Question about Gateway Solo 9300 Notebook
Cant seem to find how to replace keyboard.
How do i remove the gateway solo 9300 keyboard?
Why is there no operating system found on my gateway solo 9300
Try to reinstall if you keep getting the same message. Hard drive failure, need a new one
Dec 17, 2013 | Gateway Solo 9300 Notebook
How to open the case of a gateway solo 9300
Hi ,
open the case
(with screws removed). ... Disassembly the Gateway Solo 9300 ...
Jan 17, 2010 | Gateway Solo 9300 Notebook
Where can I get a copy of the operating system for my gateway solo 9300 notebook
From Gateway ... should have gotten a copy when new ... most if not all can be downloaded from the manufacturers web site. You should find the license on the bottom of the computer
Dec 29, 2009 | Gateway Solo 9300 Notebook
Gateway solo 40 gig will it work in tshiba laptop a45-s150
Yes you can, but most likely it will not work (you have to format it and install fresh copy of Windows (or Linux)).
Mar 28, 2009 | Gateway Solo 9300 Notebook
Gateway Solo 9300 Laptop computer notebook PIII 500MHz
This is not a good laptop, If you are thinking of purchasing. My advice is no. It just doesnt have the processing power to run almost anything.
If you could leave a comment with a price range your willing to spend. Ill find you a laptop thats much nicer.
Jan 05, 2009 | Gateway Solo 9100/9150 Series Laptop...
Looking for part gateway p/n 5501545
No one seems to be selling that particular part anymore, which laptop do you have? The Gateway Solo 9300? You may have to try to find an upgrade that's compatible as far as the motherboard connection is concerned.
Solo Series 9300 components are here.
Solo Series 9300VE components are here.
If you don't have a Solo 9300, you can look up your laptop model on Gateway's website; newer models can be found here and older models, also called "Legacy Notebooks," here.
Dec 22, 2008 | Gateway 8X DVD-ROM 5501545 (5501545)...
Gateway solo pro 9300 bios password is not remove
Go to your friend. Download and burn this cd http://www.9down.com/Hiren-s-BootCD-9-8-Keyboard-Patch-73110/
Boot your pc from it and use BIOS / CMOS Tools from it.This is a better way
Dec 15, 2008 | Gateway Solo 9300 Notebook
Touchpad
pluggung in a ps2 mouse will usually isolate the TP.
Refer to your manual or customer support at Gateway
Nov 26, 2007 | Gateway SOLO 9300 PII 400 MHZ 128 RAM 6GB...
Dismantle
I htink the easies way would be to get the keyboard out. Have you been able to do so? There might be some small "sliders" with holes in them between the keys around the edge of the keyboard. Put a paperclip in the hole and slide the "locking bolt" towards the middle of the keyboard (only a mm or two) to loosen it.
Gateway solo 9300
Sounds like the cable is not securely connected to the motherboard.
I would doubt the OS is responsible for this problem.
Nice little machine, the service manual is available for download for free. Might give a shot at refastening the cable.
If you're not that enthusiastic about taking a laptop apart, possibly an external mouse?
Put XP back on. If you have enough memory, it runs just fine.
Good luck
Nov 25, 2007 | Gateway SOLO 9300 PII 400 MHZ 128 RAM 6GB...
Gateway Solo 9300 Notebook Logo
103 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
