Question about Samsung Televison & Video
I need the factory v-chip code for a standard Samtron television so that I can unlock the channels that were accidentally locked out.
I have an older samtron tv that was made in 2002. The v-chip code was accidentally pushed on the remote control. I have never set the v-chip code so there must be a factory number that is set for a code. I cannot access most of the cable channels now. Can you help me, thanks.
Sres. Tengo problemas para encender mi SANSUI Modelo SVL2002V
Posted on Aug 02, 2010
Child lock on sharp
Turn on the TV and grab the remote. In most cases, you will need the original remote to unlock the TV if you aren't sure of the unlock code. If you don't have the original remote, you will need to purchase one.
Look at the screen. If you see a blank screen with a red key on the bottom of the screen, press 'Function' and 'Mute' at the same time. This should unlock the channel. This is an option for people who want the TV to stay locked but, want to be able to bypass the lock to watch a certain show or channel. All other channels will remain locked and the TV will fully lock when it is turned off.
Unlock all of the channels on the TV by entering the factory reset code. There are three main reset codes that TV manufacturers set. These are 0711, 6688 and 3308. Try each one until you find the one that works. This will reset the TV to original factory settings. When you do this, you will loose any information that you have stored in the TV, such as favorite channels, automatic timers and the clock. You will have to go through the full initial set up.
Call the technical support service number in your owner's manual if none of those codes work. A technician can help you troubleshoot the television because the problem may not be the locking control. When you call, make sure that you have the model number and serial number of the TV.
Take your television to a TV repair shop. In some cases, a professional who access to wiring diagrams for your television set may have to rewire certain components in order for the television to unlock. This is usually the case when the TV locks by itself while it is on. To get more details, http://electronicshelponline.blogspot.com/Pull up older posts.
Nov 30, 2013 | Sharp 21B-S10 21" TV
Hard reset
Most TVs have a parental control lock that can be set to prevent children from watching specific television shows. In order to activate or deactivate the controls, you need to know the four digit security code or parental lock control password. If you forget the number you chose or if the lock gets set accidentally, it is still possible to unlock the TV.
Instructions
Call the technical support service number in your owner's manual if none of those codes work. A technician can help you troubleshoot the television because the problem may not be the locking control. When you call, make sure that you have the model number and serial number of the TV.Take your television to a TV repair shop. In some cases, a professional who access to wiring diagrams for your television set may have to rewire certain components in order for the television to unlock. This is usually the case when the TV locks by itself while it is on.
Jun 08, 2013 | Akai CTD-1390 TV
My screen is all blue, no image and voice. a lock on the upper left corner
It sounds that your TV is locked by someway. Just unlock it. Proceed the following.
Many Jensen TVs have a parental lock that can be set to stop children from watching certain television shows or channels. In order to activate or deactivate the controls, you have to know the four-digit code or parental lock passcode. If you forget the passcode or if the lock gets set accidentally, you can still unlock the TV.
• Turn on the TV using the remote control. In most cases, you will need the original Jensen remote to unlock the TV if you aren't sure of the unlock code. You can purchase an original replacement online if necessary.
• Look at the screen. If you see a red key on the bottom of the screen, press "Function" and "Mute" on the remote at the same time. This will unlock the channel. Do this if you want to bypass the lock to watch a certain show or channel while leaving the TV locked. All other channels will remain locked and the TV will lock again when it is turned off.
• Unlock all of the channels on the TV by entering 0711 or 3308. These are the Jensen factory reset codes that will reset the TV to the original factory settings. By doing this, you will loose any information that you have stored in the TV, such as channel labels and schedules. You will have to program the TV again by going through the entire initial set up.
•Call the technical support service number in your owner's manual if neither of those codes work. A technician can help you troubleshoot the television as the problem may not be the parental lock feature. Have the model number and serial number of the TV available when you call.
• Take your television to a TV repair shop if neither of the codes work and the TV locked by itself while it was turned on. In this case, the TV may need to be rewired.
Sep 27, 2012 | Jensen Q2749J 27" TV
How do i disable the child lock
Sep 18, 2012 | Jensen TS2750J TV
My akai tv is locked,don't know the code
Instructions
Sep 13, 2012 | Jensen Q2749J 27" TV
Want to reset the v-chip on my 2001orion tv model # 1933
Omni TVs have a child lock that allows parents to prevent children from watching specific channels or television shows with certain ratings. To activate or deactivate the controls, you need the four digit pass code. If you forget the pass code or if the lock gets set accidentally, you can still unlock the TV.
• Use the original Omni remote control to turn on the TV. You need the original remote to bypass the child lock. A universal remote won't work.
Check the screen. If you see a blank screen with a red key on it, press the "Function" and "Mute" buttons at the same time. This unlocks only the channel that is on the TV. All the other channels will remain locked and the TV will lock again when it is turned off.
• Unlock all of the channels on the TV by entering "6688," which is the factory reset code. This code resets the TV to original factory settings. Once this is done, you will have to go through the initial setup.
• Call Omni technical support at (416) 260-0047. A technician can help you troubleshoot the television as the problem may not be the child lock. You'll need to know the model number and serial number of the TV.
•Take your television to a TV repair shop if you are still unable to unlock the TV. The problem may be with the wiring, so the repairman may have to rewire the TV
Aug 12, 2012 | Televison & Video
CODE FOR UNLOCKING V-CHIP
Panasonic sets need to be reset to clear the v-chip settings. To do this, put it in standby mode, then press the POWER and ACTION buttons at the same time and then turn the power off. The set should reset to the factory defaults, and reset the v-chip.
Jul 15, 2012 | Televison & Video
Cant unlock pin number jvc LT-32DR1BJ
Instructions
Visit this site for more details. The site name is (Electro-help). Just type in "electronicshelponline.blogspot" into the search box of your browser, and click search. You can see a site by this name. Pull up older posts there. Sometimes, ads related to each post might give you details about the availability of spare parts and price. It is a blogspot site, in English Language
Jun 27, 2012 | JVC Televison & Video
What is the code to unlock channels for JVC TV
JVC Standard Televisions 'Set Lock Code' are factory set to '0000'
Nov 17, 2009 | JVC Televison & Video
Need to unlock vchip passcode; factory reset?
v chip block just popped up on screen , and i never set the tv to v chip
Apr 27, 2009 | Samsung Televison & Video
Televison & Video Logo
147 people viewed this question
Jerry Greenberg
Jerry Greenberg
