Question about HP Compaq d530 SFF PC Desktop
I just cannot find the model name of my ethernet controller for my HP Compaq D530 Sff.
I am using a HP Compaq D530 SFF CPU and i need to install the driver for my ethernet controller but the problem is I can't figure out what the model name is.So i right click on 'ethernet controller' and go to 'properties',then go to 'details'.It shows PCI\VEN_14E4&DEV_1696&SUBSYS_12BC103C&REV_03\4&3A321F38&0&10F0.May anyone tell me what it means...Thanks a lot!
  • HP Master
  • 4,806 Answers
Hi there.
You don't need the model number of the ethernet controller itself, you have already provided the information i need to help you (the computer make and model).
Go here to HP support, choose your operating system (win2000, XP etc) download and install the LAN (network) driver >>>>>>
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=uk&prodNameId=316715&taskId=135&prodTypeId=12454&prodSeriesId=316713&submit.y=0&submit.x=0&lang=en&cc=uk&y=0&x=0
Good luck and thanks for choosing FixYa!!
Posted on Jun 02, 2009
    President:
  • 948 Answers
5 Suggested Answers
buffalonyman
  • 1865 Answers
SOURCE: ethernet driver for hp compaq d530
Drivers are located here: http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=316715&lang=en&cc=us&prodTypeId=12454&prodSeriesId=316713&taskId=135
You must select the appropriate operating system for your application
Posted on Apr 25, 2009
siawolf
  • 749 Answers
SOURCE: HP D530 SFF CHASIS FAN NOT DETECTED
Should be an alarm setting, usually in the bios, for both chassis intrution and fan and cpu warnings. disable it and no error message.
Most likely the fan power is connected to the wrong fan port on the motherboard itself and placing it on the correct port will fix the issue.
Posted on Mar 17, 2009
  • 8 Answers
SOURCE: hp compaq driver d530 sff
I found the drivers I needed at http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=316715&lang=en&cc=us&prodTypeId=12454&prodSeriesId=316713&taskId=135
I am running XP and used SoundMax Integrated Digital Audio for audio &
Intel Graphics Driver for Microsoft Windows 2000/XP for video.
Posted on Aug 19, 2008
joecoolvette
  • 5660 Answers
SOURCE: HP Compaq d530 SFF PC
No Ben, there is no jumper for this on the motherboard.
The method is to go into BIOS Setup, and change it to AGP.
(Should be the default factory setting however, IF you have an AGP graphics card installed)
For your computer, BIOS Setup is referred to as
Computer Setup Utilities. It is accessed by pressing the F10 key at a certain time.
1) Computer off. Turn the computer on. As SOON as the monitor light turns green, start tapping the F10 key. (Tap in 2 second intervals)
If you do not press the F10 key in time, the computer will go on to load Windows. Shut the computer down normally. Try again.
When you are in Computer Setup, select your language, press the Enter key.
(Use the appropriate arrow key to select. You cannot use your mouse anymore when in Computer Setup)
You will see Four headings.
File, Storage, Security, and Advanced.
Use the Left or Right arrow key to select Advanced
Press the Enter key.
In the menu headings select PCI VGA Configuration .
(Use the appropriate arrow key)
It will only display if you have an AGP graphics card installed. (Multiple PCI video adapters)
It will not display if you only have Integrated Graphics, and no AGP graphics card.
(Integrated Graphics is also referred to as Onboard.
ON-Board. Meaning ON the motherBoard)
Use the appropriate arrow key to highlight AGP. Press the Enter key.
Press the F10 key. (Save changes)
Now things may differ.
Some BIOS Setup utilities, (Computer Setup Utility for your computer), have two different methods for selecting YES.
You may see a Y/N, or a YES/NO
Use the appropriate arrow key, and highlight YES, if it shows a YES/NO
Press the y key if it shows a Y/N.
(It is Not a capital Y. The capital Y is shown for clarity. Press the lower case y on your keyboard)
Now press the Enter key.
Your computer will now restart with the changes you have made.
NOTE*
If by some chance your computer did not come with an AGP graphics card, and you are installing one, you MUST load the drivers for the graphics card.
Drivers are small software 'pieces', that allow the computer to 'communicate' with the device.
Drivers come on a CD disk provided with the graphic card. The drivers SHOULD be installed BEFORE the graphics card is installed.
Why?
Because as soon as a new device is installed, and the computer is turned on, Windows breaks it's neck to find appropriate drivers.
IF THE drivers are not already installed, Windows will chose from it's thousands of generic drivers, and match one accordingly.
If you install the drivers AFTER you have installed the graphics card, you will get a driver Conflict.
Crude illustration:
Windows: 'Which drivers do I use? These or THESE?'
Your graphics will look like something for the Flintstones.
If you do not have the driver installation CD disk, you will need to download the drivers from HP Support,
IF they are available.
If your computer Came with a Restoration Disk, AND your computer has an AGP graphics card, the drivers are on that disk.
The disk is installed in your optical drive, and when asked you chose REPAIR. (Or non-destructive installation)
Should you need more information, or want me to look to see if graphics drivers are available, post in a Comment.
Posted on Jan 15, 2010
Testimonial: "Thanks for the prompt replies and ideas"
HP Compaq d530 SFF PC Desktop to get audio driver software?
HP Compaq d530 SFF Drivers
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Jan 05, 2011 | HP Compaq d530 SFF PC Desktop
Compaq d530 SFF PC Desktop: what is the most amount of ram that can be place i...
hi! I have the same PC but not flat , and I work on it with 768mb RAM
it work fine with XP
I think 1Gb and more can cause problems and shirt your CPU life
don't use vista it over heat and exhaust the CPU
If you know how to control FAN SPEED , because even he heat up she don't accelerate , if you have an idea please let me know :
try.39@hotmail.com
thanks
May 18, 2010 | HP Compaq d530 SFF PC Desktop
I have failed to install ethernet driver after
your operating system should detect and install the drivers for your network controller if it is an internal on board LAN. however you must be sure that you have the LAN enabled in your BIOS setup under the advanced selection on the bios screen. otherwise , your operating system won't even see that you have a LAN connection.
Mar 01, 2010 | HP Compaq d530 SFF PC Desktop
CPU FAN SPEED IN HP Compaq d530 Small Form Factor Desktop PC
The fan/heat sink on these models get plugged with dust very easily, use an air compressor or can of air to blow the dust out of the heat sink and fan. In extreme cases the thermal paste gets dried out and needs to be re-applied to properly cool the processor.
Dec 01, 2008 | HP Compaq d530 SFF PC Desktop
Hp compaq d530 CMT motherboard diagram
You are missing the front headphone / microphone connector that plugs into the motherboard. Or a way to jump this to close the headphones so the sound will come out the back.
Aug 03, 2008 | HP Compaq d530 SFF PC Desktop
HP Compaq d530 SFF PC Desktop Logo
3,300 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
