moving at the same spot each time, I would suspect the timer. If this is an EvenHeat dryer, examine the control board located to the right of the timer in the control panel, for any burned components. Hope this helps.
Sep 15, 2008 | Kenmore 73952 Gas Dryer
Kenmore 64902 Electric Dryer Logo
97 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
